type 3 carb linkage
finegan
finegan is offline
PostPosted: Mon Nov 24, 2014 1:20 pm    Post subject: type 3 carb linkage Reply with quote
I have a type 3 motor with dual solex carbs. The ball joint rods that go from the linkage to the throttle body are worn. Where can I get a replacement? Is there a way to fix them. Can I fill the socket with something and try to re-fit? Any help would be great. Thanks
W1K1
W1K1 is offline
PostPosted: Mon Nov 24, 2014 1:44 pm    Post subject: Reply with quote
http://www.vwispwest.com/341129898K.html
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
grandpa pete
grandpa pete is offline
PostPosted: Mon Nov 24, 2014 2:32 pm    Post subject: Reply with quote
And where do I find the piece that connects to the accelerator cable
PLEASE Smile
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Mon Nov 24, 2014 4:22 pm    Post subject: Reply with quote
the barrel nut? gosh you can get those anywhere , even home depot has em
Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
MaximumFinishes
MaximumFinishes is offline
PostPosted: Mon Nov 24, 2014 7:53 pm    Post subject: Reply with quote
PLEASE Smile
Do you mean this piece?
'64 Type 3 "Noback" - Frank
'68 Squareback - Charlie
'73 Westy - Mac
'98 Honda CR-V - Dee
'97 Subaru Impreza Outback - Dennis
Bobnotch
Bobnotch is offline
PostPosted: Tue Nov 25, 2014 5:13 am    Post subject: Reply with quote
MaximumFinishes wrote:
PLEASE Smile
Note; not all dual Solex carb set ups used that linkage. My 65 Notch only uses a barrel nut and a longer (dual carb) throttle cable. My 64 T-34 did however use that style link.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ataraxia
ataraxia is offline
PostPosted: Tue Nov 25, 2014 7:26 am    Post subject: Reply with quote
PLEASE Smile
EDIT: This assembly ended 2/65 and was replaced by a longer accelerator cable 3/65.
The linkage piece, btw, is the same as the short linkage on the PDSIT carbs.
finegan
finegan is offline
PostPosted: Tue Nov 25, 2014 8:34 am    Post subject: Reply with quote
Thank You but that is not it. The piece is about 4 inches long and has a ball socket on each end. It goes from the long linkage rod to the carb. There is one on each carb.. Thank You ,Tom
Erik G
Erik G is offline
PostPosted: Tue Nov 25, 2014 8:36 am    Post subject: Reply with quote
this one? http://www.vwispwest.com/341129883B.html?page=1
Everybody else was responding to the thread jacker. Sorry
finegan
finegan is offline
PostPosted: Tue Nov 25, 2014 8:53 am    Post subject: linkage Reply with quote
Thank You! I have ordered it.
PostPosted: Tue Nov 25, 2014 9:12 am    Post subject: Reply with quote
PLEASE Smile
This assembly ended in 64 and was replaced by a longer accelerator cable in 65.
To confirm, this makes the ball socket center pivot piece I am selling here 64 only, correct?
http://www.thesamba.com/vw/classifieds/detail.php?id=1691088
ataraxia
ataraxia is offline
PostPosted: Tue Nov 25, 2014 10:18 am    Post subject: Reply with quote
The Samba online parts book is missing the dual carb section but I was able to find that the shorter accelerator cable (311 721 555) ended 2/65-which would also end the 3 ball pivot tower and the linkage pieces.
Not quite 64 only as they made it into 65 models as well. My 65 N was made after this date so it has the later pivot tower.
PostPosted: Tue Nov 25, 2014 4:31 pm    Post subject: Reply with quote
Thanks, I updated my ad with RARE 64-65 ONLY and tripled the price.
(Just kidding)
ataraxia
ataraxia is offline
PostPosted: Tue Nov 25, 2014 4:43 pm    Post subject: Reply with quote
(Just kidding)
Just found out that my parts book has the pictures but the page with the part numbers is missing! Evil or Very Mad
PostPosted: Tue Nov 25, 2014 5:31 pm    Post subject: Reply with quote
(Just kidding)
Maybe you can print them out from
http://www.thesamba.com/vw/archives/manuals/type3_parts_book/
ataraxia
ataraxia is offline
PostPosted: Tue Nov 25, 2014 5:38 pm    Post subject: Reply with quote
(Just kidding)
The version on the site is missing the whole dual carb section. My book has the page with the diagram but no listing by part #.
NoBudgetVWGarage
NoBudgetVWGarage is offline
PostPosted: Fri Jun 18, 2021 9:12 am    Post subject: Re: type 3 carb linkage Reply with quote
Any new options for stock carbs yet? Working on a buddy's squareback and one of his linkages is made of a coat hanger!! no sh!t!!
On the waitlist for the linkage kit from ISP but wondering if there is a better option yet.
1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car
Erik G
Erik G is offline
PostPosted: Fri Jun 18, 2021 9:43 am    Post subject: Re: type 3 carb linkage Reply with quote
nope, just used.
https://www.thesamba.com/vw/classifieds/search.php...ds=linkage
Jason37
Jason37 is offline
PostPosted: Fri Jun 18, 2021 10:00 am    Post subject: Re: type 3 carb linkage Reply with quote
Look up Type3Army on IG, or I think he goes by Critter1 on here. He is making replacement arms.
Bobnotch
Bobnotch is offline
PostPosted: Fri Jun 18, 2021 10:25 am    Post subject: Re: type 3 carb linkage Reply with quote
Someone on here made up a set of long rods using heim joints. That might be an option.
Tram wrote:
Tram wrote:
