Steering box cover set screws
Who.Me?
Who.Me? is offline
PostPosted: Wed Nov 12, 2014 5:35 am    Post subject: Reply with quote
I used locking washers.
Already got washers on Wink . That'd mean doubling up on them in my case.
you could cut off the excess. That would be a lot easier than adding to them if they were too short. Wink
I reckon I'll go with that. Sometimes the simplest solution escapes me.
Thanks both.
Andy
cru62
cru62 is offline
PostPosted: Tue Nov 11, 2014 5:04 pm    Post subject: Reply with quote
Or. you could cut off the excess. That would be a lot easier than adding to them if they were too short. Wink
If you thread a nut on the shaft, it will serve as a guide. I would use a manual hacksaw for better control and less clean-up of the threads.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Alexmobil
Alexmobil is offline
PostPosted: Tue Nov 11, 2014 4:37 pm    Post subject: Reply with quote
I used locking washers. Very Happy
Who.Me?
Who.Me? is offline
PostPosted: Tue Nov 11, 2014 1:49 pm    Post subject: Steering box cover set screws Reply with quote
Hi
Will it matter if I use a slightly over-length set screw (20mm rather than 18mm) for the steering box bottom cover or will it foul anything inside the box?
One of mine sheared when I was re-torquing the cover. Looked like it had been clouted at some point, which might explain why it sheared. I torqued them to 18 ft lbs.
The original set screws are Kamax 18mm M6 10K (grade 10.9) but I can only find generic 20mm set screws in that grade in small quantities in the UK.
Will the extra 2mm foul anything?
Thanks
Andy
