Aerosport Samba Member
Posted: Fri Jan 02, 2015 9:16 pm Post subject: Drilling holes in roof rain gutters |
I am contemplating using an 8' x 10' tarp as an awning, by drilling 1/4" holes in the roof rain gutters and anchoring it by using stainless steel carabiners, though the holes in the grommets of the tarp and clipped through the holes in the gutters and aluminum adjustable tarp poles on the other end. This system will allow me to use it on either side and either the 8' or 10' side to the Van. May even be able to use it on the rear as well. I realize drilling the holes in the gutter will be a possible rust spot that I will have to take measures to protect, but wonder if there are any other possible negative effects of drilling holes in the gutter. Maybe water draining down the sides of van when it rains instead of running off the back, but I live in Vegas and we don't get much rain, so no big deal there. Anything else I need to consider, or wondering if anyone else has done something similar that required drilling the gutters. Appreciate any input anyone has. Thanks and Happy New Year to all. _________________ Stan L
'87 Westy GL - "Stanagon", 2wd WBX 4 speed
15" Rhein alloys, GW 1.5" lift springs & Fox shocks |
insyncro Banned
Posted: Fri Jan 02, 2015 9:18 pm Post subject: |
Use a Jorgenson spring clamp instead, your van will appreciate it. |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Fri Jan 02, 2015 9:20 pm Post subject: |
my awning is not mounted like that, however, the awning does protrude down into the gutter. this is annoying because often water will pour over the gutter at that point, either from a heavy downpour or by some debris causing a blockage. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
uncommonvw Samba Member
Joined: July 12, 2004 Posts: 230 Location: Jordan, ON Canada
Posted: Fri Jan 02, 2015 10:04 pm Post subject: Rain gutters |
Gee I did searches on rain gutters before posting and nothing came up, didn't think to search on tarp. The reason I thought to drill the holes and use the carabiners was for a nice clean setup with no bulky clamps to keep track of that can possibly come loose. The carabiners can stay attached to the tarp and it still folds up. Some what worried about drilling the 3 holes per side in the gutter, if it will weaken it too much or the seam starts to separate or warp I guess I could put small spot welds on both sides of the holes to strengthen it. Got the nice aluminum adjustable spring loaded tarp poles at Walmart for $ 8.00 each, and nice thing about the plastic tarps are that they have grommets every 24" and the entire setup gives me an 8 x 10 awning for around $25.00 _________________ Stan L
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Jan 02, 2015 10:31 pm Post subject: |
Somewhere there was a post about hillbilly chandelier hangers. I can't readily find it or the photos.
The idea was to use 3/4 PVC T's with a slot cut on the backside. The slotted T will readily fit over the rain gutter at the rear of the gutter and can be slid forward. For a tarp or sunshade netting, they can be placed between the front and sliding door, behind the sliding door and at the rear and connected together with more T's and PVC pipe. This is a nondestructive approach. I use it for attaching a hanging sunshade with spring clamps, but it may not be suitable for a tarp or strong enough for windy conditions.
Aloha
tp |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Sat Jan 03, 2015 6:28 am Post subject: |
Look into the go westy gutter clamps. You can use those with your tarp and a piece of pvc and not have to drill any holes. _________________ _________________________________
82 Diesel Westy |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Jan 03, 2015 6:57 am Post subject: |
Just for discussion...
I remember a post about attaching a tarp under the metal channel of the canvas
top - roll it up under the poptop for storage, always ready to roll out for awning...
This? (from page 3 - http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=40 )
midmo81 wrote: |
Just finished my DIY awning. PVC tube cut in half, hinges, clasps, end caps, poles, homemade brackets, and a little paint to match my camper. Poles roll up in the tarp to travel. All under $50.
Off to the State Park.
Or this...(from page 2 - http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=20 )
davevickery wrote: |
Not necessarily recommending this, but it was cheap to make. I had a real case awning on my last van, and they are nice but I am going to see how well this does. Tucking the tarp under the poptop attachment rail limits you to a 7' width so it is small, mine is only 5x7 but I could have gone 8x7. It rolls up and tucks under the poptop.
It should be o.k. in the rain. I had a previous tarp that I just bungied to the van and it worked ok and this one is much more taught. It is a waterproof nylon tarp with eyelits in the corners. The tent poles raise up to whatever level you want. I got them from Walmart or Sports Authority for $6-7/ea. Water can't get through the tarp, so one side has to be higher than the other to keep it from pooling. I think I can also raise the front end and let water run back towards the van and into the rain gutter.
It won't stay up in really high wind, but nothing terrible happens, the legs just fall out from under it and it flaps around until you roll it up. After I slid the tarp under the poptop rail, I added a piece of string to tie it up when it is rolled up. It doesn't get in the way of the poptop closing.
The tarp has folded seams at all the edges. I cut a little hole in the fold and slid a fiberglass tent pole into the front edge to make it easier to roll up and also make it more of a rigid front edge. You don't really need it if you just pull the ropes tight. I also just got 2 short pieces of PVC tube and 45 degree elbows on the end to slide into the jack mounts and mount the legs into, like the brackets that real awnings use. |
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
midmo81 Samba Member
Joined: September 23, 2012 Posts: 114 Location: Columbia, Missouri
Posted: Sat Jan 03, 2015 3:47 pm Post subject: |
The 7x9 tarps are only about six bucks. I tried a brown then camo , had the blue one on all summer, but think silver will be next. While these make good fair weather covers, sudden high wind is a panic. _________________ 1981 AC Westy |
campism Samba Member
Joined: September 07, 2007 Posts: 4485 Location: Richmond VA
Posted: Sat Jan 03, 2015 5:12 pm Post subject: |
I drilled mine on the passenger side in order to install awning track, into which my dining fly's awning rope is inserted. You can see the white track in the rain gutter in this pic, and several of the fasteners holding it in place. Here's the link to my awning install.
https://picasaweb.google.com/bike2vcu/AwningProject#slideshow/5257374425339420306
_________________ '87 Westy in Wolfram Grey Metallic |
