Left for Dead...The Resurrection Story....(AWD EE-20)
lucianosanchez
lucianosanchez is offline
PostPosted: Mon Oct 24, 2016 3:47 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Popcorn
Bookmarked. Cant wait to see more!
1983.5 Westfalia | 2016 to Current
0cean
0cean is offline
PostPosted: Mon Oct 24, 2016 3:51 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
xoo00oox wrote:
That's more like it! Do you have the engine and transmission yet?
Bytheway, love the idea of welding in tie down hooks. I'm always wishing I had them when I go to secure something in my van.
Sexy, Sexy....
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
0cean
0cean is offline
PostPosted: Thu Oct 27, 2016 10:43 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Part two of the extra storage area.
Need a little power of the sliding door.
Next is the switches for lights, compressor, etc. I mounted them vertically to save some space on the inside. Don't need all the wires getting banged up moving stuff in and out.
Cluster Rebuild:
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Oct 27, 2016 11:51 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Where did you source those slider door contacts?
Casey--
Seven VW vans from T1 through T4 since 1985
Volkswagens powered by Volkswagen
Respect the marque
0cean
0cean is offline
PostPosted: Fri Oct 28, 2016 5:52 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
It came from Painless Performance. Not the cheapest, but good quality so I don't have to worrie about it failing later. The pins have adjustable length and that's really nice.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Tue Nov 01, 2016 4:34 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Next comes the good stuff... The pop-top and basket... I wanted solar, yet having it out of the way is a must. A roof rack that was permanent and kind of no fuss also was needed. And finally a new vent system that would prevent my surfboards from getting a Chinese wax job... all sideways and melted. (No that was not politically correct, yet I don't care..)
Lot of sanding and cleaning up to do. The vent was moved back behind the pop-top lift bar so I wont bang my head on it as much. The problem with the vent I chose was its mounting depth is a lot, so the thing sits low on the inside of the van. This was a give and take because its an automatic temperature sensing vent. AKA, stop the melted wax.
More sanding....
The roofs flocking looks to be flocked. That will be addressed soon enough.
At least it fits.
Here is the first layer of carbon fiber tissue paper. This is what I use to make surfboards. Good stuff.... Also the Rhino Racks tracks have been laid and roof cut to except them.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Sat Nov 05, 2016 3:14 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Here is the layout for the top.
There would be a problem with wind noise because the vent sticks up way to much. So, I used some extra EPS surfboard foam to shape a wing for air flow over the vent.
I don't have any pictures of the sides around the vent, but they are made from the same surfboard material and epoxied down.
Next the second layer of carbon fiber was added. In total its really strong.
Added more surfboard foam to get rid of the old vent indention. Also took the opportunity to carbon fiber all the corners for strength.
Cluster Rebuild:
erste
erste is offline
PostPosted: Sun Nov 06, 2016 5:01 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Very slick.
I'm loving your build, so many details.
Who makes the panel? It's incredibly thin.
0cean
0cean is offline
PostPosted: Sun Nov 06, 2016 3:31 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
erste wrote:
Very slick.
Its a 120w I found on eBay. The New XERA Solar 120w 12/24v Solar Charger Kit for Golf Cart Solar Panel as the seller says. Its nice, but I think some people have heating issues with the thin solar. There is open air under most on the panel for my case, so I'm not worried about it for my build.
Thank for the compliment. I'm building my dream van.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Wed Nov 09, 2016 8:41 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
A lot of carbon fiber whent into the pop-top. There is to much flex with the older staple in style roofs for my taste. Now its strong and can handle a load.
Sand, Sand, Sand, Sand
More Sanding, Sand, Sand, Sand, Sand and more Sand.
After priming with epoxy primer. Almost ready for some paint... or something like that.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Fri Nov 11, 2016 10:21 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Ok, everything was going smooth until I applied monsterliner with the custom tint from a local paint shop. The directions from monsterliner are clear, yet the type of PPG product monsterliner requires has a filler in the formula that is not obvious and hidden. Any filler will cause the mix to kick off very quickly. I will post more about this on the monsterliner thread later. Anyways, the result was the monsterliners pot life was reduced from 1.5 hours to less then 20 mins.
