cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Wed Jan 14, 2015 4:59 pm Post subject: |
hey guys, well i have all the different types of welders there is, so no problems with welding things on.
I bent the bail spring in last night, and it is much tighter now, like on the old engine, so it felt a lot better putting it on. So hopefully this is a simple problem.
I took it out for a short drive today, only getting up to 50 mph for a short time though. I didn't want to test it to much, as our truck is in the shop right now haha _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
Posted: Sun Jan 25, 2015 10:40 am Post subject: |
So.. We finally got our truck back which meant it was time for a free way test drive.
Sadly, after about 15 miles at 70mph it once again started to leak
It did make it farther then previously tested, but it still leaked a lot. I emailed the previous owner of the engine, and he said he never had any problems with it leaking...
So, more thoughts? This is very frustrating _________________ 71' Super Convertible (Orange)
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sun Jan 25, 2015 10:47 am Post subject: |
Weld on tabs _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun Jan 25, 2015 10:51 am Post subject: |
Did you try just buying new valve covers and bales instead of fighting with your old ones? I used to use the red Permatex RTV around both sides of the gaskets. The red one comes off cleanly when it's time to replace. I used a very small bead. Give it time to dry, and it should fix your problem WITH NEW COVERS. I'm not there to see your current covers, so I can't say what's going on with them. I think you said that you had a welder? Well have you tried to weld on the gasket retainers? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
maui Samba Member
Posted: Wed Jan 28, 2015 1:03 pm Post subject: |
Try ultra gray sealant |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Wed Jan 28, 2015 1:30 pm Post subject: |
cjsuner wrote: |
So, more thoughts? This is very frustrating |
When were you going to consider welding the tabs in? I don't know how you can even be frustrated? I've put them in covers that never needed them just for fun. That, and... needing a tow or roadside repair for the stupidest reasons piss me off more than the average guy, I guess. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Wed Jan 28, 2015 4:22 pm Post subject: |
The tabs havve been welded in, but have not had the chance to do another long test drive _________________ 71' Super Convertible (Orange)
eguti66 Samba Member
Joined: July 21, 2004 Posts: 260 Location: Stockton,CA
Posted: Sun Feb 15, 2015 10:52 pm Post subject: |
Any updates? I had to get towed home today for the same exact failure. Did the welded in tabs help? _________________
drscope wrote: |
Ummmm, if you can't find out where the hole is by feeling around, then FORGET about installing the light! |
66 beetle
65 karmann ghia
58 beetle
58 convertible beetle
64 11w standard
68 Squareback |
Posted: Tue Feb 17, 2015 2:44 pm Post subject: |
eguti66 wrote: |
Any updates? I had to get towed home today for the same exact failure. Did the welded in tabs help? |
Sorry it happened to you, totally sucks right?
Ya, the welded tabs seemed to have stopped the problem completely, which is great!
hopefully it will work for you also! _________________ 71' Super Convertible (Orange)
mbw65bug Samba Member
Joined: December 19, 2013 Posts: 25 Location: Japan Hokkaido
Posted: Sun Jul 05, 2015 9:09 pm Post subject: |
I'm sorry, I resurrected this thread.
I'm working on a new motor now then I happened to find this thread.
I appreciate the ideas had been told here and interested in adding tabs on my own, but I was afraid if I would screw up head covers due to my poor welding skill.
So I decided bolt tabs instead.
I made the height of tabs slightly below the surface of the gasket so the gasket will be sandwiched property even after it get squished.
I'm looking forward to seeing how these work.
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Jul 06, 2015 8:31 pm Post subject: |
mbw65bug wrote: |
How/what did you use to seal the screw areas with? They could end up being potential leak source.
Where in Hokkaido are you? I'm back and forth between Shizuoka-Fujieda 2-3 times per year. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Mon Jul 06, 2015 8:59 pm Post subject: |
udidwht wrote: |
Where in Hokkaido are you? I'm back and forth between Shizuoka-Fujieda 2-3 times per year. |
I live in Sapporo city.
I used Loctite thinking that it could be loosened by vibration. But silicon sealant might have been better, I don't know. Compared with ending up with getting oil dumping, it's not a big deal anyhow. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Tue Jul 07, 2015 1:28 pm Post subject: |
Those rocker covers in the pictures are not stock - they do not have the locating groove for the bale spring in them. Whatever system holds them on is probably not providing enough pressure to squash the gasket onto the head.
Maybe getting a set of Bugpak black painted steel stock pattern covers and bale springs will cure the problem. And then play with drilling breathers in those covers.
I found on my setup that the rusty springs my engine came with were just too thin to press the gaskets down hard enough. _________________ Ancient vehicles and vessels
Chupa7hingy Samba Member
Posted: Sun May 02, 2021 2:22 pm Post subject: Re: Valve cover gaskets getting sucked up (updated, Pg. 3) |
Posted in error |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon May 03, 2021 8:05 am Post subject: |
anthracitedub wrote: |
Weird, I have never in my 20 plus years ever had to glue a cork valve cover gasket on.... Clean/dry/stock.... No leaks, no issues ever.
I bought a used engine and someone glued the gaskets to the covers... What a pain, it took almost a hour to clean them off.... Must of been one of you guys old engines.😊 |
Me either. I never glue them.
If you have an issue and want them to seal, install the gasket on a HOT head. It will bond right to it..
No need for sealants.
I even use aftermarket valve covers. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon May 03, 2021 3:47 pm Post subject: |
Ohio Tom wrote: |
Weird, I have never in my 20 plus years ever had to glue a cork valve cover gasket on.... Clean/dry/stock.... No leaks, no issues ever. |
Me either. I never glue them. |
No leaks for me either. I just use cork gaskets, factory valve covers that came on the vehicles. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue May 04, 2021 4:22 am Post subject: Re: Valve cover gaskets getting sucked up (updated, Pg. 3) |
with "Stock engine' not an issue ,, rev that sucker to 6 K and see what happens _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Tue May 04, 2021 5:30 am Post subject: Re: Valve cover gaskets getting sucked up (updated, Pg. 3) |
madmike wrote: |
with "Stock engine' not an issue ,, rev that sucker to 6 K and see what happens |
I do (7,000rpm)... every time I drive them...
No joke..
As stated, It is important to let the gasket get hot and stick to the head.
Then you are safe for higher rpms.
Folks will figure it out eventually. |
LucKaS Samba Member
Joined: December 25, 2015 Posts: 170 Location: Alabama
Posted: Tue May 04, 2021 8:28 pm Post subject: Re: Valve cover gaskets getting sucked up (updated, Pg. 3) |
I had the same problem with my 1904. Anytime I got on it a little bit the gasket would get sucked up and I would spew oil everywhere. My fix was venting the valve covers, haven’t had a problem with it since then. _________________ If only all of life's little problems could be solved with a little PB Blaster and a hammer. |
Posted: Wed May 05, 2021 4:35 am Post subject: Re: Valve cover gaskets getting sucked up (updated, Pg. 3) |
Not u Tom,, I've seen you Drive, _________________ 'Black Ice'Drag Buggy 'Turbo'
