jimf909 Samba Member
Posted: Sun Jul 05, 2020 10:46 am Post subject: Re: Grille restoration / refinishing |
After adding the super-shiny Jetta badge to my freshly painted grill I sprayed the worn old badge with Krylon paint and reinstalled it. I can't say that I prefer one over the other. I'll drive around with the black one for a while.
Was...
Is (need to clean off the bugs)...
_________________ - Jim
Abscate wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun Jul 05, 2020 11:26 am Post subject: Re: Grille restoration / refinishing |
Ahwahnee wrote: |
...I am now replacing the grille with the usual repro and wondering whether to paint or use the foil and if paint - how much to cover. |
Grille is now trimmed in metallic tape (about ¼" wide used instead of original paint.
Upper is new from Bus Depot, lower is original in Krylon. |
Posted: Sun Jul 05, 2020 5:25 pm Post subject: Re: Grille restoration / refinishing |
I'm going back and forth between all black or with a chrome badge and trim ring. Every time I see one with a nice silver trim ring I'm impressed by how good it looks. _________________ - Jim
Abscate wrote: |
Yellow Rabbit Samba Member
Posted: Wed Sep 02, 2020 8:43 pm Post subject: Re: Grille restoration / refinishing |
I finally got around to restoring my grill. Mine is the early style with the painted rim. It took a while to figure out the right color. Eventually I remembered about 15 years ago I painted my stock hubcaps with this paint. It was a good match and it held up very nicely. I assumed VW probably used the same or similar color on the grill. In the end it’s a very close match. It has slightly more metal flake, but it’s a great match to my Gowesty wheels.
Before:
During:
After:
I’m thrilled with the result. I should have done this years ago. |
sphet Samba Member
Joined: November 09, 2016 Posts: 345 Location: Vancouver, BC
Posted: Thu Sep 03, 2020 6:48 am Post subject: Re: Grille restoration / refinishing |
Yellow Rabbit wrote: |
Looks great! Did you spray black the rest of the grill first? Or was it in decent shape already? Mine’s not OE but is pretty faded. _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Posted: Thu Sep 03, 2020 10:31 am Post subject: Re: Grille restoration / refinishing |
I did not have to repaint the black part but I don’t see why you couldn’t if yours is faded. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Thu Sep 03, 2020 10:34 am Post subject: Re: Grille restoration / refinishing |
What kind of prep work did you do? Some sanding, or just cleaning and degreasing? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Thu Sep 03, 2020 10:56 am Post subject: Re: Grille restoration / refinishing |
I lightly scuffed it with a Scotchbrite pad and cleaned it well. The masking is tedious but the entire project only took a couple hours from removal to installation. That paint dries in 30 minutes. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Sep 03, 2020 1:56 pm Post subject: Re: Grille restoration / refinishing |
And it looks great! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
VicVan Samba Member
Posted: Thu Sep 03, 2020 2:00 pm Post subject: Re: Grille restoration / refinishing |
I concur! thanks for the tips. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
tjet Samba Member
Posted: Thu Sep 03, 2020 3:42 pm Post subject: Re: Grille restoration / refinishing |
Those headlights look cool. What brand/type are they?
Posted: Thu Sep 03, 2020 5:33 pm Post subject: Re: Grille restoration / refinishing |
tjet wrote: |
Those headlights look cool. What brand/type are they? |
GE Nighthawk LEDs. They are rebranded Trucklites with a chrome stripe added.
I got a chance to check out my grill work in the daylight today. I really like the paint choice. It has just the right amount or gloss/matte to look factory. |
Posted: Mon Jun 14, 2021 2:33 pm Post subject: Re: Grille restoration / refinishing |
I’m happy to report the Rustoleum wheel paint trim on my grille still looks 100% stock and factory new. I highly recommend this for early grilles. |
WestiT3_1986 Samba Member
Posted: Tue Jun 15, 2021 12:21 am Post subject: Re: Grille restoration / refinishing |
Ahwahnee wrote: |
Ahwahnee wrote: |
How did you get the round edges made- could you stretch the tape?
Do you have some closer pictures?
Thanks! |
