Alternator Type IV (4)
surfbus23
surfbus23 is offline
PostPosted: Sat Oct 07, 2017 1:35 am    Post subject: Re: Alternator Type IV (4) Reply with quote
Turns out what you want to search for are "alternator capacitors". You'll get nowhere with "suppression condenser". Even then I couldn't find any that looked flat AND would fit over the B+ terminal. Just purchased a space version and will modify it.
Tcash
Tcash is offline
PostPosted: Sat Oct 07, 2017 9:23 am    Post subject: 021 903 295 Alt. Suppressor Condenser Reply with quote
http://www.pelicanparts.com/PartsLookup/HTML/914_USA_KATALOG/902-05-Frame3.htm
https://www.volkswagen-classic-parts.de/en/entstorkondensator.html
https://www.vwheritage.com/classic/?ClassicLookup=CONDENSER
Tcash
Tcash is offline
PostPosted: Sat Oct 07, 2017 9:25 am    Post subject: 914 Alternator wiring harness Reply with quote
Will a Porsche 914 Alternator wiring harness work on a VW T2 bus?
http://shop.914rubber.com/Alternator-wiring-harnes...egoryId=-1
raygreenwood
raygreenwood is offline
PostPosted: Sat Oct 07, 2017 9:52 am    Post subject: Re: 914 Alternator wiring harness Reply with quote
If memory serves it should. I have "stolen" alternators from 412 with L-jet to go into D-jet...so it "should" ....let me check my books.
Ray
Bleyseng
Bleyseng is offline
PostPosted: Sat Oct 07, 2017 1:14 pm    Post subject: Re: 914 Alternator wiring harness Reply with quote
Ray
Yes, but it might be a bit short in length. I'd have to measure as it's a close match
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
tommu
tommu is offline
PostPosted: Fri Nov 17, 2017 12:29 am    Post subject: Re: 914 Alternator wiring harness Reply with quote
Wondering if anyone has tried this?
Green Bay Bus Yellow Ghia
surfbus23
PostPosted: Fri Nov 17, 2017 10:03 am    Post subject: Re: 914 Alternator wiring harness Reply with quote
Looks the same to me.
surfbus23
PostPosted: Tue Dec 05, 2017 6:22 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
Thought I'd try and do something helpful, so uploaded this template for the alternator gasket for anyone in the future to use. It's from a NOS gasket from SGKent's stash.
Print it out at 300 dpi and you're good to go with a factory template. I made mine from the link below. Scissors for the outside, razor blade on the inside and drill out the holes for a nice looking gasket. This is factory spec so make sure to give yourself a little clearance on the outside unless you have a perfect steady hand.
https://www.amazon.com/Mr-Gasket-9615MRG-Compresse...per+gasket
I like it better than the original paper thin gasket because it gets the backing tin farther away from the metal of the alternator.
[/url]
tommu
tommu is offline
PostPosted: Thu Dec 07, 2017 12:19 am    Post subject: Re: Alternator Type IV (4) Reply with quote
[/url]
Thank you, that's really helpful. I'll try and do the same for EGR and CSV gaskets.
alman72
alman72 is offline
PostPosted: Thu Dec 07, 2017 4:47 am    Post subject: Re: Alternator Type IV (4) Reply with quote
T-Cash... Gasket Template sticky? or page simply named gasket templates with all of them in one place?
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Dec 08, 2017 10:06 am    Post subject: Re: Alternator Type IV (4) Reply with quote
I need to add a contribution, here, but am not at home where I have the stuff to add (photos, etc.)
What I can say is that the gaskets I got from Steve Kent actually did not fit well, and I intend to send them back to him (It's in the "to-do" pile.) The holes were not in the right place, and it was a bit of a force fit over the threaded studs in the alternator housing.
What I found worked best was to use the backing plate from the alternator as a template, drawing directly on the thick paper or foam gasket material. That way, you have a guaranteed fit. I made several at once, and I will never have to install another alternator without a gasket.
