luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Sat Dec 27, 2014 1:48 pm Post subject: Where to get armrest adjuster plastic trim piece? |
I've tried searching the classifieds, as well as all the usual online shops, and I haven't found a source for the plastic trim-piece that covers the bottom-side of the armrest, where the adjuster knob sticks out.
1. Are these things available anywhere? Anyone got a spare?
2. Are they replaceable anyways, or is it a "rip the seat apart" operation to put another one on?
3. I didn't spot an obvious source for replacement armrests in grey...?
4. Or do I just source a "new" seat (yikes)?
I mean these black plastic bits (although this pic is from a eurovan):
_________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
joshtw709 Samba Member
Joined: June 01, 2017 Posts: 76 Location: austin, texas
Posted: Sun Feb 28, 2021 2:36 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
bumping this query as I also can never find replacement sets... _________________ 1980 rusty light blue westfalia - sold
1987 less rusty white westfalia - daily driver |
DuncanS Samba Member
Posted: Sun Feb 28, 2021 3:25 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
Cannibalize from a dead seat and be careful. They are fragile. First crank the adjustment knob all the way in. Then take a pair of piers and straddle the adjustment shaft behind the knob. With a hammer tease the knob off. It's a pressed fit on a shallow splined shaft. It just goes back on with no problems. Then you will see the two philips head screws. Take them out and remove the plastic part. I just redid the armrests and had to put some fiberglass on the area under the knob as the plastic had broken away and the screw had nothing to hold onto. Worked great. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Feb 28, 2021 3:47 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
djkeev wrote: |
Sounds like good candidate to be printed!
Someone here does this, send him a good one he can copy and get some new ones made.
Dave |
all mine are cracked and in pretty rough shape. obviously not a totally essential part, but like to chip away at bringing my van back to it's former glory and swap out cracked or damaged bits as i'm able to. _________________ 1980 rusty light blue westfalia - sold
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Mon Sep 13, 2021 10:22 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
very impressive find _________________ 1980 rusty light blue westfalia - sold
Posted: Tue Sep 14, 2021 4:56 am Post subject: Re: Where to get armrest adjuster plastic trim piece? |
I repair mine with epoxy and cloth on the inside. If there are gaps, blue tape so the glass will go over the space and then fair it from the outside after the epoxy cures. Rattle can and hand it in. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6355 Location: Honolulu,Hawaii and France
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sun Sep 19, 2021 9:56 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
and there is this
https://defunk3d.com/product/arm-rest-adjuster-trim/ _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Sep 20, 2021 5:32 am Post subject: Re: Where to get armrest adjuster plastic trim piece? |
John's Car Corner in Westminster, Vermont. A lot cheaper. |
Posted: Mon Sep 20, 2021 6:20 am Post subject: Re: Where to get armrest adjuster plastic trim piece? |
Thanks all for the leads. Been lowkey on the hunt for some replacements for maybe 4 years... _________________ 1980 rusty light blue westfalia - sold
Posted: Mon Sep 20, 2021 1:46 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
DuncanS wrote: |
depending on the day. i've know him for years and he's beginning to slip a bit. i reached out to him for a door panel. he wanted 700 that day. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Sep 20, 2021 7:54 pm Post subject: Re: Where to get armrest adjuster plastic trim piece? |
I had VERY bad luck with him years ago which cost me my modified 181 and another 1600 engine to boot. I would NEVER do business with him for anything over $25 as you could wind up on the short end like I did. |
