1958 De Luxe Beetle from Morocco
Page: Previous  1, 2, 3 ... , 12, 13, 14  Next
flyboy161
flyboy161 is offline
PostPosted: Sun Dec 29, 2019 11:46 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Well, thank you, Mr. Mike!
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
foamermetal
foamermetal is offline
PostPosted: Mon Dec 30, 2019 4:30 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Nice job on that quarter. I've got to address around the back window myself.
flyboy161
PostPosted: Sun Jan 12, 2020 10:50 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
I puttered around this weekend addressing some of the uglier rust on the car. The passenger door had some rust through spots at the back lower corner. I cut out a 1.2Ē x 3.5Ē area and welded in a patch.
There was also some rust that turned into a hole at the bottom of the B pillar once I tapped on it with a hammer. I cut it out. But Iíll need to square it up before I start fabricating a patch. I also need to decide the best course of action for the next issue before I continue.
Finally the heater tube where it enters the heater channel is just yuck. Iím sitting on the fence on this one. I donít want to replace a heater channel.
If I end up patching that tube Iím going to have to cut into the channel skin to fully treat it. Ugh!
On a happy note, I did find a body shop thatíll spray the car when Iím ready.
flyboy161
PostPosted: Sun Jan 12, 2020 11:13 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
The underseat heater tube cover on the passenger side is also in pretty sad shape.
Replacement is on the way
flyboy161
PostPosted: Wed Jan 15, 2020 10:09 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Now starts the paint removal. At an hour a day, I should be ready to smooth and prime this door by Saturday 🙄
flyboy161
PostPosted: Sat Jan 18, 2020 1:09 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Well, 4 days later...
Not really. I didnít touch it after the first day. The rest of the door was sanded this afternoon. I needed a bigger sander. Laughing
flyboy161
PostPosted: Mon Jan 20, 2020 10:20 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Unfortunately, rust has reared its ugly head again. This time at the A pillar passenger side. Also in the heater tube on the drivers side. Youíve already seen the heater tube and B pillar on the passenger side.
The passenger B pillar.
The bottom of the passenger heater tube
The passenger A pillar. This was one teeny little hole that opened up with some scribe work
The underside of the drivers heater tube.
Nothing to do but replace heater channels. Ugh!
First step was to get the door out of the way.
Surprisingly, all the door screws came out with an impact screwdriver with the exception of one at the lower right outboard position. Drilled it out and then retapped the hole. Fortunately I have a fair stash of hardware Iíve collected over the years. Iíll be ordering Klassic Fab heater channels and a couple of odds and ends. Iíll finish stripping the door while waiting for those to arrive. Collect up some bracing and begin uncovering spot welds. I really did not want to end up doing heater channels, but itíll be a good opportunity to fix it right.
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Mon Jan 20, 2020 11:02 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Jeez, I'm exhausted looking at all that work you're doing. Laughing
As my Dad would say when I was a kid "God damn it, if you can't do it right the first time, don't do it at all!"
[email protected]
The Samba member since 2004.
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
flyboy161
PostPosted: Mon Jan 20, 2020 11:27 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Thanks Bill. Iím exhausted just thinking about whatís coming. I will reinstall the door prior to removing the heater channel. I just wanted it out of the way to thoroughly evaluate the rust damage and to depaint the area.
Iím thinking of transitioning away from the wire feed welder for this job as I am a much better oxy-acetylene type of guy. Better for me.
Anyhoo, this promises to be a very slow process with not a lot of frequent updates. Iíll start de-painting and removing seam sealer this week.
flyboy161
PostPosted: Mon Jan 20, 2020 2:07 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Well, I decided to get started cleaning up the interior for the upcoming mayhem. Still had a lot of tar paper to scrape out plus 62 year old body seam sealant.
Passenger side. Not terrible. Helps to able to see where the spot welds are hiding
Drivers side and package trays werenít hiding anything awful
While removing body sealant up front I did find something on the passenger side
Again, not awful, but will need to be repaired
Something about the passenger side of this car Confused
flyboy161
PostPosted: Wed Jan 22, 2020 9:06 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Yesterday, I took a break. Today I can only give her an hour and a half, but I made some progress.
At the bottom of the quarter panels...
5 little pin holes
Only 5 layers of paint to go through Shocked
The purple, a yellow white primer
A rust colored primer
The Capri blue
And the original primer.