Also, using a hole punch for the holes is cleaner than drilling.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab, 1978 Irish 4-door double cab RHD
Abscate Premium Member
Abscate is offline
PostPosted: Fri Dec 08, 2017 11:35 am    Post subject: Re: Alternator Type IV (4) Reply with quote
You should photo that with a scale to make it a bit easier to reproduce electronically
.ssS!
Wildthings
Wildthings is offline
PostPosted: Fri Dec 08, 2017 11:46 am    Post subject: Re: Alternator Type IV (4) Reply with quote
This is another route that people could go. Find three washers of suitable thickness to use as spacers to hold the cover out a bit. Put the washers over the three long bolts on the alternator. Now smear some high temperature silicone along the cover where the gasket would normally sit, wipe the silicone from the areas where the washers will sit against the cover. Let the silicone skin over well but not through harden. Install the cover and tighten the nuts down. You now have a custom gasket that should last for decades.
If the cover is warped and doesn't sit flat an extra washer embedded in the silicone half way between each hole should help shape the cover as it is installed.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Dec 08, 2017 11:53 am    Post subject: Re: Alternator Type IV (4) Reply with quote
two other people told me that then they changed the clocking (rotated or turned over the gasket) and got back to me again saying they fit perfectly once they did that. Those came from VW in Germany and had the correct part number on the packaging so you might try re-clocking them. I plan to redo the bearings and brushes in my own 55 amp alternator in a couple weeks and will check it out.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
1971 (sold)
1977
THall
THall is offline
PostPosted: Fri Jul 06, 2018 2:40 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
I'm going to be installing a new alternator this weekend.
I already shortened the one bolt and use a smaller diameter washer on the other.
Is there any reason I shouldn't use a cork gasket between the alternator and backing plate to gain some extra clearance?
'78 Westy - 2.0 FI
Wildthings
PostPosted: Fri Jul 06, 2018 2:55 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
Maybe what we need is for someone to repro plastic covers for the alternator.
Tcash
Tcash is offline
PostPosted: Fri Jul 06, 2018 5:15 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
I don't see a problem with it. The only thing it is sealing is air.
Cut an isolator out of a piece of plastic and install here.
ivwshane
ivwshane is offline
PostPosted: Wed Aug 29, 2018 6:03 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
Does anyone have some good pics of the alternator sealing ring installed or the correct orientation on the alternator? I was thinking about making my own since mine is pretty beat up. I was planning on using a 1/8" thick silicone rubber sheet with a durometer rating of 60-70 (were they originally hard plastic or soft rubber?).
Its for a 77 so the odd shaped one.
77 westy 2.0 FI? (who knows)
71 ghia coup 1600dp
kool kombi 79
kool kombi 79 is offline
PostPosted: Fri Jan 25, 2019 10:54 pm    Post subject: Re: Alternator Type IV (4) Reply with quote
Malcolm Engineering Australia is manufacturing the later Alternator seals.
Please contact us for a international postage quote.
https://www.malcolmengineering.com.au/vw-kombi-alternator-seal
Malcolm Engineering
0407 916 816
[email protected]
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Thu Jan 31, 2019 8:23 am    Post subject: Re: Alternator Type IV (4) Reply with quote
55 Amp Alternator Question:
On my original ‘74 alternator, I have a thick (8 gauge?) wire coming off the alternator leading to confusion on what exactly this ties into. On the schematic, I have no visual of such blue wire.
Small blue wire - indicator light
Large red wire - starter 50
Brown wire - ground
Green wire - isssss????
Trying to figure this out, something’s array as I had it hooked up previously with a running bus but resulting in ruining a voltage regulator.
Any insight is wonderfully apprciated.
Sam
The Bus Barn Ltd. Co.
Maywood Mountain
Benton, Arkansas
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -S.H.B.
1959 Dove Blue Single Cab - SOLD
1965 Ruby Red Standard Beetle - SOLD
Oct. ’67 Double Cab (’68 Doka)
1974 Brilliant Orange Westfalia “PushPop" - SOLD
1975 Kasan Red Transporter
1978 Sage Green Tintop
1981 Aussie Brown Westfalia
2017 Golf GTI - SOLD
Page 5 of 6
