kamzcab86 Samba Moderator
Posted: Tue Dec 09, 2014 10:54 pm Post subject: |
Nice job, Doug. Looks good!
IdahoDoug wrote: |
One comment on doing the chrome tape. I was surprised how many little gravel divots mine had, which would make for a distorted surface on chrome tape you could easily see. These chips might also make it difficult to get good adhesion because some are right on the edge where the paint just flowed and filled them, but tape would be like a bridge over them where water will wick behind the film. |
Mine doesn't have many, if any, chips; one other reason for trying the tape. I'd go the paint/silver leafing route (as I did with the rear badges), but a shiny new, modern (Jetta IV) chrome emblem in my grille just desires shiny chrome trim:
_________________ ~Kamz
2016 Golf GTI S
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Wed Dec 10, 2014 10:12 am Post subject: |
Dave,
Yeah, I'm sure a protective coating would help durability but it was so laughably simple I would have absolutely no problem redoing it every other summer or so. For $9 and 20 minutes of my time the messing about might not be worth it to add a clearcoat in addition. To cover it with an outdoor clearcoat I think would require spraying it on, masking it off, etc.
It was so spontaneous, I was putting the dishes away and not feeling so hot - minor cold or something. Then I remembered the leafing pen, texted my wife at a school board meeting to find out where I put it (married guys will know this). Grabbed the grille, wiped it with a rag in the garage already damp from window cleaning and laid it across the kitchen table. Went to town. The chisel felt tip and raised edge made it easy to get a nice edge. Even if the tip hung over the edge, it doesn't run down the side as it kinda needs to be drawn out by sliding. So I literally have zero runs down the side, etc. Perfect tool for the job.
For durability, the #1 wear will be weathering vs abrasion, which is best duplicated by putting a sample out in the weather. So I'll put a sample outside and leave it facing up to the sun and rain, etc - worst case versus the grille's horizontal direction. If I have a can of Krylon clear coat, I'll hit half the sample just for grins.
I suspect it will be pretty durable simply because Krylon products have always surprised me in the past. I've used their products on mailboxes, railings, steel bumper touch up, etc. Always impressed me except one rattle can paint job on my utility trailer that faded and I later realized I did not use their better heavy duty outdoor stuff.
Anyhow, I just walked out to the garage with a cuppa, and looked at Mango's fresh face with a smile. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
specialev Samba Member
Joined: March 25, 2011 Posts: 281 Location: Mukilteo WA
Posted: Tue Apr 21, 2015 7:40 pm Post subject: |
How are your grilles with the krylon paint holding up?
I need to restore the grille from my Swedish Tristar. It's had the added insult of white over spray due to my negligence. It does not have a chrome strip on it so I just need to get back to black. I spent several hours wet sanding the over spray and I still can't get to the nooks and crannies. |
tjet Samba Member
Posted: Tue Apr 21, 2015 8:52 pm Post subject: |
tjet wrote: |
I'm gonna try that chrome film now for mine. If it looks ghetto, I'll take it off & try your method.
Just an update as this thread was revived, I tried the film method. I did not like it. It was a lot of work & too shiny - chromish.
IMO, Dougs looks more OEM
Also, I don't like Forever Black. I will try Krylon Fusion flat black next
Posted: Tue Apr 21, 2015 10:53 pm Post subject: |
The Krylon Black Satin paint I learned about here on Samba for the grilles in the D pillars and the front is holding up quite literally perfectly. When I wash the car, they look like I painted them yesterday. Absolutely nothing bad to say, and I also shot the grille on my Quattro, and something else I can't remember. Edit - Oh just remembered, I also shot a tail light on the Mitsubishi. One of the Samba guys in California snagged it for me out of a U pull and sent it up. Its black surround was faded to grey and mismatched the other side. Quick shot of Krylon and the van looks great. Cough. OK, it looks like a Japanese parody of the Vanagon, which would be somewhat less than "good" on a Bell curve....