Ugh! On the bright side, I havenít run across anything awful yet.
When the car was repainted, they sanded the Capri pretty well, so itís kind of leopard skin pattern under all the other layers. But they left all the original primer. At this rate Iíll be ready to paint in a couple of years, lol
flyboy161
PostPosted: Sat Jan 25, 2020 1:15 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Today was sanding with a purpose. Uncover all the spot welds needed to remove the heater channel.
The long view
Happy to see no rot here
Bottom of the rear quarter panel
Inside under the back seat
Base of the B pillar
Bottom of the A pillar
At the front bulkhead
And finally the front quarter panel. Double row of spot welds...ugh
flyboy161
PostPosted: Sun Jan 26, 2020 1:05 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Work smarter, not harder: My fatherís mantra
Today a little heat and razor blade work made short work out of stripping the rest of the rear quarter panel.
This definitely sped up the process. A little primer residue is all thatís left after the razor work, and that vanishes quickly once sanded.
flyboy161
PostPosted: Sun Jan 26, 2020 1:50 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
And finally for today, my ugly lesson learned...what lurks under pretty paint is not always golden.
So, continuing the razor blade heat trick, I found a large area of what looked to be rust colored primer on the front quarter panel
Itís not. Itís a fine layer of surface rust with some minor pitting.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun Jan 26, 2020 2:26 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Hey Brother of the same name. Life's not over!
Based on what I have seen from the last few posts. Your car looks better than most from the region lately.
Clean up the rust a little and treat it with Ospho. And move on with the repairs.
Good Luck.
flyboy161
PostPosted: Sun Jan 26, 2020 3:04 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Nah, itís all good. I know, itís better off than some. Iím actually pleased with the amount of good metal this car still has.
flyboy161
PostPosted: Mon Feb 10, 2020 4:39 pm    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Itís about to get scary for me😂
Step 1: re-orient the pan under the body the correct direction front to rear
Step 2: receive 2 boxes from Bogota, Columbia
Step 3: open said packages and voilŗ
One heater channel
One A pillar base
And one rear quarter section
Step 4: test fit the heater channel to the pan....
Perfect fit. I mean absolutely perfect. Gerson makes great parts. I mean these things are heavy gauge steel, for sure. Not flimsy in any way shape or form.
Now, the real fun begins...
flyboy161
PostPosted: Sat Apr 25, 2020 8:24 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Kind like watchin paint dry, but this week I got back on it.
Welded in a box frame to hold everything together
Cut out the back 1/2 from the A pillar to the aft bulkhead
This was last weekend. This week...
The front 1/2 was cut out
Just have to clean up the last 1Ē at the front bulkhead.
This lower quarter panel is going to get a lot of attention and so is the front quarter and A pillar.
flyboy161
PostPosted: Wed May 06, 2020 7:36 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Test fit number 2. I really donít like being in a hurry, so I just donít hurry. First test fit was a bust. I had to remover the lower heater muffler, notch the front and rear crossmembers to accept the flanges on the channel and trim 1/4Ē of the rear crossmember so the channel would slide up past it. It was just residual metal from the old channel. So, Gerson makes great channels! This thing fits like a glove. Iím going to leave it up for a few days while I go to work. Then it will come down for cleanup prior to welding. Iíll tack it in place and then Iíll start replacing the rusty areas on the quarter panels and finish weld. I guess the biggest hurdle has just been confidence but by walking away, breathing, contemplating navel lint, etc., I gain a little confidence and whittle away at it.
Itís a tight fit at the rear crossmember.
And at the front
It warms the heart to see metal under the door again
The front quarter panel section pulls in nicely too
The two clamps are just more for peace of mind. I honestly donít think it would fall out at this point, the channel fits that tight.
flyboy161
PostPosted: Fri May 29, 2020 7:58 am    Post subject: Re: 1958 De Luxe Beetle from Morocco Reply with quote
Other priorities, other projects...but, today is the last test fit. It took a little grinding to remove remnants of old defrost hose and old heater channel. Everything lines up and is clamped in place.
They weld the defrost hose to the car Shocked
I did not end up re-using this. VW switched to paper hoses is 1960, so did I
It fits perfectly
Clamped in place! Paint is removed from the areas to be welded and I donít feel like welding today. Gotta get ready for work. Tomorrow? Weíll see Wink
Page 13 of 14
