KevinsKamper Samba Member
Joined: November 17, 2014 Posts: 72 Location: Massachusetts
Posted: Sat Dec 06, 2014 10:19 am Post subject: What lies beneath!............. |
So I've had my Westy for about 3 weeks now, checking it out and getting familiar with it and starting to fix some minor things...Today I decided to take the luggage tray off the roof.....I had noticed a couple of pine needles sticking out from underneath the tray seal and figured I better investigate further....sure glad I did cause heres the results!....and this doesn't show the crap that fell to the floor during removal....Damp wet mud and rotting vegetation.....a perfect recipe for a future sunroof I really don't want!.....Now for a major clean up and a coat of wax....
[img][/img] |
benandmj Samba Member
Joined: October 29, 2012 Posts: 550 Location: Atlanta
Posted: Sat Dec 06, 2014 10:22 am Post subject: |
I need to do this SOOOO bad. _________________ 85 Westfalia Weekender
91 Syncro Westy |
Posted: Sat Dec 06, 2014 10:24 am Post subject: |
benandmj wrote: |
I need to do this SOOOO bad. |
I highly recommend it.....remove 8 fastners and she's off!...... |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9799 Location: Mt Lemmon, AZ
Posted: Sat Dec 06, 2014 10:44 am Post subject: |
you may want examine the archives for ways to keep stuff from passing thru the drain holes in the luggage rack.
I use those little cone-shaped screens made for washing machine hoses but other clever ways have also been found. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sat Dec 06, 2014 1:41 pm Post subject: |
I'd suggest being prepared to prep and paint body where luggage rack rubber meets the body. I used proper body paint and a brush. At a running gallop, it looks fine. It would be an easy matter to wet sand any brush strokes out or just use a foam brush?
If you put screens at the drain holes, IMO it's best to install them at underside of rack. No, don't ask. So far, I've found that fibreglass resin works to hold them in place (I was repairing the rack while installing screens)
If any of the rubber washers are missing, you may find same or similar at your local plumbing store. IIRC, Bentley shows these washers. On my bus there was one between each bracket and rack and two at each rear fastener between body and rack. In terms of height at rear of rack, you want the rack and pop top to seal when closed.
OEM washer (or what I found) on LH. Not not the same thickness but two might be ok These types of washers should be easy to find.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Merian Samba Member
Posted: Sat Dec 06, 2014 3:56 pm Post subject: |
don't tell me you removed all that insulation! |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sat Dec 06, 2014 6:55 pm Post subject: Re: What lies beneath!............. |
Hey Kevin ... looks like you have a good acorn selection there
I took mine off for the first time ever a few years back, and I know the original owner (before me) never had it off ('87 Westy).
It was immaculate with just a few twigs, the paint looked like it was new and waxed !!!
Maybe not getting parked under trees very often ?
But about three times a year during a wash I always spray water into the holes (not on paint-peel high), rotate the nozzle around slight in the process and maybe that was the reason. |
Posted: Sat Dec 06, 2014 7:02 pm Post subject: |
I'm thinking maybe mice resided here at some point......if they could squezze into the drain holes?.... |
outdoornate65 Samba Member
Joined: September 29, 2012 Posts: 161 Location: SE burbs of Denver, Colorado
Posted: Sat Dec 06, 2014 7:47 pm Post subject: |
When I removed mine last winter, I glued small pieces of screen on the underside of the drain holes to keep debris out....seems to be working fine.
_________________ 1984 Westfalia Wolfsburg "Nana" |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Sat Dec 06, 2014 8:11 pm Post subject: |
You would think all that gunk would ruin the paint, but once I cleaned mine up, (and others have mentioned this too) the paint under the luggage rack looks factory new. It shows that sun is the true enemy of paint, not water and organic matter. |
Posted: Sat Dec 06, 2014 8:19 pm Post subject: |
wcdennis wrote: |
Agreed, after a quick clean-up the paint under my luggage rack was the best looking section on the bus. _________________ 1984 Westfalia Wolfsburg "Nana" |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
Posted: Sun Dec 07, 2014 7:04 am Post subject: |
It ended up cleaning up nicely, no rust and just one small area that wore down to bare
metal that will get touched up. I will install the screen idea as insurance...thanks! |
Posted: Sun Dec 07, 2014 7:41 am Post subject: |
Any organic debris pile up, left for a while, will release certain acids during the decay process that could leave stains all the way up to eating through the paint and rust. This is why in the fall in particular I try to remove any wet leaves (they are really bad) and other debris off any rigs parked outside as frequently as I can.
Doing the screen thing on the holes as mentioned by another and/or periodically the low pressure water hose spray cleaning thing through the holes will help a lot. |
Posted: Sun Dec 07, 2014 12:08 pm Post subject: |
I ended up putting in some small screens today held in with silicone....should alleviate any future problems and the fact that this baby will always be garaged under my watch.....thanks for the input guys. Kevin |
Ibuprofen Samba Member
Posted: Sun Dec 07, 2014 1:05 pm Post subject: |
When you clean underneath the front luggage area take steps to prevent water from being introduced at the bolts near the pop top. I'm pretty sure that's where the water was introduced. I had a bit of rain in the cabin during braking after I last did this job! _________________ Filbert: 85 Westy, 1.9 AHU mTDI, LR 300 pump stock fueling, 520 nozzles. |
Lotek Samba Member
Joined: May 11, 2008 Posts: 126 Location: Los Angeles
Posted: Sun Dec 07, 2014 1:33 pm Post subject: |
Any tips on removing the screws that hold the luggage rack on? Mine are frozen solid and resist movement by my biggest screwdriver. |
Posted: Sun Dec 07, 2014 6:37 pm Post subject: |
Lotek wrote: |
The first 7 came off surprisingly easy but the last one was a bitch....isn't it always the last one?..haha.....I was afraid as it started to deform the slot from the screwdriver....I tapped on the head a few times carefully with a hammer to try and break the seize....eventually got some movement and worked it back and forth and she finally screwed out....I was afraid to try heat because of the fiberglass.....good luck! |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3093 Location: ABQ NM USA.... Except when not
