Oil Bath Mess
Kaput
Kaput is offline
PostPosted: Wed Nov 12, 2014 11:01 pm    Post subject: Oil Bath Mess Reply with quote
I have a 1600 sp engine with an oil bath
There is a pipe that goes by the oil filler that just drips on the tin. Where is this supposed to lead? The PO said it could be plugged up (don't really trust he knew what he was talking about) but it seems like it may supposed to be going through the tin to the ground?? Also there seems to be a hose or 2 missing on the main part of the oil bath. Can anyone shed some light?
I would like to be able to park the bus in my driveway without making a mess.
WestyPop
WestyPop is offline
PostPosted: Wed Nov 12, 2014 11:42 pm    Post subject: Reply with quote
Unless someone has really put way too much oil into the air cleaner, IMO the 'oil mess' is more likely due to engine blowby/crankcase fumes than to any problem with the OG oilbath air cleaner.
And yes, the warm air hose is missing from the the air cleaner assembly's lower intake.
Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others)
Wildthings
Wildthings is offline
PostPosted: Thu Nov 13, 2014 12:09 am    Post subject: Reply with quote
The pipe is your draft tube. It is an alternate route for blowby to get out of your engine. Yes they dump oil under the car, fifty years ago all cars had draft tubes and the roads were an oily mess. People often do make changes to their crankcase ventilation at least partially to get rid of the oil drips. Some systems work well, while others can make your engine even nastier.
The draft tube would have originally had a rubber pinch valve on its lower end.
aeromech
aeromech is offline
PostPosted: Thu Nov 13, 2014 8:04 am    Post subject: Reply with quote
Thank you Busdaddy for the pics
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
67jason
67jason is offline
PostPosted: Thu Nov 13, 2014 8:25 am    Post subject: Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311115541
source for the oil breather rubber valve that goes on the end of the down draft tube.
67 bug x3
67 ghia
64 bug
busdaddy
busdaddy is offline
PostPosted: Thu Nov 13, 2014 8:36 am    Post subject: Reply with quote
It looks as if that draft tube has been shortened, unless you can find a replacement you'll want to add a short piece of tube (clamped on with a rubber hose sleeve perhaps?) so it extends down through the tin. When you get the rubber end boot from WW or whoever check that the end is actually slit open, some are not and don't allow condensation to drain like they should.
BTW the smog hoses on the aircleaner in my pics there are reversed, the oil breather goes on the snout and the canister purge line (if you have one) goes on the filter body.
Kaput
Kaput is offline
PostPosted: Thu Nov 13, 2014 12:47 pm    Post subject: Reply with quote
Thanks Everyone for the info!
Should that air intake hose just go through the tin to take air in or does it need to connect to anything?
Looks like i just need to drill a couple holes in the tin, get some hoses and the boot And I should be fine. Please correct me if I am wrong.
richparker
richparker is offline
PostPosted: Thu Nov 13, 2014 2:01 pm    Post subject: Reply with quote
The hose that comes off the bottom of the air cleaner and goes through the tin should hook to this. This picks up warm air off the heater box.
__________
71 Westy build
Adventure thread
Wildthings
PostPosted: Thu Nov 13, 2014 3:00 pm    Post subject: Reply with quote
You might just look for a rear tin with all the holes you need already cut into it. They are pretty plentiful as every engine came with one. You do need to find the right one for your year though as there were several variants over the years.
bigbore
bigbore is offline
PostPosted: Thu Nov 13, 2014 4:37 pm    Post subject: Reply with quote
It looks like your road draft tube is cut off thats bad you need to fix that. Also having your fuel filter sitting on the carb heat pipe is a sure way to burn the bus to the ground.
where its cold and snowy
Wildthings
PostPosted: Thu Nov 13, 2014 6:39 pm    Post subject: Reply with quote
It also looks to be a DP engine.
Kaput
Kaput is offline
PostPosted: Thu Nov 13, 2014 9:09 pm    Post subject: Reply with quote
Excellent advice, keep it coming! Good eye Wildthings, it is a dual port.
I will definitely move that filter and attach something to extend the road draft tube. Is that a hazard? I suppose the oil on the tin is a fire hazard too.
Is the oil bath intake a hazard as well?
richparker
PostPosted: Thu Nov 13, 2014 9:17 pm    Post subject: Reply with quote
No it is not. Clean it real good and fill it up to the line and it will work great, best air filter you can get.
__________
71 Westy build
Adventure thread
mikedjames
mikedjames is offline
PostPosted: Fri Nov 14, 2014 11:46 am    Post subject: Reply with quote
You could of course just change the oil filler assembly on the end of the alternator / dynamo stand for a more modern alternator oil fillerne that only has the hose going to the oil bath and nothing dropping oil below.
These are common on upright engines here in Europe. My 1973 bay has no pipe hanging down.
https://m.vwheritage.com/productDetails.cfm?iItemID=60775
Ancient vehicles and vessels
1974 VW T2 : Devon Eurovette camper with 1641 DP T1 engine, Progressive carb, full flow oil cooler
Engine 1: 40k miles (rocker shaft clip fell off), Engine 2: 30k miles (rebuild, dropped valve). Engine 3: a JK Preservation Parts "new" engine: 16k miles to date.
