fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Mar 26, 2020 2:04 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
shagginwagon83 wrote: |
I have no problems at all refilling my canisters. I freeze the empty ones 30 mins before I refill them.
(Don't try the following at home, folks...)
I don't even bother with the freezing. I filed down the ends of a large pair of angled needle-nose pliers so that I can grip the relief valve pin. I pull that out while filling the can. I stop when I reckon it's full (you get quite good at this with practice) and check the canister doesn't now weigh more than 29oz (they weigh 13oz when empty). If so, I let a bit out of the relief valve to ensure it's not overfilled. Saved me a fortune when we used to use a Mr Buddy heater. Now the canisters are just used as emergency spares if the main tank becomes empty. I have an extra connector under the sink for this purpose. _________________ Jim Crowther
Vespa GTS 300 |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Thu Mar 26, 2020 1:48 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
I ditched my propane tank. I can still referb it. However I don't mind the 1lb canisters. I hardly cook inside my van anyways.
light weight baby _________________ Brandon
Instagram @joannthevan |
monstersteve Samba Member
Posted: Thu Mar 26, 2020 1:05 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
I don't get why some folks want to try and use the Monster refill adapter to dump multiple 1 lb canisters into the westy tank.
The idea is this device is set up to put in enough propane to keep a camper happy until they get to a gas station, RV place or whatever to fill up the tank with LP. I have gone days using stove and fridge on just what came out of the little green canister before I got to a propane dealer.
First of all, the 1 lb canisters are going to be more expensive than what you should be paying from a propane dealer. Second, the adapter works on propane equalization between the two tanks. At some point you are not going to be able to push any more LP from the canister into your tank, regardless of how hot your Kevlar-suited friend gets his armpit. So, stop trying to refill your tanks from 5 gal, and 1 lb. canisters. Go to the propane dealer where they have big old pressurized tanks than can actually push enough LP into your westy's tank to fill it up all the way. And for Pete's sake, don't be heating your canisters with a blow torch to up the input pressure. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9615 Location: Western WA
Posted: Sun Oct 13, 2019 9:45 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
I use this type, it's only the little adapter, it's $6.70 on Amazon.
https://www.amazon.com/dp/B077SP5BJP/ref=cm_sw_em_r_mt_dp_U_C2.ODbDTHG64Q
These are good to have for re-using "one-time-use" propane cannisters.
Even if the valve leaks the propane can't get out.
$8.45 for qty4 https://www.amazon.com/dp/B07CMFWX7S/ref=cm_sw_em_r_mt_dp_U_k5.ODb3P7WQ0P _________________
....KTMs, GasGas, SPOT mtb |
beach_creature Samba Member
jimf909 Samba Member
Posted: Sun Oct 13, 2019 6:29 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
I repeated this today: emptied two green disposable 1 lb bottles into an empty Westy propane tank with an ACME fill port. The Westy tank was about 55 degrees F and the green bottles were about 75 degrees F. Each green bottle was about 14 ounces after taking about a minute to empty. This is a great solution when propane is needed for the stove or Propex.
jimf909 wrote: |
I've used the 1lb disposable >>> Vanagon tank refill method several times. Yesterday I measured:
- Vanagon propane tank: 51 degrees
- 1lb disposable tank at start of transfer: 74 degrees, 29.4 ounces
- 1lb disposable tank after transfer: 14.0 ounces (did not measure the temp)
This moved about 15.4 ounces from the disposable to the van showing that the method above gets nearly all the propane out of the disposable.
I don't know how long the propex runs on 1lb because I added the propane before the tank was empty because I didn't want to d it in the middle of the night.
[/img] |
_________________ - Jim
Abscate wrote: |
Timwhy Samba Member
msinabottle Samba Member
Posted: Tue Aug 29, 2017 2:37 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Quote: |
AFAIK the kit is not used to refill the westy tank with liquid propane. It is there to use the vapor from the 1lb bottle to run the stove or fridge. |
'Xactly. In fact, you can turn off the tank and my tap-hose-tank will run the stove and fridge, which is quite a comfort.
Abscate Samba Member
Posted: Tue Aug 29, 2017 7:07 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Quote: |
The only experience I have thus far is from refilling 1 lb disposables from a 20 lb tank. |
Just to reiterate for the two posters above who do this.
This is illegal in the US and there is a hefty fine for transporting refilled, 1lb propane containers in a car.
I don't know about Canada, but they are usually ahead of us on safety stuff. _________________ .ssS! |
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Tue Aug 29, 2017 6:09 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
dobryan wrote: |
This particular kit is to get a bit of propane in the on board tank so that you can run the fridge until you can find a propane fill station.
http://www.thesamba.com/vw/classifieds/detail.php?id=1567630
Before I buy the kit, I'm just wondering if what I already have is essentially the same thing as this kit.
