HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Tue Jan 27, 2004 8:58 pm Post subject: offroaders are welders, maybe you can help |
i have a lincoln weld-pak 100. a wire feed welder. i recently purchased the mig conversion kit along with some 75 argon/25 co2 gas. the welds are much cleaner, but it makes a very pronounced popping sound. as i weld, it appears some of the wire is melting into a ball onto the end of the wire coming out of the gun. as the ball drops, it makes the popping sound. can anyone help me find a solution to eliminating that sound, because im pretty sure its not right. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
rlarkin Samba Member
Joined: November 10, 2002 Posts: 184 Location: Lodi, Ca.
Posted: Tue Jan 27, 2004 9:24 pm Post subject: |
Hold the tip 3/8" to 1/2" from the material.
Also try turning up the wire speed a hair. |
Also, what fo you have the regulator set at? |
Posted: Tue Jan 27, 2004 9:58 pm Post subject: |
i have tried all kinds of combinations of wire speed, amperage, and gas flow. the regulator is set at 15 currently _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Tue Jan 27, 2004 10:07 pm Post subject: |
Turn it up to 20.
What wire are you using? |
Posted: Tue Jan 27, 2004 10:12 pm Post subject: |
spool says .030" superarc L-56 _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Tue Jan 27, 2004 10:20 pm Post subject: |
Try some .023. Smaller wire works better with the smaller welders on light gauge.
And L56 is about one of the best so stick with it. |
Posted: Tue Jan 27, 2004 10:22 pm Post subject: |
the mig kit came with a small spool of .025? i'll give that a try in the near future. home depot didnt have any of the large spools of .025, so we got the .030 _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Tue Jan 27, 2004 10:29 pm Post subject: |
Don't forget to change the tip.
I would use a .023/.025 tip. The .030 would be a little big. The liner will be ok. |
DavidLH Samba Member
Posted: Wed Jan 28, 2004 4:40 pm Post subject: |
It is normal for solid wire to make that loud sound, compared to Innershield. You will have to experiment with heat settings and wirespeed to make proper welds. |
Posted: Wed Jan 28, 2004 11:15 pm Post subject: |
thanks alot, both of you. my dad went to a welding supply store and they said to turn up the wire feed. that turned out to be it. we messed with the other settings and finally got it to a pretty decent setting _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
