dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Jun 27, 2018 1:02 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Yeah but might have a buyer for my mk5 tdi instead. So it may stay in my hands a bit longer... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Jul 04, 2018 2:31 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
4th of July project in progress...:
New syncro shocks and springs: (the taller ones in the pics)
This booger of a bump stop had to go in after the springs went in on both sides...these springs took some creativity to work the spring compressors around the vans boxy rear suspensions stuff...
Working on the fronts now... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Abscate Samba Member
Posted: Wed Jul 04, 2018 3:35 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
You need to get that Westy to SFO where money flows like Niagara Falls and
#ihatemylifeworkingforcriminalswellsfargobutTheypaymealotSoimasuckerforavWvan,bus
Abounds _________________ .ssS! |
Posted: Sat Jul 07, 2018 10:10 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Got my big tires on with the rear lift...getting close to the look I want!
And the rears:
206-841-7324
[email protected] |
Posted: Sat Jul 07, 2018 8:15 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Found a new battery cable at the junkyard today. Who buys a used cable???!?
I did.
This thing is 3 times as thick as my cable, as flexible as welding wire, and it’s got a VW part number.
And it was $3.
I’d call it a solid win. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Pinetops Samba Member
Posted: Sun Jul 08, 2018 5:54 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Are you worried about those tires slowing your van down? I went just 3.3% taller than stock and I can feel a difference. Rolls, tracks and looks better but it's slower.
I like that stout battery cable! _________________ "A rolling bus gathers no rust." |
Posted: Sun Jul 08, 2018 8:51 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Pinetops wrote: |
I like that stout battery cable! |
For SURE these are terrible for the van. Way to tall, very slow, out of balance and pull hard right, and hum at speed.
But at low speed the traction and clearance is fantastic!
It’s getting general grabber at2 tires 27x8.5x14LT. They make the speedo accurate and I love how they drive for the price. Should fill the wheel well plenty.
And I have 6 or 7 of that Michelin LTX in a stock size to play with...old and Dry but all hold air and roll great! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Jul 08, 2018 9:09 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
I can dig that.
One other nice thing about a taller bus/vanagon is how easy they are to get under to work on. _________________ "A rolling bus gathers no rust." |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Jul 09, 2018 7:02 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Stuart, I'm glad I found this thread (just recently started checking out the vanagon forums) Misty will be missed, but long live Corky! I love the look and dig the use of a used cable (old cable can be better than some of the new stuff). _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Mon Jul 09, 2018 8:02 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
I don't see your jack stands and safety blocking, but Im taking it on faith you are using them. If you arent, I will call your mother and she will bitch slap you
I DO have her number, too.
I love you , man. _________________ .ssS! |
Posted: Mon Jul 09, 2018 12:16 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Abscate wrote: |
I love you , man. |
It was only jacked up for sleeping level in it. New front springs get here this afternoon around 3, and then it will be a non issue _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Jul 10, 2018 6:56 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Found a bad wheel bearing. This has less then 6 miles since the noise started..I promise!
206-841-7324
[email protected] |
Posted: Wed Jul 11, 2018 2:35 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Dang. It sounds like you reassembled the bearings with sand instead of grease. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed Jul 11, 2018 3:52 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
That’s sounds dry. You can get another 5000 out of it with just lube I bet... _________________ .ssS! |
Posted: Wed Jul 11, 2018 9:42 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Spike0180 wrote: |
Dang. It sounds like you reassembled the bearings with sand instead of grease. |
Yeah except I never did these. I think driving it backward from Cali did it. These wheels were the ones on the ground. Also found a shot inner tie rod on the left and a little wear on the right. Gonna toss a new inner and out on the driver side, and a new speedo cable (broke when I installed the spring while I was figuring everything out) and call it good.
Lifted the front with moog 5660 springs but not happy with the result so gonna add some spacers and go for 19” rather then the 16.5 I got. Gotta do research and get creative! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Jul 11, 2018 9:51 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Nah. Rollers won't care which way they turn as long as they lubed.
They just wore out from years or the grease leached out. _________________ .ssS! |
Posted: Wed Jul 11, 2018 11:23 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Abscate wrote: |
They just wore out from years or the grease leached out. |
It got hammered with the bad inner tie rod on that side while rolling backwards for 1500 miles, I think that’s what did it _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Jul 13, 2018 3:45 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Have some guests staying at the house:
Waxed a side to see what it would come back to...pleasantly surprised it came back nicely! Gonna wash it and finish it later...
Replaced my left front wheel bearing, found it rusty. Determined it was the speedo cable hole causing the leak. Been bad for a while but never heard any noise! Weird.
Put the upper ball joint spacers on I got from Kwilk, gowesty brand. Thanks kim!
Put the alloys back on and swapped the spare out with a matching Michelin LTX on a steel wheel. Stock size 195/75/14.
Now the lift is more noticeable!
206-841-7324
[email protected] |
