bassam Samba Member
Posted: Tue Dec 16, 2014 12:02 pm Post subject: Rocker molding clips |
Hello guys,
I bought a chrome kit for my 73 Squareback but they come without the rocker molding clips. Now that they will be in stock and as they come in a set of 10 (http://www.paruzzi.com/images/mega30398.jpg?refresh=1329723317), I need to know how many sets will I need. In other words, how many holes are there on each side of the stock rocker of a 73 Squareback to add clips to?
Cheers,
Bassam _________________ 1973 VW Squareback |
Jack square Samba Member
Joined: July 23, 2014 Posts: 36 Location: New Zealand
Posted: Tue Dec 16, 2014 12:23 pm Post subject: |
You should only need ten but make sure they are the lat ones not the early ones they changed |
Pelle Samba Member
Joined: February 07, 2004 Posts: 199 Location: Sweden
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Thu Dec 18, 2014 1:10 pm Post subject: |
Original Volkswagen Factory Nylon / Plastic Lower Rocker Molding Clip ... installs in hole them push pin in to secure.
VW Part # 515 853 587 on part.
Care must be taken to remove, most are brittle & broken.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Thu Dec 18, 2014 7:31 pm Post subject: |
ISP West sells them too, but they're the steel version, that'll need some paint on them to keep them from rusting. And yes, you need 14 of them (7 per side). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
nassau66427 Samba Member
Joined: January 13, 2012 Posts: 80 Location: New Jersey
Posted: Fri Dec 19, 2014 9:09 pm Post subject: |
Typ3nut wrote: |
Care must be taken to remove, most are brittle & broken. |
An easy way to remove them without damage is to -
1. While gently squeezing the clip with a pair of pliers, drill a small hole part way through the pin. (The pliers keep the pin from spinning.)
2. While gently squeezing the clip, screw a small screw part way into the hole you drilled.
3. Pull on the screw head (I used a claw hammer) and the pin will come start to come out. When the pin is about half way out, the clip will come off the car.
Remove your screw and move on to the next one. It takes longer to read than do. The pins can be reused. |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Fri Dec 19, 2014 10:52 pm Post subject: |
I bought those plastic ones from Bert iirc.
failing that Mario might have some. _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
danielf Samba Member
Joined: June 09, 2009 Posts: 26 Location: long island
Posted: Fri Sep 29, 2017 1:26 pm Post subject: |
Bobnotch wrote: |
ISP West sells them too, but they're the steel version, that'll need some paint on them to keep them from rusting. And yes, you need 14 of them (7 per side). |
THANK YOUR THE ONLY ONE THAT REALLY KNEW WAITING ON PLASTIC NOW,NOT ISP WRONG METAL CLIPS |
Posted: Fri Sep 29, 2017 1:45 pm Post subject: |
danielf wrote: |
Bobnotch wrote: |
The metal clips will work. In fact on my 71 Notch I used the metal clips on it, but I ended having to remove them and put some paint on them because they were rusting. And having rust stains on fresh paint is a no no for me. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Sep 29, 2017 3:52 pm Post subject: Re: Rocker molding clips |
bassam wrote: |
Hello guys,
Cheers,
Bassam |
HI 14 |
Posted: Sat May 26, 2018 11:39 am Post subject: Re: Rocker molding clips |
NOS Type 3 Rocker Moulding Clip * Update :
The metal clips don't work, these plastic clips are the ones you need for a secure fit of your rocker trim.
LASHEETMETAL Samba Member
Posted: Sat May 26, 2018 3:12 pm Post subject: Re: Rocker molding clips |
Hi Guys, I have a 67 Squareback that I bought the lower rocker mouldings and the galvanized clips. While I was trying to install these clips the back piece that is supposed to go into the hole would break off with absolutely no effort at all, will these plastic ones work? really new to the VW family and I find that the 67 seems to be a one year only on many parts. Any help would be greatly appreciated! |
Posted: Sun May 27, 2018 8:30 am Post subject: Re: Rocker molding clips |
LASHEETMETAL wrote: |
The plastic clips are for the narrow lower trim. I only mention it, as early type 3s used the wide lower trim. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Jun 08, 2018 12:49 pm Post subject: Re: Rocker molding clips |
The plastic ones should be fairly easy to find for a 67 - it was the first year that used them:
311 853 587 B
Plastic clip - Molding, outer
from Ch. No. 317 000 001 |
Posted: Sun Jun 10, 2018 9:09 am Post subject: Re: Rocker molding clips |
Bobnotch wrote: |
The plastic clips are for the narrow lower trim. I only mention it, as early type 3s used the wide lower trim. |
The earlier trim also has a plastic version - not as cheap or easy to find but they're out there:
http://type3headquarter.de/epages/7b2adfc2-5ed3-41...D=14988573 |
