What is this - Oil pan extension?
steveoutlaw
steveoutlaw is offline
PostPosted: Sat Nov 22, 2014 10:50 am    Post subject: What is this - Oil pan extension? Reply with quote
Is this normal or is it some kind of oil pan extension? It looks to be hanging awfully low.
Woreign
Woreign is offline
PostPosted: Sat Nov 22, 2014 11:00 am    Post subject: Reply with quote
It's an after-market deep sump. Adds more oil for the engine to use and some even have additional filtration.
steveoutlaw
PostPosted: Sat Nov 22, 2014 11:16 am    Post subject: Reply with quote
Ok, now the for the money round.........should I keep it or get rid of it?
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Nov 22, 2014 1:01 pm    Post subject: Reply with quote
Get rid of it , and while you are under there get the rest of your engine tin in place.
In Stereo, Where Available!
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 22, 2014 1:20 pm    Post subject: Reply with quote
After you remove it, buy these http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113198031SI
As you see on your car, ALL the paper drain plate gaskets leak. I tried them all. I greased them, sealed them and they still leaked. I have these on my VW's now and no leaks at all.
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
steveoutlaw
PostPosted: Sat Nov 22, 2014 2:33 pm    Post subject: Reply with quote
Gotcha. I already ordered the gaskets and a new strainer for the oil pan. But what do you mean by getting the rest of my engine tin in place? I'm a newbie here so I can use all of the advice I can get.
Thanks.
-Zodiac-
-Zodiac- is offline
PostPosted: Sat Nov 22, 2014 2:46 pm    Post subject: Reply with quote
Engine tin is an essential part of the cooling system.
Use this site http://www.vw-resource.com/engine_tin.html always good info
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
steveoutlaw
PostPosted: Sat Nov 22, 2014 3:15 pm    Post subject: Reply with quote
Ok, so now another big question.........how do I know what tin is missing? That page is good info, but I can't tell what I'm supposed to have underneath so I can know what is missing.
Thanks,
-Zodiac-
-Zodiac- is offline
PostPosted: Sat Nov 22, 2014 3:41 pm    Post subject: Reply with quote
I can't really tell, I would imagine your sled tin/ j tube tin. Someone correct me if I'm wrong?
Here's another good picture of the tin.
Eric&Barb
PostPosted: Sat Nov 22, 2014 3:43 pm    Post subject: Reply with quote
Since we do not know what mismash of tin you have or do not have, it would help to post good detailed images of engine in question.
Missing #7 lower right rear sled tin.
steveoutlaw
PostPosted: Sat Nov 22, 2014 4:16 pm    Post subject: Reply with quote
Ok. I plan on putting it up on jack stands tomorrow so I'll get detailed pics of the underside of the engine and the topside as well.
Abscate Premium Member
Abscate is offline
PostPosted: Sun Nov 23, 2014 2:09 pm    Post subject: Reply with quote
And lower left #6 too?
Those two tabs you see poking inwards from your heat exchanger box ( big tubular looking thing) should be screwed together into the missing tin.
The tin directs the airflow around the motor and stops it from melting. It's important, yet deceptively simple looking.
.ssS!
c21darrel
c21darrel is offline
PostPosted: Mon Nov 24, 2014 12:01 pm    Post subject: Reply with quote
E&B, whats wrong with an extra 1.5 qts of oil?
GhiaBuild
NOVA Airhead
NOVA Airhead is offline
PostPosted: Mon Nov 24, 2014 12:49 pm    Post subject: Reply with quote
You likely will need #5 as well. It often goes missing. There are two of them. One for each side.
Ghia Owner Emeritus
Max Welton
Max Welton is offline
PostPosted: Mon Nov 24, 2014 3:37 pm    Post subject: Reply with quote
Filtration, Gracey? Nope.
Nothing at all. And it may be there for a reason. But he didn't tell us anything about his engine.
Take everything you read here (or anywhere on the internet) as potentially incorrect.
Max
iowegian
Samba Curmudgeon
iowegian is offline
PostPosted: Mon Nov 24, 2014 4:29 pm    Post subject: Reply with quote
Max
Now THAT is a correct statement.
Max Welton
PostPosted: Mon Nov 24, 2014 4:34 pm    Post subject: Reply with quote
iowegian wrote:
Max
Maybe you meant "cooling"? Laughing
Max
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Nov 25, 2014 1:33 am    Post subject: Reply with quote
Max Welton wrote:
iowegian wrote:
Max
Max
We won't get into the contentious issue of whether adding an extra 1.5 quarts of oil will aid cooling or just add to the time the oil will get to its normal running temperature. Be that running hot or running at a normal temperature. Wink
John.
My 1958 Karmann Ghia
steveoutlaw
PostPosted: Tue Nov 25, 2014 7:10 am    Post subject: Reply with quote
I got called out of town but will be back in town tomorrow. I'm planning on putting the car up on jacks and getting some detailed pictures of the engine top to bottom. That should spark some debate! Very Happy
Seroiusly, I'm hoping that you guys can help me figure out just exactly what cooling tin is missing.
thanks,
Steve
Max Welton
PostPosted: Tue Nov 25, 2014 7:33 pm    Post subject: Reply with quote
From the one picture you've shown, you are missing the right-side "sled" (#2 from the diagram).
Show us more.
Max
