Cip1.ca VDM reproduction steering wheel... no longer listed
Z
Z is offline
PostPosted: Fri Feb 06, 2015 12:48 pm    Post subject: Reply with quote
Great video...well done. Can't wait for the next installment. I thought only camper restos combined woodworking with busses!
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Fri Feb 06, 2015 3:36 pm    Post subject: Reply with quote
Z wrote:
Great video... I thought only camper restos combined woodworking with busses!
Thanks. This is not the first bits of wood in my resto.
Now that I have a handle on the bamboo laminating, I may make the middle seat grab bars to match the wheel.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
flemcadiddlehopper
PostPosted: Sun Feb 08, 2015 1:16 am    Post subject: Reply with quote
Here is the next bits being done.
http://youtu.be/t4JfLVQ-nJs
Gordo.
Oldnslow
Oldnslow is offline
PostPosted: Sun Feb 08, 2015 12:03 pm    Post subject: Reply with quote
Gordo.
An old woodworkers trick is to place a couple pieces of wax paper between the pads of the clamps and the work piece so they are not all glued together when dry.
flemcadiddlehopper
PostPosted: Sun Feb 08, 2015 2:10 pm    Post subject: Reply with quote
Gordo.
Good advice, I am using packing tape on the clamps right now. The epoxy seems not to stick to it at all. It may be a bit tougher than wax paper too.
Gordo.
flemcadiddlehopper
PostPosted: Fri Feb 13, 2015 6:50 pm    Post subject: Reply with quote
The two halves of the Steering wheel have had the spoke epoxied into place and are ready to be grooved out for the metal hoop and carbon fibre fitment. So far so good, only one near disaster... The MDF board that the router thickness planer mounts to, met with some steam coming out our dryer vent, which warped it and I had planed the spokes into a lovely swooping non-flat surface. Luckily I had some tolerances and was able to fix the issue and re-plane them flat.
Gordo.
BarryL Premium Member
BarryL is offline
PostPosted: Fri Feb 13, 2015 7:16 pm    Post subject: Reply with quote
You are a master craftsman.
flemcadiddlehopper
PostPosted: Fri Feb 13, 2015 9:25 pm    Post subject: Reply with quote
That ^^^^^^ is like being Knighted from one of the Samba Gods....Thank you so much.
Really I am not, I am just too stupid to know how hard some shit is to do, and I do it 'cus I think I can. Works for me.
Gordo.
flemcadiddlehopper
PostPosted: Mon Feb 16, 2015 8:05 am    Post subject: Reply with quote
I have roughly trimmed some of the excess wood from the spoke flanges and thickness planed (levelled) the internal sides of the wheel halves.
Now I was struggling with how to go about cutting the groove in the wheel to fit the metal and carbon fibre. My router table idea had some draw backs, so I came up with a different plan. I will use the thickness planer and mount the wheel so it can be rotated. (those of you who are Skate pioneers...I took the bearings from from my 1976 skateboards "OJ" wheels for this) I will then solidly mount the router above the wheel so the groove can be cut uniformly into both halves.
Gordo.
BarryL is offline
PostPosted: Mon Feb 16, 2015 10:08 am    Post subject: Reply with quote
That means that not only is your wood a perfect circle so is your metal.
flemcadiddlehopper
PostPosted: Mon Feb 16, 2015 8:19 pm    Post subject: Reply with quote
Here is how it went with the groove cutter.
http://youtu.be/Fg7BaVpxGic
Gordo.
campingbox Premium Member
campingbox is offline
PostPosted: Mon Feb 16, 2015 10:12 pm    Post subject: Reply with quote
Nice work!
Are those Swiss bearings?
Fredrok
Fredrok is offline
PostPosted: Mon Feb 16, 2015 10:13 pm    Post subject: Reply with quote
Gordo.
Amen Gordo, been living by that method on most things my entire life. Still, I'll have to agree with Barry!
Thanks for the WatB turn on.
flemcadiddlehopper
PostPosted: Tue Feb 17, 2015 8:02 am    Post subject: Reply with quote
Thanks guys, it's not turning out too bad...not bad for doing it mostly by braille and how it sounds. Being blind in one eye I don't trust my vision, so I make loads of measurements. The touch tells more, but bamboo slivers really suck.
Gordo.
flemcadiddlehopper
PostPosted: Tue Feb 17, 2015 8:50 pm    Post subject: Reply with quote
I got (for my Birthday) a Flat Four Banjo Wheel Hub adapter. Once the metal hoop is clamped in the Bamboo hoops I can then find the absolute centre of the wheel an mark out where to cut the hole for the Hub.
Gordo.
RPGreg2600
RPGreg2600 is offline
PostPosted: Tue Feb 17, 2015 9:54 pm    Post subject: Reply with quote
Awesome work!
V-Dub Guy
V-Dub Guy is offline
PostPosted: Wed Feb 18, 2015 7:25 pm    Post subject: Reply with quote
When can we place our orders!
flemcadiddlehopper
PostPosted: Fri Feb 20, 2015 6:40 pm    Post subject: Reply with quote
Easy now... Let me finish mine first.
Gordo.
Z
Z is offline
PostPosted: Fri Feb 20, 2015 8:12 pm    Post subject: Reply with quote
Tease...I get excited whenever this thread jumps to the top.
vwtrey
vwtrey is offline
PostPosted: Fri Feb 20, 2015 8:22 pm    Post subject: Reply with quote
Nice work.
Page 3 of 5
