EDSEL Samba Member
Joined: February 05, 2010 Posts: 10 Location: United States
Posted: Sun Nov 30, 2014 2:29 pm Post subject: 1973 camper with 3TC |
I have a 73 camper that I put a 81 3TC into I have the radiator up top. Travel between chattanooga,tn and Maine never had a problem had to leave the thermostat out slowed the flow. Doesn't over heat. Going to put a high performance water pump in it. I left the Toyota crossmember and mounts on the motor then connected that to the mustache that I cut down. Worked perfectly. Rebuilt the motor before I put it in should of used a different trans had to put 16 rims on to lower the RPMs. 65 @3200rpms. Made a mount for the alternator so I could keep the vw one. Don't like wiring. The radiator is in a box that looks like luggage on top. _________________ STEPHEN |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sat Jan 25, 2020 12:48 pm Post subject: Re: 1973 camper with 3TC |
lets see a pic of the luggage/rad!
also, does that motor poke into the cabin? |
EDSEL Samba Member
Posted: Sat Jan 23, 2021 8:36 pm Post subject: Re: 1973 camper with 3TC |
EDSEL Samba Member
Posted: Wed Mar 09, 2022 6:45 am Post subject: Re: 1973 camper with 3TC |
I put a freeway flyer transmission in it works great. If I didn’t want to use it for long distance travel I might of made it electric. I’m lucky it came from Arizona so has no rust. I put the regular tires back on and the RPMs are great. I used rusty bottom outside of Nashville for the transmission great place! Don’t know how long I’ll keep it or what it’s worth it would be easy to convert back to vw power but then I think a Toyota motor is a vast improvement. _________________ STEPHEN |