Thanks _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Pascal Samba Member
Posted: Tue Aug 29, 2017 3:52 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
So it looks pretty much the same as mine with a different fitting for my POL tank. I tested it yesterday but my 1lb tank was not new and all I could tell is that it filled the hose and nothing went into the Westy tank. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
Timwhy Samba Member
Posted: Mon Aug 28, 2017 7:24 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Pascal wrote: |
I have this adaptor to fill 1lb tanks using a 20 lb tank and a hose from my extend a stay that I have not installed yet. Is this essentially the same as what is being offered for sale? We use our fridge a lot and I like the idea of being able to add propane to the tank to keep the fridge running until we can find a place to refill the on-board tank. I was going to order the kit but I don't want to essentially buy what I already have. Thanks
I have thjis stuff!
[/img][/quote] _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Pascal Samba Member
Posted: Mon Aug 28, 2017 6:34 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
'91 EA Cabby |
Posted: Sun Jan 22, 2017 6:02 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Mellow Yellow 74 wrote: |
Terry Kay wrote: |
Perfoming this transfer by an untrsined, unprofessional, is dangerous, and not at all healthy.
Be sure to have a kevlar suit on while your at it.
Propane should be introduced as a vapor, tank to tank not liquid.
Go for it. |
So propane tanks are filled at hardware stores and gas stations in the US by trained professionals wearing Kevlar suits? |
No, but the propane you get put into a 25# BBQ cylinder is different than the propane sold to you in the green 1# can. One critical difference is the amount of water allowed, so that the green cans don't rust.
That's the reason this
Quote: |
I refill the little green 1 lb disposables from an 20-lb OPD style tank. |
...is a very bad idea, and actually a Federal law violation to transport such a 'refilled green can' - which are single use cans under DOT 39. _________________ .ssS! |
Posted: Sun Jan 22, 2017 4:37 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
[/img] _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Fri Jan 13, 2017 10:39 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Someone wearing a Kevlar suit can be useful. If you can agitate this overdressed person to be physically active for a few minutes then place the donor cylinder into this person's warm armpit the liquid transfer speed will be faster. Don't use a cigarette to agitate this person. While they may run, they may not return with the warm armpits you have organized.
This table shows the pressure that a propane tank (with even one drop of liquid) has at any temperature. Note that if your donor tank is at 80deg, and westy tank is 60 deg, there is (128-92=) 36psi to push liquid from the donor tank to the receiving tank. That's significant. Even with the tiny orifii it can't take more than a few minutes. But just know that as the donor tank empties, it "cools". As the receiving tank fills, it "warms". This is happening at the same time which will reduce the available pressure differential.
Also note that at 130F, any rubber hose that you have in your system will have 250psi. At 130F, the pressure in your disposable cylinder, if it has ONE DROP or (new) full, is 250 psi. If your refrigerator needs propane, you might consider using rubber hoses only in the cool morning (in Death valley for example). Other than that, the pressures are reasonable, not unsafe.
If you allow bubbles (propane gas) to get forced into the westy tank ---- that "wastes" pressure for liquid transfer potential. No biggie, you just have to warm up your donor tank again, or cool your westy tank to regenerate the pressure differential. This is just a reminder to keep in mind where the liquid is (at the bottom) and employ the pressure difference to force it into the receiving tank.
I bought the transfer hose but HAVE NOT yet tried refilling my Westy tank. But this is the rundown how I understand it from (many times) re-filling 1-lb disposable cylinders with a 20lb (5 gallon) propane tank.
The details (as I understand them) restated.
- Donor tank warmer than receiving tank (= more transfer pressure)
- Donor tank inverted (so liquid is at bottom)
- Hose as vertical as possible (maintain a downhill slope to Westy tank).
- Give time for gas (above) to push the liquid out of the hose before disconnect. Warm the hose with your hands. This is to NOT waste the volume of liquid propane in the hose to the atmosphere upon disconnect (and lots safer too).
I bought the hose for connecting the 20-lb (POL) to Westy (ACME) so I can top off my Westy tank from home, but it seems like just carrying two disposable cylinders might be sufficient.
I'd like to hear from a Propex user who has run out, refilled, then how many hours of heat did you get from one cylinder. _________________
Terry Kay Banned
Posted: Fri Jan 13, 2017 9:27 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Yes Sir they are.
And they know what they're doing. _________________ T.K. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Jan 13, 2017 2:22 am Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Terry Kay wrote: |
Go for it. |
So propane tanks are filled at hardware stores and gas stations in the US by trained professionals wearing Kevlar suits? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
shepherdsond Samba Member
Joined: April 25, 2005 Posts: 439 Location: Bellingham, WA
Posted: Thu Jan 12, 2017 10:59 pm Post subject: Re: Propane Tank Refill Adapter (from 1lb bottles) - Review |
Quote: |
Aside from that, it can be done |
Indeed it can _________________ 87 Syncro Hightop Camper
3 knobs + solid shaft
2.2 Phase II Subaru
Hi-Top build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534517 |
