Corney13 Samba Member
Joined: July 06, 2014 Posts: 265 Location: Castaic, California
Posted: Mon Oct 23, 2017 10:10 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
vwuberalles wrote: |
I'd just cut and splice the radio opening. Take measurements off the red dash and redrill the holes that had been filled on your car. |
I agree. No point in cutting out the rest of the dash if it is good. |
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Mon Oct 23, 2017 10:19 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
ok
The reason I was asking is because the filled-in holes have been welded from the back and might be a pain to drill out. (not sure if the welded section would be easier)
I agree that a smaller patch would be better than welding a larger piece
I guess I could try drilling out the holes and if I have issues then i still have a donor piece
Thanks for the input _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1355 Location: Richmond, VA
Posted: Sat Feb 03, 2018 6:29 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Weather is beautiful here in SoCal today, so I finished hangin the doors on Ol’ Herb
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
67ctbug Samba Member
Posted: Sat Feb 03, 2018 7:01 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Looking good! _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Sun Feb 11, 2018 4:21 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
I picked up a 1600 dual port today . It's an AE coded dual relief case, so that's a very good starting point
I'll tear it down a little and check it out
I wont be splitting the case though
The seller said it was used for industrial use, which would help explain the j tubes and weird exhaust .
I'm guessing it ran a pump of some kind _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Sun Feb 11, 2018 4:40 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
My first thought when I saw the exhaust was it had been in a bus. Anywho, please be sure to rotate the generator ninety degrees clockwise and connect the vacuum advance to the correct port on the side of the carb when you put things back together.
Making good progress. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sun Feb 11, 2018 5:11 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Thanks , I hadnt Thought about a bus
Maybe it was, I have no idea
And don't worry about the generator not being clocked right , it'll get replaced with the alternator from the 2180
In fact, most of the parts placed on as a mock-up and not mounted fully .
I've got a little time before I try and fire it anyway , I still need fuel lines and a new fuel tank .
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Tue Feb 13, 2018 7:47 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
I drilled out the seat track on the driver's side after work tonight
If you recall, the PO welded angle iron to the rails so he could mount some other seats and screwed up the rails
So , I got some from Wolfsburg West and will try welding those in
Sorry, but I dont have before pics any more ☹️
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Wed Feb 14, 2018 1:39 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
IDK about the quality of Wolfsburg West's seat tracks but most of the aftermarket tracks are pure crap, make sure to slide them into the seat to see if they'll work. I also suggest using the seat as a jig to ensure that the tracks are aligned correctly as you tack weld the tracks onto the pan. & FWIW, depending on your height, it wouldn't hurt to install the new tracks about 2" back from original position, at 6'4" the original position is a bit tight for me.
Looking at that brake line, I'd give it a thorough once over or replace it just because. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
pbenn Samba Member
Joined: November 21, 2007 Posts: 375 Location: Toronto
Posted: Wed Feb 14, 2018 2:46 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
slave1pilot wrote: |
Is that engine missing tin pieces on the bottom? |
Posted: Wed Feb 14, 2018 4:07 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
TDCTDI wrote: |
Looking at that brake line, I'd give it a thorough once over or replace it just because. |
all very good information.
I will make sure they fit, but the old ones had to be replaced. They were unusable. The PO welded angle iron to them and they were FUBAR.
I was considering welding the track in a little farther back just to be ok. I'm only 5'11" but I like to sit back a little when I drive.I wasn't sure if it was a good idea to weld them someplace else and was gonna ask.
Everything needs going over in the car . it sat for quite some time out in the harsh California Desert
pbenn wrote: |
yes, the bottom tin isn't there. I do have the tin from the 2180 . I will install all tins and seals since I live in the desert and cooling is very important.
thanks everyone! _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Wed Feb 14, 2018 8:52 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Agree, I moved my seat tracks back 2 inch's. I made a plywood template before I removed them so I had something to refer to. Too bad the PO didn't give you that. Be mindfull of the seat workings and the tunnel when you weld them back in. _________________ 1960 Convertible |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Fri Feb 16, 2018 8:24 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
Your best bet is contact some VW salvage yards to see if they have some good OG seat tracks. I ordered WW heavy duty pans (which were great) and ended up using my original seat tracks (moved back a few inches). Test placement and use seat as alignment jig as stated above. You'll be glad you did if you go that route. |
Posted: Sun Feb 18, 2018 4:01 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
I had Some free time today so I decided To check out the engine i picked up
So much for that plan
Looks like it might be another boat anchor _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
mukluk Samba Member
Posted: Sun Feb 18, 2018 8:32 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Doesn't look to have been water filled for too long, continue the tear down and cross your fingers. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sun Feb 18, 2018 8:35 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Thanks man
That’s the plan
A little discouraged today , so I put the heads back in place
Going to drain the oil And see if there is any water there.
I’ll flush it a few times and take a look
Id rather not split the case, but I’m not sure at this point how much effort I wanna Put into this one _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
EA812 Samba Member
