Help Identifying a Broken Steering Column Bushing
Page: 1, 2, 3, 4, 5  Next
vamram Premium Member
vamram is offline
PostPosted: Mon Jan 05, 2015 8:08 am    Post subject: Help Identifying a Broken Steering Column Bushing Reply with quote
I was replacing the turn signal switch on my '72 Super and this fell to pieces w/in the column. I couldn't identify it, but I guess it's a bushing of some kind, just not sure what to get as a replacement.
Thanks!
Victor
Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
Mr.Duncan
Mr.Duncan is offline
PostPosted: Mon Jan 05, 2015 8:12 am    Post subject: Reply with quote
im interested too.
Same style one (broken) fell out of my 71'
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
Jeff_Birt
Jeff_Birt is offline
PostPosted: Mon Jan 05, 2015 8:23 am    Post subject: Reply with quote
This perhaps: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=175419341A
Mr.Duncan
PostPosted: Mon Jan 05, 2015 8:24 am    Post subject: Reply with quote
Good work Jeff.
That looks just like it!
1966 Ghia (sold)
1966 Red Beetle
vamram is offline
PostPosted: Mon Jan 05, 2015 8:40 am    Post subject: Reply with quote
I thought that as well, but the busted one doesn't have any ribs....still think that's it?
Click to view image
Save the Supers!!
Mr.Duncan
PostPosted: Mon Jan 05, 2015 8:44 am    Post subject: Reply with quote
My 71' had the ribs.
Maybe it's universal?
I'd call WW and check.
1966 Ghia (sold)
1966 Red Beetle
vamram is offline
PostPosted: Tue Jan 06, 2015 4:45 pm    Post subject: Reply with quote
Thomas, I emailed the picture to WW and the guy who answered couldn't identify the part. What I can say is that after re-installing my turn and wiper switches and steering wheel, my steering lock no longer works. Is there an additional bushing or piece that works w/the steering lock that may be what busted?
Thanks,
Victor
Click to view image
Save the Supers!!
vamram is offline
PostPosted: Tue Jan 06, 2015 6:19 pm    Post subject: Reply with quote
You can see the busted piece/bushing in this picture - follow the red arrow.
I can confirm that it's what's missing now. It appears to go over the ribbed bushing you linked from WW's site.
Click to view image
Save the Supers!!
Jeff_Birt
PostPosted: Wed Jan 07, 2015 1:31 am    Post subject: Reply with quote
Sounds like your missing part of the turn signal canceling ring.
green1303
green1303 is offline
PostPosted: Wed Jan 07, 2015 7:07 am    Post subject: Reply with quote
I recently gave someone some bad advice on this question, so I offered to reimburse him for the part that he had bought, and he refused like a gentleman. Here is the thread, which should answer your question.
http://www.thesamba.com/vw/forum/viewtopic.php?t=608983&highlight=
See also:
http://www.partsbase.org/vw/vw-1200-1300-1302-1303...ring-tube/
1973 green Super Beetle
vamram is offline
PostPosted: Wed Jan 07, 2015 7:20 am    Post subject: Reply with quote
Green- that's it! Either 1 or 1b. Now to hunt it down. thanks!
Victor
Click to view image
Save the Supers!!
vamram is offline
PostPosted: Thu Jan 08, 2015 7:36 pm    Post subject: Reply with quote
Found a good picture of it on another post here, borrowing it to show. It's the yellowish item circled below, goes over the ribbed bushing and below the circlip.
Any ideas where I can get one?
Thanks!
Victor
Click to view image
Save the Supers!!
talljordan
talljordan is online now
PostPosted: Fri Jan 09, 2015 2:27 am    Post subject: Reply with quote
Ive said it before and ill say it again. I don't think this spacer is actually necessary. I have one and have 0 up/down, left/right, or in out play. I am however running one of the newer WW upper bearings with the plastic contact ring. I placed it with the plastic ring facing inwards so that it didn't work itself up and loose.
I dont have one of those spacers and to date have 0 issues.
1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end
Jeff_Birt
PostPosted: Fri Jan 09, 2015 5:21 am    Post subject: Reply with quote
So your saying VW included a part in the steering column for no reason? Must have been the same engineer who included all those cooling tins that aren't really needed. Very Happy
vamram is offline
PostPosted: Fri Jan 09, 2015 5:29 am    Post subject: Reply with quote
x2 Very Happy
Click to view image
Save the Supers!!
peteandvanessa
peteandvanessa is offline
PostPosted: Fri Jan 09, 2015 9:39 am    Post subject: Reply with quote
I battled this issue a few months back on my 74 Standard Bug (my thread is referenced above). Some say that they have no issues NOT having that spacer in their steering column, but with mine it was an issue, with too much in/out (meaning towards and away from the driver position) play on the steering column.
Here's the diagram:
1A in the diagram above is the anti-rattle bushing, which is easily sourced on-line, some are plastic and some are metal.
1 in the diagram above, is a plastic spacer that helps to hold the anti-rattle bushing in place, Item 1 goes above the anti-rattle bushing and then a C clip holds it in place. Without (item 1) it on my Bug the steering has way too much play in/out play and the anti-rattle bushing would work itself loose causing even more play in the steering.
As far as I'm aware, 1 is not available to purchase, so I had to improvise. I used some plastic pipe cut to the correct length to use as a replacement spacer (see my thread above). Once that was installed, the anti-rattle bushing stayed in place and the in/out play was gone.
Now mines a 74 Standard Bug and I needed part 1, but for later Bugs (74 1/2 and up ) I think you need the later spacer which is 1B, you might also need spacer 1 as well (I can't confirm since mine's a 74 Standard Bug)
My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189
Last edited by peteandvanessa on Fri Jan 09, 2015 10:20 am; edited 6 times in total
bnam
bnam is offline
PostPosted: Fri Jan 09, 2015 9:55 am    Post subject: Reply with quote
My understanding is that 1A and 1B are for the '74 on cars and are to be used together. 1 is for the earlier cars (without 1A). I wonder if 1A+1B can be used on pre-74 cars?
vamram is offline
PostPosted: Fri Jan 09, 2015 10:14 am    Post subject: Reply with quote
Pete&Vanessa, thanks for the info. I'll be looking at your threat this weekend, it's looking like making my own is going to be the way to go.
Victor
Click to view image
Save the Supers!!
peteandvanessa
PostPosted: Fri Jan 09, 2015 10:25 am    Post subject: Reply with quote
Victor
It might be that you can use this spacer from 74 1/2 and upwards and just cut it to length to fit on bugs built before 74 1/2
http://www.airheadparts.com/vintage-vw-parts/steer...-171419549
vamram is offline
PostPosted: Fri Jan 09, 2015 10:55 am    Post subject: Reply with quote
peteandvanessa wrote:
Victor
Awesome, i just went to your thread. Very cool over all. What do you think about this part from WestCoastMetric?
https://www.westcoastmetric.com/product/111-603B/s...m_search=1
Click to view image
Save the Supers!!
Page 1 of 5
