DeathBySnuSnu Samba Member
Posted: Tue Nov 25, 2014 4:27 pm Post subject: Lightened Flywheels |
I have had my 2110 (82 x 90.5) engine since 1981.
It is all Claudes Buggies parts.
The flywheel was the lightened unit right out of the catalog.
Now I am rebuilding. The flywheel pin holes are loose, it has had a hard life.
Got a new flywheel, simple enough right?
Then I notice the new flywheel is different, heavy feeling.
So I weigh the old and new.
Old CB flywheel 9lbs.
New CB flywheel 13 lbs.
Called CB and they never heard of a 9lb flywheel and also tell me the 12.5 to 13lb is a lightened flywheel these days.
So how is this going to effect my engine? Or effect my cam choice?
Anyone been there and done that?
My vehicle is
850lbs
3.44 r&p
Now a 2286cc
Street driven
Fuel injected
Distributerless
Type 1 VW |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Nov 25, 2014 4:48 pm Post subject: |
My opinion is u should run the 13lb flywheel. 9lbs is way too light. It wont affect cam choice but it wont be such a rascal on the street like before. Im sure youve gotten used to it through the years, but I would definitely switch. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Tue Nov 25, 2014 6:19 pm Post subject: |
I run a stock weight flywheel on my drag cars.
13lbs is plenty light enough for some spirited street action. The difference really isn't that much IMHO. When I switched while my drag car was still asperated, I noticed nothing, and that was a 10.5lb flywheel. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
jsturtlebuggy Samba Member
Posted: Tue Nov 25, 2014 7:02 pm Post subject: |
One reason they stopped making the flywheels that light (I had a 8 1/2lb SCAT) is that removes material from the opposite side of where the clutch disc is. This removes some of the heat sink. Can cause clutch slippage. Also flywheel can be bent when trying to remove it.
Does your flywheel have bluing on the outside surface of the clutch disc? _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Tue Nov 25, 2014 7:27 pm Post subject: |
Well I do have to admit it has been so long I can not remember having any other flywheel.
The dowel pin holes are loose and it will not be used again.
The heavy wheel is going on.
Think about this... i am light 850lbs.
No bluing or surface problems with it ever. |
modok Samba Member
Posted: Tue Nov 25, 2014 7:29 pm Post subject: |
The mass at the outer diameter matters MUCH more than nearer the center.
A 13 pound flywheel can rev faster than a 9 LB one, if they take all the weight out of the very edge instead of behind the clutch! |
Posted: Tue Nov 25, 2014 7:34 pm Post subject: |
It is apart right now.
Here it is with carbs.
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Wed Nov 26, 2014 5:42 am Post subject: |
If the flywheel is otherwise in good condition, have the crank and flywheel pin holes reamed to the next size larger. 8mm to 11/32". _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Wed Nov 26, 2014 6:50 am Post subject: |
That trike can take the lightest flywheel you want , you don't need much flywheel to get tht going ... that's why it problably had the 9lb on it.. _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Posted: Wed Nov 26, 2014 7:36 am Post subject: |
I did not design it specifically at 9 lbs.
I just bought the lightened wheel out of the CB catalog.
The engine was originally in my 66 Sedan with this wheel.
The motorcycle was my 85 Gold Wing.
One day a long time ago I looked at them and said, I aught to put that big boxer where that little boxer is".
So this is what happened. It has been fun.
I have gotten a new crank and flywheel. Maybe I will cut some more weight off the wheel before it goes out to balance. I am still collecting parts. I want to get it back together for next summer. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Wed Nov 26, 2014 7:49 am Post subject: |
X2. Have the old crank and flywheel upsized to 11/32 dowells and rebuild. It's the standard fix for loose pins. And when you rebuild, use a chromoly gladnut and torque to 400 ft/lbs. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Wed Nov 26, 2014 8:46 am Post subject: |
There were some aluminum/steel flywheels available years ago.
Maybe that's what CB sold you back then. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Wed Nov 26, 2014 11:50 am Post subject: Re: Lightened Flywheels |
Do you have a picture of the crank and flywheel? I agree they can be saved by reaming to 11/32 and using the 11/32 dowels. Not a huge deal for a good crank guy (DPR). Certainly less $ than buying a new crank and flywheel. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed Nov 26, 2014 12:31 pm Post subject: |
Lol. People. He already has the new flywheel in hand. If the crank specs out and crank dowels are not out of round or doesnt spec out, put the new flywheel on! I torque between 380 to 400. New chromolly gland nut should be bought. Or am I interpreting this wrongly? _________________ 2276 IDA's 86C 11-1 DD !
mark tucker Samba Member
Posted: Wed Nov 26, 2014 1:01 pm Post subject: |
I think fats has the right idea. execpt I go a bit more than the 400 twerking thers that danged spellen again,kaint seem to get it wright. I seriously doubt you will find any negitive affects from the 13# flyingwheels over the one you had.dont worry be happy, be sure to reset the end play too!!!good luck and getter done. |
Posted: Wed Nov 26, 2014 2:09 pm Post subject: |
Thank Guys.
I do have a new crank and flywheel in hand.
The scooter is all apart, not just the engine.
The flywheel had almost come totally loose. It only took (guessing) around 100 to 120 lb/ft to get the gland loose. It has worked the eight dowel holes out of round. It was getting tired, starting to blow by more and more.
It is now becoming 86mm x thick92mm 2286cc. I have all the major parts except the thick wall VW9200T1KSF from aircoolednet.
If I can get some time this holiday I am going to finish the Mega Squirt.
Going to be fuel injected and distributer less.
Mikuni Throttle bodies.
Posted: Wed Nov 26, 2014 2:14 pm Post subject: |
sweet, what heads are those?? be sure to torque the shit out of that gland bolt. deburr the bolt flats& points so they dont grab/bite/gauld the washer, and I use moly lube on the threads and the washer when I torque it 400+ |
Posted: Wed Nov 26, 2014 2:45 pm Post subject: |
That's Roy's 050 heads with some minor work making them look more like a cb mini wedge port and good single springs and keepers.
Really like the extra cooling fins. I don't run a fan.
With more displacement under them I am going to have to increase chamber size.
Still trying to pick a cam. I have always run a 2246 in the scooter.
Emailed Pat and the most he suggested was a 2288 and more spring. Mainly because of my lack of having a true merged header.
I pretty much take his word as law......
So studying how I could get the exhaust right. |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Nov 28, 2014 7:39 pm Post subject: |
Don't waNna derail this thread but 400ft/lbs????
I'm putting together a stock 1600dp and thought it was like 230ft/lbs.....should I be doing 400ft/lbs too??? Wouldn't that affect end play as well? Should I get a cromo gland nut too?
Have a huge cart at cb and I can add it before Sunday if need be. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Fri Nov 28, 2014 7:44 pm Post subject: |
'67 Sunroof wrote: |
Stock 1600 doesn't need more than stock torque.
Hi-po does. _________________ Glenn
Member #1009
#BlueSquare |