The silver leaving pen on the front grille surround is also unchanged. And the Vanagon has had to sit outside for a bit while I played with the Mitsubishi. So, the leafing stuff has held up to the road chemicals of typical winter driving, rain, and sitting out with no change. Not an endurance test by any means, but clearly it is tough enough for outdoor use and its adherence to the Krylon I'd sprayed the grille black with a year earlier seems proven as well. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Wed Apr 22, 2015 9:12 am Post subject: |
Thanks for the replies. I'm glad you are all having good luck with black krylon plastic paint. I'm going to pick some up and work over the Tristar grille! |
Posted: Fri Apr 05, 2019 3:47 pm Post subject: |
kamzcab86 wrote: |
As for the pinstripe...The tape is cheap enough, so I'll give it a shot and see what happens.
djkeev wrote: |
If you are clever, skilled or know someone who is... Cut your own trim bits!
Up to 8" wide... You can easily cut the radius of your grille... |
Over four years later, done! And finally painted the crappy-looking grilles as well with Krylon Fusion (satin).
2" chrome striping trimmed down to two horizontal strips a touch less than 1/2" wide and two [ ] pieces cut out using a template traced from the grille. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Apr 05, 2019 8:01 pm Post subject: Re: Grille restoration / refinishing |
Wow, that looks great. Even when new, my "leafing silver paint pen" work did not look that crisp and vivid. It's now looking a bit weathered in spots.
I really like the way your grill looks with that factory silvery outline. I can see why VW did it as it adds significantly to the appearance with a more three dimensional front face than when we just have a completely black grille by painting. Well done and well worth the time. Any tips on material and how you did it?
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
a2wolfsburggli Samba Member
Posted: Sat Apr 06, 2019 6:12 am Post subject: Re: Grille restoration / refinishing |
A quick trick to restore any black moulding is to use Kiwi black leather dye.
Not polish! Dye is liquid and come in a bottle with a foam applicator.
Get it at any Walmart.
It'll last about 4 years in direct sunlight before needing touch-up. Much longer if you garage or store your vehicle.
https://www.kiwicare.com/en-us/products/kiwi-leather-dye _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
jimf909 Samba Member
Posted: Sat Apr 06, 2019 7:34 am Post subject: Re: Grille restoration / refinishing |
Best thread bump of the month: a great answer to a five year old question and som Saturday morning TK and Dylan.
I'm on the four year program with shaking the can of Krylon Fusion I bought and freshening up my black grills. It's raining today so it may be a five year program. The problem is a shiny grill would look out of place on my rattle can and bondo van.
Thanks for the follow-up kam. _________________ - Jim
Abscate wrote: |
Posted: Sun Apr 07, 2019 12:41 pm Post subject: Re: Grille restoration / refinishing |
IdahoDoug wrote: |
Any tips on material and how you did it? |
Pretty much what I posted:
kamzcab86 wrote: |
2" chrome striping trimmed down to two horizontal strips a touch less than 1/2" wide and two [ ] pieces cut out using a template traced from the grille. |
I initially applied 1/2" wide chrome to the horizontal runs, but the 2" wide stuff I got for the [ ] pieces didn't match. The 1/2" is more "bright aluminum", while the 2" is chrome. So, there are variations out on the market and I recommend simply getting 2" wide (or wider, if desired) decal that is at least 60-61" long. You'll then mark two 1/2" (or just a touch thinner) strips on the back side, cut, peel, and apply.
For the [ ] pieces, I've uploaded the template I made: http://oldbluesblog.com/images/Exterior/GrilleStripe.png . Print on card stock (image size: 4.01"x8.053"), cut along the lines, trace onto the back side of the chrome/aluminum decal, flip template, trace, cut, peel, apply.
The stuff I used is pretty flimsy; I imagine it's actually not going to last very long. I'll report back in another 4 years. _________________ ~Kamz
2016 Golf GTI S
Posted: Sun Apr 07, 2019 1:56 pm Post subject: Re: Grille restoration / refinishing |
Excellent - thanks. Summer project for me for sure this year if I can't find that silver leafing pen to try a recoat. Probably dried up in the kid's arts and crafts drawers... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun May 17, 2020 10:46 pm Post subject: Re: Grille restoration / refinishing |
The amazon tells me that I bought the Krylon Fusion paint for my Vanagon's grills on May 14, 2014 so I'm right at the 6 year anniversary of thinking that I'd clean up the grills on my van.
