guzyk Samba Member
Joined: September 23, 2004 Posts: 82 Location: Boulder, CO
Posted: Sun Jul 16, 2023 4:05 pm Post subject: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
Previous owner installed 16" alloy wheels with 215/65R16 Goodyear Assurance Tires. Tires are around 10 years old and cracking.
What would you replace them with in 2023 if this was your camper? |
calsurf Samba Member
gryffon Samba Member
Posted: Sun Jul 16, 2023 8:50 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
Just installed Sumitomo HTR A/S P03 215/60R16 on my 1989 Westy full camper. Replaced Nokian Entyres that had bad cracking in same size. Took it for a cruise yesterday and really like the ride. Quieter and smoother ride than the Nokians. _________________ Oakley, CA
71 Ghia Convertible, 74 Thing, 67 Beetle, 65 Notchback, 89 Westy, 71 Squareback
Meyers Manx 1 - Teal, Meyers Manx 1 - Gold, Meyers Manx 2 - Blue, Welmac VW Trike |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Sun Jul 16, 2023 8:53 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
I just put on BFG AT.....again. I looked at so many tires, but I always come back to BFG. If you're doing any kind of dirt road or gravel driving, that's what I'd use. I don't drive in the snow so that wasn't a consideration for me. I think if your going to be driving n the snow, a dedicated winter tire is what I'd switch to seasonally. _________________ 89 Westy 2.1 Auto |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Mon Jul 17, 2023 8:03 am Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
Choose a tire that is readily available anywhere. _________________ ☮️ |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Mon Jul 17, 2023 4:58 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
Stock engine? Planning to run separate snow tires in the winter? Your current tires are over an inch wider and taller than what was originally on your Vanagon. Your choice should be based on your driving needs and engine capability. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
airshipper Samba Member
Joined: December 04, 2014 Posts: 10 Location: Akron, Ohio
Posted: Sun Jul 30, 2023 11:20 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
I'm running the 215/55/16 XL load-rated Goodyear Assurance WeatherReady tires, I used to run the 215/60/16 older Assurance TripleTred's. Both of those sizes are closer to stock tire height. My pop top would lightly touch the top of my garage door with those as I pulled in. I'd go shorter, especially if you have a stock engine or auto transmission. There aren't too many decent options from the winged foot brand for our Vanagons, but if you are going to go to that route, DM me for a discount code. I also carry a full-sized spare with the Van Cafe carrier.
Although if you are happy with the 215/65/16 size, a lot of people like the BFG KO2's (great off-road and excellent D load rating, but expensive) or Yokohama Geolanders. The Goodyear Assurance WeatherReady tires (98 load rating) are also available in that size, but I'd go with the 215/55's, especially if most of your driving is on the road. If you do a decent amount of off-roading, I'd go with the taller BFG's. _________________ '84 Bostig Westy Wolfsburg Auto |
Matt Edick Samba Member
Joined: October 27, 2012 Posts: 1 Location: Santa Barbara, Ca
Posted: Thu Apr 18, 2024 4:52 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
Kumho Crudgen HT51 215/65/R16 is XL rated. Been happy so far. Good pricing. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6560 Location: Westfalia, Earth
Posted: Thu Apr 18, 2024 8:46 pm Post subject: Re: Tire advice wanted for 16" GoWesty wheels on an 87 Full Westy? |
PDXWesty wrote: |
I just put on BFG AT.....again. I looked at so many tires, but I always come back to BFG. If you're doing any kind of dirt road or gravel driving, that's what I'd use. I don't drive in the snow so that wasn't a consideration for me. I think if your going to be driving n the snow, a dedicated winter tire is what I'd switch to seasonally. |
Exactly my take.
I was quoted $1,670-something for four mounted and balanced last May, size 215/65-16, D-rated.
Instead, I paid $1,004 delivered to Lander, Wyoming from TireRack.com, and $100 for local mounting and balancing.
Carter is an excellent Rep, (888) 727-8092 ext. 4661. He’ll remember me from re-naming him “Karter,” as in go-karting. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
