earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Dec 18, 2014 12:07 am Post subject: What scale for balancing parts do you guys use? |
I am looking to get a triple beam scale for balancing rods and pistons and other things, I don't like digital scales so I will be looking at Ohaus scales mostly.
I have a Ohaus scale but it is for heavy things, it will up to 20KG in 1 gram increments, this thing is 3 feet long and weighs 20 pounds, I could weigh cranks with it! Its missing the weights for any thing over 1010 grams but I am watching Ebay for a set.
I don't have the 1 KG weight so I don't know what a Weber 44 IDF weighs.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu Dec 18, 2014 5:53 am Post subject: |
Why don't you trust a digital scale? They can be certified and just as accurate as anything else. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Dec 18, 2014 6:51 am Post subject: Re: What scale for balancing parts do you guys use? |
earthquake wrote: |
Casey |
Suit yourself, but time is money. The digital scales read instantly, and there are no weights to lose. I have two pelouze brand digital scales, they never have let me down. One of them is a counting scale, that has a few memory settings, it comes in handy when you're matching sets, or want to remember what you started with. |
nsracing Samba Member
Posted: Thu Dec 18, 2014 7:07 am Post subject: |
The Ohouse will work ...if you want to measure it in pounds!
The digital is about as fast and accurate you can get...depending on tolerance of course.
I have a Shadow Scale from Stewart Warner (1/2 gram tolerance) if you want to have your own. Let me know..I am very agreeable. I need money for my M14 projects. |
risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Thu Dec 18, 2014 7:52 am Post subject: Re: What scale for balancing parts do you guys use? |
earthquake wrote: |
Casey |
Seems like balancing the carbs is a little overboard... but to each his own.
I use digital scales from a local hippie shop. Works for me. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Dec 18, 2014 8:09 am Post subject: |
I have an Ohaus Triple Beam and a 600 gram Ohaus digital. My triple beam measures in grams. The digital is much more convenient, smaller, and just as accurate. I got mine on Ebay for $60 new, out of the box. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Thu Dec 18, 2014 8:17 am Post subject: |
I just bought a cheap 2000 gram max 0.1 gram accuracy digital on ebay for $20.00.
I just tested it with some test gram weights I own from a powder scale and it tested right on, or + or _ 0.1 grams with various calibrated weights. Pretty good for $20.00 _________________ 1958 Karmann Ghia owner |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Dec 18, 2014 8:42 am Post subject: |
Cheapo AWS brand digital scale for around 20$. 3000 gram x .0.1. Amazon. I bought the 4x 500 g calibration wieghts also. Able to get down to a 10th or two and thats good enough for any build. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mark tucker Samba Member
Posted: Thu Dec 18, 2014 10:46 am Post subject: |
I have digitail scales.i dont like the shadow scales.and dont care for beam scales either. Ive found the digital to be better for repeatability no mater where the part is put on the scale. |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Thu Dec 18, 2014 4:48 pm Post subject: |
I use a cheap digital scale I bought at Harbor Freight. I check it by weighing something on my powder scale and again with the digital. For being as inexpencive as it is, it is very accurate. _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri Dec 19, 2014 4:56 am Post subject: |
Metric.
On a more serious note, balance scales are more accurate than most electronic scales in the right hands. Most lay people confuse accuracy with precision - a resolution of 0.1 gram is useless if it is not repeatable due to changes in temperature, scale and position on the scales (most electronic scales have a single load cell and can show wide variations in readings depending on where on the scale the center of gravity falls.) Laboratory scales can overcome most of these problems, but are expensive. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
morymob Samba Member
Posted: Fri Dec 19, 2014 7:16 am Post subject: |
Digital, before i start i have a couple penny stacksI stick on , if theycheck out i go ahead. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Fri Dec 19, 2014 11:01 am Post subject: |
O Haus beam. Works great for the infrequent need I have for it. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Fri Dec 19, 2014 1:50 pm Post subject: |
The thing I don't like about digital is they have to be plugged into a outlet or they have batteries, when they are plugged in they can fluctuate when there a load on the line and when batteries start to go flat,
You can plug them into a UPS and they will be pretty stable but
"A triple beam don't need no stinking power!"
I know a lot of guys that reload using digital scales made by "Denver Instruments" and they like them but the are not cheap.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Mon Dec 22, 2014 9:28 am Post subject: |
This is what I use...Stewart Warner.
bluebus86 Banned
Posted: Mon Dec 22, 2014 10:42 am Post subject: |
for most small time engine building don't be too concerned about absolute accuracy. repeatability is more important. ( ie You are most concerned in matching four rods, or four pistons in weight to each other, not so much concerned about their absolute weight, for engine building the difference in weight in a small number of samples is the main concern.)
1... repeatability issues can be overcome even on cheapo electronic scales by measuring all four pistons at the same temperature, since four pistons can be measured in less than a minute, temp variations of the scale should not be an issue. If you end up lightening a piston that is too heavy, and don't get to re-weighing it until a day later, it would be wise to re-measure all of them again (or at least one of the pistons you did not alter)) to see if any drift occurred in the weight measurement. Also you can do a repeat measure of each piston and compare values to check for drift of measurement
2... Also it is always wise on any scale when comparing samples, to set each sample (say pistons) that is measured in exactly the same position on the scale platform each time, this eliminates issues with repeatability due to placement on scale.
3. On ANY scale it is wise to have one or more proof weights to be used periodically to check accuracy if accuracy is required. The Proof weights should be close in size to what ever sample is being measured, and the location on the scale platform for setting the proof weights should be consistent (see item 2 above).
So digital or mechanical can both be used well. Digital has a great speed advantage for production uses. For an engine builder that does even an engine a week, the time savings of a digital scale is not great. Not needing batteries or needing an electric outlet may be a deciding factor for some. If your running a huge production facility with 1000's of parts to measure daily, semiskilled work force, then digital scales make a lot more sense.
Engineers have come up with procedures to address issues with accuracy and repeatability and understand how to do work with different types of measuring equipment, knowing the strong points and weak points of different methods of measure, and appropriate responses to meet various manufacturing and hobby needs. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Oil Phil-M Samba Member
Joined: October 08, 2005 Posts: 541 Location: Vancouver, BC
Posted: Mon Dec 22, 2014 1:10 pm Post subject: |
I used a digital scale that read in grams and to get even more precise i added pieces of packing foam into the process for weighing. The foam I had just happened to weigh 1g for 10 pieces so I would add a piece on at a time until the scale when up to the next gram then the math gave me a rough 0.1g reading. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
bluebus86 Banned
Posted: Wed Dec 24, 2014 5:42 pm Post subject: |
Boolean wrote: |
That is clever. |
My Ohaus triple beam easily reads one tenth gram, no foam.
Problem is with the foam trick is that you are still depending on the scale having 1/10 th gram resolution, when it may not be able to resolve that well. It would make sense for a scale maker to have a display that resolves as well as the scale is able to resolve.
A resolution a full order of magnitude reported beyond the scale readout is suspect.
I wont claim my triple beam Ohaus can resolve 1/100th gram, just because I have ten pieces of 1/100th gram foam. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Wed Dec 24, 2014 6:23 pm Post subject: |
You don't have to have good resolution to get good results with the foam (or whatever) trick. The clever part is that you can use small, say 0, 1 gram weights to find the resolution clickover point exactly. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
