Corney13's '63 Beetle
coxbzh
coxbzh is offline
PostPosted: Tue Dec 05, 2017 4:32 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Corney13 wrote:
coxbzh wrote:
Hi Corney 13.
you do a magnificent job!
could you take a picture of your muffler odds wheel please. I would like to install the same but I have trouble visualizing the remaining space with the wheel
Thanks Wink
Sure thing! Here you go:
thanks a lot.
No risk for the tire? (heat)
Corney13
Corney13 is offline
PostPosted: Tue Dec 05, 2017 11:02 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
coxbzh wrote:
Corney13 wrote:
coxbzh wrote:
Hi Corney 13.
Thanks Wink
thanks a lot.
I wouldn't think so.
Corney13
Corney13 is offline
PostPosted: Fri Dec 29, 2017 11:29 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Getting some sun before the new year...
Corney13
Corney13 is offline
PostPosted: Tue Feb 20, 2018 12:56 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Finally got some decent weather to finish up some painting.
I repainted the fenders (Due to minor solvent pop) and the passenger side of the car (I sanded through the clear in a couple spots) I also painted the hood and deck lid and the last remaining little pieces. Unfortunately, the deck lid fell, so I will have to repair it and repaint. I will let the paint harden until next week, then I will color match bed liner the back sides of the fenders and color sand and buff everything.
I loosely placed some trim and the lights to see how it will look, I am happy with the results so far. It should look great once I sand out the orange peel.
Finally after 4 years of work, I will get to drive the car! Can't wait!
63Ragtop NZ
63Ragtop NZ is offline
PostPosted: Tue Feb 20, 2018 1:54 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Beautiful work man, you should be proud!
If you can't join them, beat them!
socal1904
socal1904 is offline
PostPosted: Tue Feb 20, 2018 4:16 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
That looks awesome!! Is that Anthracite or a different shade of gray? Looks like you should be tearing up the streets this coming summer!
Corney13
Corney13 is offline
PostPosted: Tue Feb 20, 2018 4:56 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Thank you!
Corney13
Corney13 is offline
PostPosted: Tue Feb 20, 2018 4:57 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Yes, it is Anthracite! I hope to be soon!
vwuberalles
vwuberalles is offline
PostPosted: Wed Feb 21, 2018 10:54 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Looks amazing, nice work!! That color is gorgeous.
Corney13
Corney13 is offline
PostPosted: Wed Feb 21, 2018 11:27 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Much appreciated!
EMPIImp69
EMPIImp69 is offline
PostPosted: Fri Feb 23, 2018 6:42 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Looking good, I'm jealous, I wish I was at the same stage of the game as you. I may do the Weber windows too.
1963 Ragtop Bug
Pruneman99
Pruneman99 is offline
PostPosted: Fri Feb 23, 2018 8:13 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Anthracite has got to be the best color on a bug IMO. That car is going to be awesome. Fantastic work Applause
Corney13
Corney13 is offline
PostPosted: Mon Feb 26, 2018 11:42 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Thanks guys!
I recommend the Weber windows. Makes it way easier!
Finished spraying the color matched bed liner under the fenders and got the hood polished. Looks great with the trim installed. This is this morning as I left for work.
Corney13
Corney13 is offline
PostPosted: Mon Apr 09, 2018 11:42 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
Been feverishly working to get her done. Here is the past few weeks of progress. I am hoping to be driving soon, but as you all know, everything tends to take 4 times longer then you expect, and these little cars like to fight you along the way.
Started color sanding and buffing the passenger door & quarter, driver's front fender and rear fenders. I can't tell you what a difference color sanding and buffing the clear coat makes! I have never painted a car before (Except my Rustoleum job on my old Baja). Being a novice, you get a lot of orange peal. I am getting better, but it is still very apparent I am not a pro. After I carefully sand and buff the clear, the results are impressive. Only real issue is that it is VERY time consuming!! But the results are definitely worth it...
I installed and wired the front headlights and turn signals, as well as the front bumper and fog lights. For the fog lights, I was going to install them under the over rider, but ultimately decided on above.
I installed the glass in the passenger door. Still hard, but easier then the first one I did.
I finally put the glovebox door on. I over bent the latch, so now it won't open. Rolling Eyes I will have to unbolt from the trunk and fix it.
I then moved on to tuning the engine. I synced the carbs and timed it. It runs pretty good, but I am going to take it to a Weber guru to fine tune. The Weber Windows I bought from Danny at Gab-Fab are awesome! Makes things much easier!
After installing the rear fenders, this is how she sits now (On a jack in the rear at the moment) This week I will install the rear bumper, install the rear gravel guards, tidy up some wiring and othe fine details, then it is off to Koch's for a new windshield and some fine tuning.
dodgerodder
dodgerodder is offline
PostPosted: Mon Apr 09, 2018 1:27 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Wow, just found your build-STUNNING!
Car looks awesome, you should be proud of what you’ve done
I’m just starting a 66’ build, what did you use for the bedliner in the wheel wells?
It looks great being color matched, did you tint the bedliner before spraying?
Thanks for the inspiration!
Corney13
Corney13 is offline
PostPosted: Mon Apr 09, 2018 2:06 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Thank you!
I used U-POL Raptor tintable bed liner. Here is the spec sheet:
http://www.raptorcoatings.com/files/3060/up4800-SDS-EN
I then went to the auto paint shop where I bought my paint and bought basecoat toner in the same paint code as my paint. (ask your paint supplier to leave out the binders). This is how it matches the paint color. It dries very hard and protects well. I did the underside of the fenders, as well as the entire trunk. I bought the kit with the sprayer. I got the 4 bottle kit and still have one left.
slave1pilot
slave1pilot is offline
PostPosted: Mon Apr 09, 2018 3:54 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
hurry up and get this finished. There's another '63 a little northeast that needs your help.
Very Happy
My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
Corney13
Corney13 is offline
PostPosted: Mon Apr 09, 2018 3:58 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Very Happy
LOL! Working on it!
dodgerodder
PostPosted: Mon Apr 09, 2018 4:04 pm    Post subject: Re: Corney13's '63 Beetle Reply with quote
Thank you!
Oh that’s right, forgot about the UPOL! I used that years ago on the underside of my Model A roadster.
Stuff is super durable, I tinted mine black. It still looks like the day I sprayed it. It’s been on there since 2010
I liked it because the texture is much smoother than the typical bedliner.
Thanks for reminding me, I can see I’ll be using it again years later haha
Corney13
Corney13 is offline
PostPosted: Tue May 01, 2018 11:25 am    Post subject: Re: Corney13's '63 Beetle Reply with quote
The bug finally left the garage / driveway for the first time since I brought it home in June 2014. Off to Koch VW in Acton for some buttoning up and to fix some of my rookie mistakes. I had to lift the rear back up to the stock height in order to get it on the trailer. I was going to take the time to index it properly by adjusting the inner and outer splines, but I am just going to let Koch do it. I always thought 1 outer spline equaled about 2.5 inches, but for me it is either ass high or 3 inches off the sump drain bolt. Not drive-able in my opinion. I will also have them raise the front. I am near full adjustment on the beam, so if they cant get it high enough, I may have to swap out my unused drop spindles for stock height spindles and just adjust off the beam. Goal is to have the tires basically in line with the fender line. Other than that, they will replace the windshield, add a dual circuit master cylinder and fine tune the carbs.
Here are a few photos before it left. Additionally, I finally got around to repainting the decklid after it fell.
Page 8 of 9
