myvolks1 Samba Member
Joined: February 07, 2011 Posts: 182 Location: Modesto, CA
Posted: Wed Feb 22, 2017 8:28 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
I have seen that type of solenoid before, those are the earlier style.
flyboy161 wrote: |
I ordered some spot weld cutters off Amazon. This morning I had about two hours to kill, so I broke out the wire brush and my air drill and went to work on the right side pan.
This area up front is covered in some kind of epoxy. Some bad pitting corrosion there
Spot welds exposed, I tried out the new cutter. Wow! Piece of cake, just use a good center punch to mark the center before you start cutting.
On a side note, anyone seen a solenoid like this before?
_________________ 1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Thu Oct 26, 2017 10:12 am Post subject: Re: 1958 De Luxe Beetle from Morocco |
A fire has been lit and after an 8 month hiatus, I've started again. Time for more winter therapy.
This week I started reassembling the motor. This is my first 36hp assembly, so it's been a learning curve. As someone stated earlier the rod torquing was a little tricky, but a few well placed hammer taps while applying torque corrected any issues. After cleaning the case and inserting the dowels and number 2 bearing halves, I inserted the distributor drive gear. Checked clearance at .1". Then ensured the cam followers did the free fall thing in each of their slots with no discernible clearance when rotated in their slots.
Installed distributor after disassembling and cleaning. Lubed and reassembled, it's set to the mark on the top of the distributor face.
Crankshaft installed with number one rod at top dead center. Camshaft follows with the "O" lined up between the two timing marks on the cam drive gear. Then I rotated the crank clockwise and counter clockwise to ensure the cam stays put. Cleaned any oily residue off the mating surface and installed the cam plug with sealant, being careful, not to get any on the journals. _________________ My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
Posted: Thu Oct 26, 2017 10:20 am Post subject: Re: 1958 De Luxe Beetle from Morocco |
Next up, mating!
For this sealant is applied to the case right side all the way round and at the case stud flats. Slid the right side down on the left and a couple of light taps to seat it. Paper washers on the six case studs with thick washers over that and torqued the nuts to 7 ft-lbs and then 22 ft-lbs, rotating the crank periodically to ensure the bearings were seated and not binding. Then the installed the two cam plug bolts. And then the remainder of the bolts. The two studs on each side of the number four bearing got paper washers and the 10mm nut by the oil pump. Snugged them all and then torqued the periphery bolts to 15ft- lbs again, checking rotation constantly.
A short block! Woo-hoo!! _________________ My father's 1970 Beetle-
wcfvw69 Samba Purist
Posted: Thu Oct 26, 2017 12:14 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Nice work! Living in Georgia in that heat and humidity, I wouldn't want to be in the garage/workshop during the summer either! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Oct 26, 2017 2:20 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
flyboy161 wrote: |
And it was particularly hot this year, Bill! Thanks. Long time no see! |
Yes, you've been a stranger for sure! Don't feel bad, I can only handle my garage in the Phoenix heat for the first few hours of the morning. After that I'm like "oh hell no".. _________________ Contact me at [email protected]
Posted: Sat Oct 28, 2017 7:47 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Today was long block time. Long day cleaning head studs and running them through a die to clean the threads. Then I was missing one head washer...ugh! Anyway, found a suitable sub and continued with the assembly.
A brand new set of Wolfsburg West pistons and jugs. Must say, a very nice set. Had to set the rings twice due to placing the top side down first and then finding the 1 and 2 cylinder upside down. Finally gave up using my ring compressor and went with the careful finger push method. Got the wrist pins in and the paper gaskets against the case. Gentle tapping with a wood block seated the jugs. The air diverters went in next followed by the copper sealing rings for the combustion chamber. They were a very tight fit and took a little gentle persuasion to get on the jugs.
I was beginning to get a little frustrated with the push rod tubes and once I realized the pushrod and cam follower are installed with them they started cooperating. Heads next with sealant under the lower head stud washers and then torqued the heads.
Posted: Sat Oct 28, 2017 8:01 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Side note for end play. I tried the shims that came out of the engine but they were too thick. I ended up with no end play. So I ordered new shims from WW and expect them Tuesday I hope.
Anyway, per the Bentley manual, and based on measuments, it should take a .24mm, .30mm, and a .32mm to give me .0028" end play. Distance from crank to number 1 bearing is 4.25mm. Depth of the flywheel is 3.17mm. Paper gasket is .15mm. Net difference is .93mm. Take away .86mm and I'm left with .07mm end play or .0028".
I'll double check with a dial indicator when the new shims arrive. Hats off to Gary at Rimco and their crew for line boring the case to .020 and polishing the original crank, matching the bearings, and reconditioning the rods. Everything went together nice and easy!
I found a really awesome article from 1998 VW trends for rebuilding a 36hp and it was invaluable. I'll finish up the motor and then finish the pan. Like to have a rolling, running chassis by December 1st. More to follow... _________________ My father's 1970 Beetle-
mukluk Samba Member
Posted: Sat Oct 28, 2017 8:04 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Looking good, keep it up. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri Nov 03, 2017 1:19 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Wait? You're not done yet?!? _________________ Contact me at [email protected]
Posted: Fri Nov 10, 2017 3:30 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Veterans Day, 2017! A shipment arrived from WW!!
Fuel line grommets, front and rear...
Shift coupling, and still need to safety wire the bolts
Inspection cover gasket and a freshly painted inspection cover.
Axle boots...soooo much easier with the body out of the way!
Cable exit grommet and Bowden tube
And transmission mounts, as well as new washers under the transaxle mount bolts.
Tightened the transmission mounts and front axle beam.
Brakes and wheel bearings next _________________ My father's 1970 Beetle-
