Hustlers67 Samba Member
Joined: September 21, 2011 Posts: 263 Location: Sydney, Australia
Posted: Thu Jan 08, 2015 4:49 pm Post subject: |
76 it is!! |
Posted: Thu Jan 08, 2015 9:35 pm Post subject: |
Next question. What are the best rods to give me the least hassle, using the A pistons and a 76mm crank?
5.325 H Beam? Any brand recommendations? Best bolts? |
Danwvw Samba Member
Posted: Fri Jan 09, 2015 11:41 am Post subject: |
Do you already have the A Pistons & Cylinders?
The short rods 5.325" rods work with the 74mm crank and A pistons but with a 76mm crank your going to need the B pistons or a lot of shim (about .100") under the cylinders and longer push rods even with the short 5.325" rods your engine will be a little wider too. That's why I used the 74mm crank. Didn't want to mess with the push rod length and wanted to run the A pistons.
John explains it here just below the picture of the rod in the case: http://www.aircooled.net/1800cc-vw-engine-no-machine-combo/
As far as rod bolts the CB Performance 3.325" 5.325" H-Beam racing rods and the AA Performance 3.325" 5.325" I-Beam come with their own ARP Style bolts as shown in the photo in Johns article above. But the I-Beam rods have a larger bolt that won't clear the case as well as the H-Beam ones which came with the 3/8" Rod Bolts. I'm not sure I trust the Rod bolts that came from China with the AA-Performance 5.325" I-Beams! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Posted: Fri Jan 09, 2015 4:00 pm Post subject: |
Danwvw wrote: |
As far as rod bolts the CB Performance 3.325" H-Beam racing rods and the AA Performance 3.325" I-Beam come with their own ARP Style bolts as shown in the photo in Johns article above. But the I-Beam rods have a larger bolt that won't clear the case as well as the H-Beam ones which came with the 3/8" Rod Bolts. I'm not sure I trust the Rod bolts that came from China with the AA-Performance 5.325" I-Beams! |
Hi Dan, yep already have the "a" P&Cs.
Modok and John have given some good info on the wideness issues. Which I am pretty comfortable with.
I am leaning towards the H beams. Just wondering more if there is much difference between manufacturers?
Here is a little pic of the car:
deadkombi Samba Member
Joined: February 10, 2011 Posts: 112 Location: Perth Western Australia
Posted: Fri Jan 09, 2015 10:56 pm Post subject: |
Go the CB performance H beams. They finish hone them and have proved good for me. |
Danwvw Samba Member
Posted: Sat Jan 10, 2015 8:30 pm Post subject: |
I used the H beams from Air cooled Net on my last rebuild they were the CB-Performance H beams. Had them check for balance end to end and total but they did not need anything. They are a very nice rod.
On the engine I am building now I ordered the $139 Chinese manufactured AA-Performance I beams for it. Just got them out last night and started looking them over and they need some de-burring and from the looks of them they will need considerable work to balance. Wish I had another set of H-Beams instead! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
modok Samba Member
Posted: Sat Jan 10, 2015 11:39 pm Post subject: |
WORD. Try a pin in those I-beams. I had to hone the small ends. and the bolts seemed to be 12.5mm. |
Posted: Wed Feb 04, 2015 5:39 pm Post subject: |
So it looks like the title to this thread may change.. It may be becoming apparent I am not in this with a particular dream spec engine. I am in it for the challenge, the experience and learning, plus I enjoy parts hunting... and as luck would have it, I got a sweet deal on some CB 044 heads (40x35, dual springs) and a 78.8 c/w crank (which according to some of you appears to be forged and worth a go). Interesting twist is, the heads are cut for 94s ... so looks like all I need is some bigger carbs and I have bits that better match the cam. Trick now is making it all work...
Modok, you say 92s clear a 78 crank.
modok wrote: |
92 A mahle pistons will clear a DPR raceweight 78 stroke crank with 5.3 length rods. I checked that last time the question came up...
What about a 78.8 crank?
Reason I ask is I have some 92a mahle p&cs I could use. (They are thin walls though). Or, I trade my 90.5a p&cs and 92a p&cs and arrange either some 92 thick walls (and use the copper wire trick - see earlier post by Dan Ruddock) or 94s.
I haven't got the case cut or clearanced yet. I now have good heads cut for 94s. I figure the piston skirt clearance issues will be minimal with 94s (if there are any clearance issues at all).
I think I go 94 [edit] B p&cs, in which case the build will look more like:
As41 case
78.8 c/w forged crank
94b p&cs
Cb 044 (40x35) dual springs
Webcam 163+6 (I've still got it)
1.25:1 rockers
5.5 rods ( do they need to be h-beam now?)
Probably DRLA 40s or IDF 44s (depends on what I find)
Of course: measure.measure.check.assemble.measure.measure.check.assemble etc.etc. I am just trying to get closer to having the right parts for a balanced combo.