Amazon also tells me that I bought Forever Black Bumper and Trim Restorer on March 13, 2015.
I never bought Mother's Back to Black on Amazon but I have two bottles of it so I bought it at some point...twice.
After a few tests over the years, I can say that Mother's Back to Black is probably fine for shining up the black on a newer car that hasn't sat in the sun for 30 years. I'd never recommend it to someone hoping to restore a Vanagon's black parts. At best, it'll look nice for a few days or weeks. At worst, it'll impede any other efforts to blacken the black bits.
Forever Black is often recommended and appears to be shoe polish for the plastic. It works for about as long as shoe polish keeps your shoes polished when you wear your pro-polished shoes every day. It's also another product that probably gets in the way of paint sticking to stuff so I only tested it on disposable things like the front door fascia.
Here's the front door fascia that I've used as a test space.
- The lower right is where Forever Black was applied a year ago. It looks oxidized and I can see where the Forever Black shoe polish was laid on heavier by the sponge applicator...it still looks dark while the rest is greyish.
- Above that is Forever Black applied this morning. It cleans it up but still looks worn.
- To the left is Mother's Back to Black looking better but that will be short-lived.
With a few tests like that over the years I went all-in for the Krylon Fusion. I'm not a fan of layering layer upon layer of rattle-can paint over the coming years but that seems to be the best option.
Here's what the grills looked like in June, 2016, chalky and grey which is pretty much how they looked 4 years later. Zoom in to see how chalky they are.
Here's what they look like after a good cleaning and a can and a half of Krylon Fusion (the first coats were in gloss black because I had a can of it to use, the final coat in satin). A few fisheyes and some dust landing on fresh paint but they look good enough to make the rust pocked marked nose of my van look even older,
Rattle can paint has its limits, out in the weather 24/7 I put its lifespan at 3-4 years tops but I've been wanting to do this for a few years so I thought I'd give it a try.
Next up, adding chrome trim. I generally don't like chrome but when I see an original Vanagon chrome trimmed grill, esp. Kamz work above, I see exactly what the VW designers intended.
https://www.amazon.com/gp/product/B01E3K3W66/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
And a shiny new badge...
This might get me to do something about the seam rust and bondo...in 6 years or so... _________________ - Jim
Abscate wrote: |
Posted: Sat May 23, 2020 11:28 pm Post subject: Re: Grille restoration / refinishing |
jimf909 wrote: |
The amazon tells me that I bought the Krylon Fusion paint for my Vanagon's grills on May 14, 2014 so I'm right at the 6 year anniversary of thinking that I'd clean up the grills.
Six years after buying the Krylon Fusion I installed the grills and shiny VW badge today but haven't gotten to the silver trim. As expected, it just makes the rusty pock marks on the nose stand out.
Abscate wrote: |
jlrftype7 Samba Member
Posted: Sun May 24, 2020 7:35 am Post subject: Re: Grille restoration / refinishing |
What’s interesting is how much larger the lights look once you applied the black around them versus when the grill had faded. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Sun May 24, 2020 10:00 am Post subject: Re: Grille restoration / refinishing |
Indeed! It makes for a much more aggressive look. I like it! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 306 Location: Marietta, GA
Posted: Sun May 24, 2020 1:35 pm Post subject: Re: Grille restoration / refinishing |
In 2012 I took some pictures of the grill on my 1985 after I cleaned it up but before I painted it. It's interesting that the silver, which appears to be paint, filled the edge. The grills in this thread have silver on just the raised portion.
Also, the silver is on the top of the headlight opening:
But not the bottom:
As the original owner, I know that this is the paint scheme for the grill on my 1985. _________________ 1985 Westfalia 15 degree EA288 Boxeer |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun May 24, 2020 2:02 pm Post subject: Re: Grille restoration / refinishing |
Nuthin2It wrote: |
In 2012 I took some pictures of the grill on my 1985 after I cleaned it up but before I painted it. It's interesting that the silver, which appears to be paint, filled the edge. The grills in this thread have silver on just the raised portion... |
That is how my 84 was painted too.
I am now replacing the grille with the usual repro and wondering whether to paint or use the foil and if paint - how much to cover. |
