70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Sat Nov 08, 2014 3:00 pm Post subject: 1.9 Water Pump Threaded Blind Hole |
I replaced my water pump on my 1.9. On my old pump I saw this. My new pump was bolted up already when I saw this so I could not check it.
The blind threaded hole,for the front thermostat bolt, broke through into the main pump cavity.
So that means that the coolant pressure gets to the bolt threads.
Also the said bolt length is on the long side on mine. Close to bottoming out in this "blind" hole.
The rear bolt is a through hole.
Just something to check and be aware of. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Sat Nov 08, 2014 6:42 pm Post subject: |
I have a brand new HEPU pump with the same issue _________________ wv2yb0252gg092706 |
rubbachicken Samba Member
Posted: Sun Nov 09, 2014 2:38 am Post subject: |
must be pretty common, i was in the junk yard yesterday, removing a 1.9 T stat housing, it suffered from the same, the bolt was wet, it's easy enough to check, and cut the end off of the bolt if need be _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