I appreciate any thoughts or feedback.
modok Samba Member
Posted: Wed Feb 04, 2015 5:55 pm Post subject: |
my 5.3" rod is .025 thou shorter than any currently made, and your crank pulls the piston only .015 more, so actually you'd have MORE clearance.
You CAN use A pistons at 78.8 stroke, but no more. I would be best to use .060 copper "head gaskets" to allow you to run the piston all the way to the top. Short rods will help keep the engine as narrow as it can be.
I would not want to do this with thinwall cylinders!
AA thickwall cylinders are available to fit "94" or "90.5/92" case size, but use 94 size heads. I think you should get the cylinders in hand and measured before deciding what rods to buy, |
Posted: Wed Feb 04, 2015 6:39 pm Post subject: |
of course.. the 92 thickwalls are the same size as the 94s eh, so no copper wire trick needed. |
Posted: Wed Feb 04, 2015 6:44 pm Post subject: |
I should have said 94 B p&cs.
As if I have to get a new set of p&cs it will be the stroker ones. That should fix up the rod selection issue. |
modok Samba Member
Posted: Wed Feb 04, 2015 6:48 pm Post subject: |
yep, but with all the options I don't know if you'll want 5.325, 5.4 or 5.5
92b mahle pistons in AA cylinders is kinda cool too. good 92b pistons are actually the most common size to find good used.
I do not know if this is because they lose ring seal so fast or because the guys that DO want to build a thinwall stroker just tend to build time bombs anyhow. |
Posted: Thu Feb 05, 2015 12:44 pm Post subject: |
Thanks modok that's good to know. And no, not planning on building a time bomb, which is why I'm fleshing it all out here before I get too deep.
I couldn't find a build sheet, or thread that has 94b x 78.8.
'B' pistons will make the assembly and width issues a whole lot easier (when compared to the fiddle with short rods and 'a' pistons), right?
I'd like to keep it as close to stock width as possible.
GTV Samba Member
Posted: Thu Feb 05, 2015 1:36 pm Post subject: |
2187cc, cool. Closest to stock width will be 5.4" rods. 5.5's will also work and only make the engine ever so slightly wider (once you account for proper deck height), but when given the choice I prefer short rods and slightly narrower over slightly wider. Pin heights between AA's and Cima's are also 1mm different, so you'll have to account for that as well. _________________ EMPI Power Rules! |
Posted: Thu Feb 05, 2015 4:06 pm Post subject: |
92B pistons are fine, it's the 92B cylinders that were a problem (THIN WALL). So it is an option to buy a set of used pistons, and then buy some new thickwall cylinders to complete the package on the cheap.
http://vwparts.aircooled.net/AA-92mm-Cylinders-THICK-WALL-94mm-Head-92mm-Case-p/vw9200t1kl.htm
modok wrote: |
92b mahle pistons in AA cylinders is kinda cool too. good 92b pistons are actually the most common size to find good used. |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Feb 05, 2015 9:59 pm Post subject: |
Thanks for clarifying that John, that makes sense.
GTV, yep 2187 - an unusual number, its a long way from 1904.. I think slightly narrower would be better too.
Lots of measuring to do! |
Posted: Wed Feb 25, 2015 2:49 pm Post subject: |
I am on the hunt for Carbies:
With this set up (2187cc) - I am looking out for:
- Weber IDF 44s
- Dellorto DRLA 40s
- Dellorto DRLA 45s
I know jetting is the variable - but I just want to get the best base unit. I also understand the jet access benefits on the DRLAs (over the IDFs).
Would the DRLA 40s be too small? |
Posted: Wed Feb 25, 2015 3:10 pm Post subject: |
IMO 45s are a bit too big. The 44 IDFs or 40 DRLAs will work very well. _________________ It's just advice, do whatever you want with it!
modok Samba Member
Posted: Wed Feb 25, 2015 5:44 pm Post subject: |
40 DRLA are about perfect for conservatively ported 40mm intake valve heads. |
Posted: Tue Mar 17, 2015 3:29 pm Post subject: |
Hi Again,
I should probably change the name/title of this thread to "2187 guidance please" any ideas how to do this?
Anyway - I got some Dellorto DRLA 40's. They are in good condition and appear to be straight off an Alfa Romeo?? The Jetting is:
Vents: 32
Air: 180
Main: 142
Idle: 52
From my search of comparative setups - this doesnt appear too far off the mark?? Maybe a bigger idle jet is needed?
I will need a filter set up and a linkage. Are velocity stacks essential?
I am not sure what if any modifications will be needed to make them work for a VW - I have seen Jet Dr's and other things referred to and will need to research them. I plan on getting the Dellorto Superformance book and doing some reading. Any other suggestions?
I am also conscious that untested carbs are not a wise move for engine break in... but TBH I am a long way from there!
Slowly slowly
