D Rock Samba Member
Joined: November 20, 2014 Posts: 76 Location: United States
Posted: Sat Dec 27, 2014 8:18 pm Post subject: Dog House Shroud Question? |
As I start changing my rail into how I want it to look, I want to give a nod to the VW bones.
I'm thinking about putting a Volkswagen script on the backside of my doghouse shroud visible just over the motor. I know it's air cooled and depends on airflow.
Do you think this would look good or would it cause a problem?
Brian Samba Moderator
Posted: Sun Dec 28, 2014 2:51 am Post subject: |
nah
the biggest thing that's causing a problem is that exhaust. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Dec 28, 2014 5:19 am Post subject: |
Brian wrote: |
nah
the biggest thing that's causing a problem is that exhaust. |
Weber Progessive and 009.
BTW... why does the engine lean to the left? _________________ Glenn
Member #1009
#BlueSquare |
Dale M. Samba Member
Posted: Sun Dec 28, 2014 7:10 am Post subject: |
Kinda wonder same thing as Glenn, why is engine leaning... Sort of indicates problem with "pickle forks" (engine/transaxle mount)... I would be more concerned with that than cosmetic mods...
Glenn Mr. 010
Posted: Sun Dec 28, 2014 8:38 am Post subject: |
Dale M. wrote: |
Dale |
Bent frame horns or broken mount.. agreed. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Dec 28, 2014 9:52 am Post subject: |
possibly even missing a mount. that is some serious lean.
Also yea, changing that carb and distributor combo you would be able to get some power out of the motor without having to mash the gas pedal. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
D Rock Samba Member
Posted: Sun Dec 28, 2014 11:06 am Post subject: |
Thanks for the reply's. A local VW mechanic took a look at it. He said there wasn't any motor or tranny mounts and that's what was causing the lean. I have the mounts and will put them in. Apparently, the PO ran without them.
By the title, he had it about 7 months. I've had it about 3 weeks. Gotta love PO's.
This is the best pic I had of the motor.
I changed the exhaust in the pic to a stinger that was in the extra parts that came with it, since the PO did a "custom job" to it. |
D Rock Samba Member
Posted: Mon Dec 29, 2014 11:03 pm Post subject: |
How many variations are there of the doghouse shroud? Any pics of the differences and what they are for? I'm thinking of powder coating the doghouse and my fins...any pics of this? |
D Rock Samba Member
Posted: Tue Dec 30, 2014 3:13 pm Post subject: |
Thanks!!!!
Where can I find out about the differences in the shrouds? I have several shrouds and fins that came with my rail. I would like to know if the one I have is the best one for my application or if I should switch to a different one. |
race-desert Samba Member
Posted: Tue Dec 30, 2014 4:31 pm Post subject: |
Maybe "tins"? |
D Rock Samba Member
Posted: Tue Dec 30, 2014 5:41 pm Post subject: |
These are my extra doghouse shrouds...Are either one better than what I have currently? What are they from? Do they wear out and need to be replaced to where I need to keep these?
What is this? Is it necessary? I don't think there is one of these on my motor now. Should there be? What did it come off of?
These are my extra fins/tins. would they fit like what I already have? Could I get them powder coated and swap the others out? Would they fit or are they specialized per model?
Thanks for all the info and thanks for bearing with me as I am very much a NOOB with about 3 weeks of ownership on a 1st VW... |
D Rock Samba Member
Posted: Tue Dec 30, 2014 5:47 pm Post subject: |
I cut the baffle down to fit my bobcat/stinger. I haven't taken any new rear pics since I changed exhaust. I had to cut the flange off of the baffle, but still used a set screw to hold it in place. |
Glenn Mr. 010
Posted: Tue Dec 30, 2014 5:54 pm Post subject: |
The yellow one is not a dog house shroud. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Dec 30, 2014 6:25 pm Post subject: |
Use the black shroud with the correct oil cooler. Either chop off those outlets on them or get some plugs for them. If you plug them, drill a small hole in the plugs to let it shoot out a little bit of air.
In this picture, you don't need either of these pieces but I would use the one on the far left, good place to hold your wrench or beer.
In this picture, you don't need the one in the middle. But you do need the other four.
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
D Rock Samba Member
Posted: Tue Dec 30, 2014 6:45 pm Post subject: |
OK. Black doghouse shroud, then which oil cooler is the correct one, any model numbers or brand?
So if I get these parts powder coated will I need to do anything special or should they bolt up? |
Posted: Tue Dec 30, 2014 7:37 pm Post subject: |
The one you need is offset like this:
I bought one here, but there is word that this isn't the best brand. I think the might be supplied by Meyle company and need to be pressure checked on arrival. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
D Rock Samba Member
Posted: Tue Dec 30, 2014 7:42 pm Post subject: |
Would it set in the shroud or outside? |
Posted: Tue Dec 30, 2014 7:54 pm Post subject: |
D Rock wrote: |
Technically its "outside" the shroud, but still get its air from shroud through its own set of sheet metal...
