Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Aug 03, 2018 12:37 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Replaced the fuel pump with a spare. No change. Also noted I’ve gotta switch back to the first harness style as the body harness doesn’t match on the double relay. More info when I can dig into diag properly in a few weeks. New job and out of town and I’m slammed.
On the plus side I installed the LED rope light from my 78 into the engine bay. So much better for later evening wrenching or roadside repairs...
_________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Aug 03, 2018 8:26 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Here’s the ECU and double relay I was speaking of:
On the left is original 80, the right is a 78 style that I got off a vanagon motor:
This pic sucks:
This is the 78 style:
And this is a 80 style:
And the pair:
206-841-7324
[email protected] |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Aug 03, 2018 10:58 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Stuartzickefoose wrote: |
A spare used pump?
Get a gauge on it yet? Did you check the flow from the tank or did you just throw another pump at it? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Sat Aug 04, 2018 10:55 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
looks like the ol' 13 vs. 11 pin double relay.
they both look like later replacements to me...
this is getting painful to watch, stu. get a fuel pressure gauge on there _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Tue Aug 07, 2018 7:40 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Figured it out....
Updates shortly _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Aug 07, 2018 11:52 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
So...swapped back to my original FI setup, with the 13 pin double relay. Fired right up. Fuel pressure at 35 psi. New clean connectors on the fuel pump, all clean and tight on fuel lines (found a few loose ones...) pretty sure as soon as it got warm I had not fully dried the ECU. 3 weeks later it was good and dry.
Went ahead and took a cruise with my buddy in his lower d 70. Had dragging brakes and after new soft lines and a proper adjustment, he needed to put some trouble free miles on it before he takes it to the great Canadian VW show this weekend in Vancouver. So we put about 25-30 miles on it, got it dialed in great, and got mine all hot and stuff to burn off assembly messiness
See my new engine lights? Still working on those license plate lights but whatever...
206-841-7324
[email protected] |
Posted: Sun Aug 12, 2018 6:58 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Packed up and ready for Portland!
Canned lighting!
Got there, and pulled into a rest stop to check some things...
Found my issue ...
The harness was shorting against the block where I couldn’t see it...broken harness causing nearly all the issues. So I had re routed things...and they shorted out while I was running some tests.
Yeah dead short 12v to the fuel rail. Fabulous.
Fixed that issue and determined it melted my double relay (13 pin California model!) (which is the entire issue I was fighting...California vs federal parts)
See the contacts?
Then did a valve adjustment and checked head torque. Left head came WAY loose ...so I’m pulling the tin tonight or tomorrow to retorque. Not happy with the engine AT ALL...but gotta make it work so I’ll make it work.
In other news...:
Liked this sign:
And the dog here’s not to bad either...:
I’m beginning to hate this van very much.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Aug 12, 2018 7:03 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Also, changed the oil and put in 20-50 vr1 valvoline high zinc oil. Set the timing and replaced cap and rotor. Picked up a set of bumpers and some wheels and tires. Plenty to do in the next few days... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Aug 12, 2018 9:34 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Aaaaaand posted for sale in the classified. Engine pulled back a 80-80-140-50 compression test, I’m done trying. I don’t have time, I don’t like this van, and I’m ready for it to be out of my way.
https://www.thesamba.com/vw/classifieds/detail.php?id=2201688
If your following along this thread and say so I’m happy to give you a smoking deal. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
elizer Samba Member
Joined: May 02, 2016 Posts: 1461 Location: Northern Virginia
Posted: Mon Aug 13, 2018 6:14 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Good luck with your next venture. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Aug 13, 2018 8:05 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
_________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Sat Aug 18, 2018 3:52 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
You guys seemed so depressed and disappointed I figured I would do a autopsy...
Estimated 500 miles. 3-4 fuel ups and none were full tanks.
And yes I ran headgaskets. I want the lower compression. I know I didn’t need them. I like them.
But this time #4 didn’t even try to seal right.
Details when I pull cylinders and hand them back to Jerry for a inspection. Last time I use him for VW parts. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Wed Sep 05, 2018 6:09 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Reme'ber to kick back some cash to the lady who donated it...good karma
- Grandpa _________________ .ssS! |
Posted: Thu Sep 06, 2018 7:09 am Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Pft. With only 500miles, throw 'em back on and run it. Maybe it'll be fine. They look fine. Might save you from selling the van. and get you to Alaska and back. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Thu Sep 06, 2018 2:09 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Spike0180 wrote: |
Pft. With only 500miles, throw 'em back on and run it. Maybe it'll be fine. They look fine. Might save you from selling the van. and get you to Alaska and back. |
I can’t find the pics I took but the #4 piston totally fried. Complete and utter overheated mess of scraped up crap. Gonna call the machine shop in a few and find out what they said.
My estimation is that when they cut the heads, and messed up the geometry of my engine...the rockers on 4 were sitting on the edge of the valve springs and held them open. Add that to much to far advanced timing, and a engine harness shorting out....it will be better next round and I’ll be sure to shim the rockers this time BEFORE I leave town...
This is not a Hasta Alaska adventure...mofo, I can’t afford 13 engine rebuilds!
Looking like if it goes back together and runs properly when it is all dialed in, I’ll be holding onto it for a bit...
If only I could trade rims and tires for engine stuff...only have about 25 rims and tires left to sell from vanagon...I only have the one van! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Sep 28, 2018 10:21 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Got stuff back in my hands...only to realize I was a few head gaskets short...(had 2 2.0, and 6 1.8 gaskets!)
So I got the pistons in and cylinders at least!
Hoping to grab gaskets and finish assembly when I get back next week....
Also ordered new engine lights as these are very tired. New ones claim 1200 lumens in a 15 foot rope...should be a nice improvement!
206-841-7324
[email protected] |
Posted: Sun Oct 07, 2018 10:39 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Well, after a small party from mom celebrating her son made it to 26.... I moved the van over to the carport for final assembly. Not wanting to dive in tonight....I tackled a easier project...lighting
First made sure it worked...
Then ran it along the opening of the pop top, self stickied to the smooth surface the whole way, hopefully it holds!!!
Then tied the dimmer into the dome light (the blue light) so it comes on when the front doors open, and can be turned on while camping too. And it’s dimmable, so easy to knock down the intensity later at night!
All day tomorrow is engine building time...off to bed for a full nights rest! Since I sold my tdi yesterday, this things gotta get me to SoCal Tuesday evening...(arrival Thursday, leaving Tuesday...) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
rag63 Samba Member
Posted: Mon Oct 08, 2018 7:27 pm Post subject: Re: Corkey! The 1980 Westfalia Vanagon |
Stuart,
Glad to see you sticking with the '80 AC Westy.
I've followed your thread.
I'm close to getting through my recent to do list on my '81 AC Westy.
We gotta keep the aircooled's on the road!
Cheers,
Dave |
