hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Wed Dec 10, 2014 1:06 pm Post subject: weber f11 tubes air /jets stuck |
question on weber f11 tubes and jets i cant seem to take off the mains and airs on the air correction tubes any suggestions ? i tried to screw off the main just keeps turning . havent tried on the other tubes yet. also the air correction is that a thread or just a cap that goes on the f11 tubes ? thanks . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Wed Dec 10, 2014 1:09 pm Post subject: Re: weber f11 tubes air /jets stuck |
they are pressed into the emulsion tube, they just pull out. They are NOT THREADED.
The jet holder is threaded, which presses the whole stack down. Just use vice grips and pull straight apart, but be careful to not grip the #s which will make jet IDing' more difficult in the future. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
hsosa1 Samba Member
Posted: Wed Dec 10, 2014 1:11 pm Post subject: Re: weber f11 tubes air /jets stuck |
[email protected] wrote: |
The jet holder is threaded, which presses the whole stack down. Just use vice grips and pull straight apart, but be careful to not grip the #s which will make jet IDing' more difficult in the future. |
ok thanks for the info . will do . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Thu Dec 11, 2014 4:44 am Post subject: |
When you reassemble the jet stack, they should fit together snuggly so they don't fall apart. It makes it much easier to reinstall into the carbs. _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
