CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Mon Dec 01, 2014 2:33 pm Post subject: Seat Questions |
I have a few questions about seats. Are convertible seats different then coupe seats from the same year?
Would a 1970 Karmann Ghia coupe seats be the same type, size and style seat that would be found in a 1970 convertible from the same year?
How different are the Ghia's seats from year to year? Are 1970 to 1974 all the same front seats? Thanks. |
asbug Samba Member
Joined: January 01, 2008 Posts: 287 Location: N.W. Ga.
Posted: Mon Dec 01, 2014 2:56 pm Post subject: |
This has been covered before, but I speak from personal experience that the rear seats are different widths.
The vert is narrower.
I have the front seats out of a '74 in my '69 vert and they slid right on and look great.
KC _________________ 1969 Ghia Vert - Jenny.
2004 B5.5 Passat Wagon - no name yet.
2012 Routan - Urban Assault Vehicle. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Dec 01, 2014 3:08 pm Post subject: Re: Seat Questions |
CiderGuy wrote: |
Coupe and Vert front seats in a particular year are the same. As mentioned back seats are different between coupes and verts. 69 to 74 front seats should interchange. Not sure about pre-1969. 73 and 74 verts had no back seat but they can be retrofitted from a 69 to 72. _________________ Ghia Owner Emeritus |
Posted: Mon Dec 01, 2014 4:23 pm Post subject: Re: Seat Questions |
NOVA Airhead wrote: |
CiderGuy wrote: |
Coupe and Vert front seats in a particular year are the same. As mentioned back seats are different between coupes and verts. 69 to 74 front seats should interchange. Not sure about pre-1969. 73 and 74 verts had no back seat but they can be retrofitted from a 69 to 72. |
Thanks, I own a 70 and 73 coupe, looking at purchasing a vert. |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Mon Dec 01, 2014 6:50 pm Post subject: |
I always thought Ghia seats were the same for each model in the production year. Aren't Ghia seats wider than Beetle seats? _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
c21darrel Samba Member
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Dec 02, 2014 11:23 am Post subject: |
1969-74 model year ghia front seats are interchangeable between coupes and convertibles and use the same seat rail width, although original vinyl patterns varied by model year. 1968 and earlier ghias used a different front seat rail width.
Any year ghia coupe rear seat will fit any year ghia coupe, although different retaining clasps and straps were used. Likewise, any year ghia convertible rear seat will fit any year ghia convertible, although different retaining clasps and straps were used. _________________ 1966 Karmann-Ghia convertible |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Tue Dec 02, 2014 11:37 am Post subject: |
Since the VW Thing used the same pan as the Karmann Ghia, I would guess that Thing seats would also fit in the Ghia seat rails.
That might be an easy option for someone with a later model year Ghia that is looking for low back seats. |
Posted: Tue Dec 02, 2014 12:07 pm Post subject: |
KGCoupe wrote: |
I don't know about that. Thing seats are likely too high to fit in a ghia, much like how beetle seats are raised approximately 6 inches off the pan, whereas ghia seats pretty much hug the pan. _________________ 1966 Karmann-Ghia convertible |
Posted: Tue Dec 02, 2014 12:47 pm Post subject: |
Since I have both a Thing and Ghia I would have to take a look at the tracks. Even if they fit as Sactojesse says you will be sitting very high. _________________ Ghia Owner Emeritus |
Posted: Tue Dec 02, 2014 8:41 pm Post subject: |
sactojesse wrote: |
KGCoupe wrote: |
I don't know about that. Thing seats are likely too high to fit in a ghia, much like how beetle seats are raised approximately 6 inches off the pan, whereas ghia seats pretty much hug the pan. |
Well obviously I didn't think that whole concept out very carefully.
Since none of you know me personally, I'll claim that this is the first time that something like that has happened. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