As I was spraying the monsterliner and it started to harden like crazy. First I stoped spraying and then used a roller to try to save the poptop. That ended in failure and I had a mess of a paint job and lost one full gallon of product. I was pissed!! : #2gunfire Brick wall #2gunfire
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Sat Nov 19, 2016 12:03 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
So after the monsterliner failure, I called PPG to find out what happened. They told me there is a active ingredient in the mixture that does not state its a filler. The mixture recipe calls it Clear and its the only thing that is not a tint. STAY AWAY FROM THE CLEAR if you use this product. Well after a lot of sanding and a new batch of tint, I was back in business. Finally!!
Over a gallon of product was lost because of a bad mix.
The roller disintegrated leaving pieces of it all over the pop-top
A lot of sanding to get ride of all the air bubbles and the parts of the roller that was left.
In the end, this is the texture with sprayed monster liner. Its really nice and not all crazy bed liner looking.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Mon Nov 28, 2016 8:44 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Now for the hard part, the underside of the pop-top. Of course the flocking looked horrible and was just as bad as a 80's Freddy Cougar movie, so it was removed with a wire wheel and sanding.
Now a little more carbon fiber was need because of some bowing that was happening in the middle and for more strength.
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Fri Dec 02, 2016 4:18 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Working on the top was a messy time consuming process, yet it was worth it.
I sprayed a light layer of lizard skin for a little sound dampening.
Flocking.... well it's about a three person job really. The reason is because it's very time sensitive as the glue drys in 10 mins. Not a lot of working time. The other reason is because your spray gun will jam all the time preventing flocking from coming out. Last but not least, the flocking has to be sifted because the strands bunch up and clog the gun. It's not easy at all.
If you try this at home, one person rolls the glue, the second sifts the flocking and fills the canisters, and the last person sprays the flocking. Keep the gun real close to the glue and put a ton of it on.
Sprayed the outside edges with normal automotive paint. Love the Toyota quick sand color.
Its Christmas!!! Unwrapping the pop top present!
Cluster Rebuild:
0cean
0cean is offline
PostPosted: Fri Dec 09, 2016 3:47 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Time to give the basket some love. Its in rough shape, yet very fixable.
Drilled all the rivets out.
I will have two GPS devices; One for the speedometer and one for Siri/XM. Guess that's only one GPS and one Satellite receiver thing. Well, what ever. Anyways its going in the basket out of the way.
I added some small metal plates for the GPS receivers to attach to.
Little carbon fiber for strength.
Cluster Rebuild:
E1
E1 is offline
PostPosted: Fri Dec 09, 2016 5:21 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Great thread, compliments to your build!
As my Brit friends in the F1 world would say, you have "very large attachments" to tackle this mammoth project as you have...
Awesome, keep it goin' on!!!
Bills85Westy
Bills85Westy is offline
PostPosted: Fri Dec 09, 2016 5:32 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Loving this! Making great progress and some improvements that I hadn't thought of. I really like strengthening the top with carbon fiber. I carefully walk on my top (have done this for years and years) but like how you've modernized it with the racks and vent.
Can't wait to see what's next.
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP 1.8
Front and rear lockers and decoupler
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L
figborg
figborg is offline
PostPosted: Sat Dec 10, 2016 11:19 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Loving this too! I'm following this thread. Thanks for sharing.
-- PF
Providence, RI
1986.5 Westy camper (G year code, grey interior), 2WD, manual transmission, Subaru conversion by Vanaru. Spoiled rotten.
http://www.thesamba.com/vw/forum/viewtopic.php?t=662374
Steve M.
Steve M. is offline
PostPosted: Sat Dec 10, 2016 11:29 am    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
Dare I ask if your going to call this one "Phoenix"?
0cean
0cean is offline
PostPosted: Sat Dec 10, 2016 12:56 pm    Post subject: Re: Left for Dead...The Resurrection Story....(AWD EE-20) Reply with quote
No, but I was thinking of a rear plate saying Diesel and Dust edition instead of Vanagon or Syncro. Very Happy
Thanks for the kind words everyone. This will be finished, it just has so many mods going on it's taking forever. Hopefully I will put the welder down next month.
Cluster Rebuild:
Page 6 of 10
