rear end creaking noise
craig78bus
craig78bus is offline
PostPosted: Sun Nov 09, 2014 8:28 am    Post subject: rear end creaking noise Reply with quote
I'm hearing a rear end creaking noise, especially on acceleration, but also other times. Have new shocks, cv boots good. Could it be rear wheel bearings need to be repacked. Can't remember last time they were done
busdaddy
busdaddy is offline
PostPosted: Sun Nov 09, 2014 8:57 am    Post subject: Reply with quote
Does it do it when parked and a couple people jump into the side door or rear hatch depressing the suspension? Torsion housing bushings creak when old and worn.
Слава Україні!
craig78bus
PostPosted: Sun Nov 09, 2014 9:09 am    Post subject: rear end creaking noise Reply with quote
No it doesn't...it's almost a weird gurgling sound when accelerating and sometimes turning corners.
notchboy
notchboy is offline
PostPosted: Sun Nov 09, 2014 9:21 am    Post subject: Reply with quote
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
CrRusty
CrRusty is offline
PostPosted: Tue Jul 20, 2021 10:04 am    Post subject: Re: rear end creaking noise Reply with quote
What was the solution to Notchboys wheel noise?
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jul 20, 2021 11:07 am    Post subject: Re: rear end creaking noise Reply with quote
he caught a family of raccoons in the back who ere taking joy rides. He was hearing the whoo-hoo's every time he went around a corner or braked hard.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
notchboy
notchboy is offline
PostPosted: Tue Jul 20, 2021 8:07 pm    Post subject: Re: rear end creaking noise Reply with quote
After vetting the issue to the fine folks here and other fine venues. The over all peanut gallery consensus that only the internet can provide was varied. There are only a few things to look at - the wheel bearing or the cv joint. But you get all kinds of theories thrown about from the transmission drive shaft to some corny ass racoon/aluminum hat/grassy knoll stuff Laughing But we have fun, right?
In my case it was the wheel bearing. It was shot. Most people had wanted me to do the CV's. I've had bad wheel bearings on my notchbacks plenty. So went for that first.
So that was my answer. It may be yours too? That is until you find a bad CV or a Racoon in your spare wheel well Wink Laughing
https://www.thesamba.com/vw/forum/viewtopic.php?p=6645719#6645719
1964 1500 S
aeromech
aeromech is offline
PostPosted: Tue Jul 20, 2021 8:31 pm    Post subject: Re: rear end creaking noise Reply with quote
Raise your ass end. Grab each rear wheel and shake. Feel any movement? If not, call the Python Cowboy.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
ScreaminJimmy
ScreaminJimmy is offline
PostPosted: Thu Jul 22, 2021 3:35 pm    Post subject: Re: rear end creaking noise Reply with quote
My '79 bus once had the same noise as in Notchboy's video. After blaming CV's, axle nut, etc. it turned out to be a wheel bearing. It really threw me though because I've had wheel bearings go out on other kinds of vehicles and they always produced a low roar at speed. I've never heard a wheel bearing make the "squick-squack" sound except on a bus.
James
56 bug
79 Westy
notchboy
notchboy is offline
PostPosted: Thu Jul 22, 2021 9:14 pm    Post subject: Re: rear end creaking noise Reply with quote
Hey, I finally caught that sum bitch. Wink
1964 1500 S
orwell84
orwell84 is offline
PostPosted: Fri Jul 23, 2021 5:46 am    Post subject: Re: rear end creaking noise Reply with quote
I rescued some baby squirrels from my attic with my pellet gun. The have a heart traps didn’t work.
