Xevin Samba Member
Posted: Fri Jan 09, 2015 10:48 am Post subject: 72 Campmobile interior question |
Looking for a pic or explanation of what went in the two holes above the Z bed on the driver side. Between the windows I have two holes. What are they for? A strap like on the closet side, a knob to hang stuff, blank cover, or?
Thanks, can take a pic if needed.
70westie Samba Member
Posted: Fri Jan 09, 2015 11:00 am Post subject: |
Probably be best to take a pic.. My guess would be a pull strap.
-70 |
Xevin Samba Member
Posted: Fri Jan 09, 2015 11:31 am Post subject: |
These two holes.
rshepard10 Samba Member
Posted: Fri Jan 09, 2015 11:48 am Post subject: |
Yea thats for a pull strap
I think Wolfsburg West sells them _________________ 1978 VW Deluxe 2000cc FI
1994 Jeep YJ (Jurassic Park #22)
Certified Diagnostic Mercedes-Benz Technician |
Xevin Samba Member
Posted: Fri Jan 09, 2015 12:03 pm Post subject: |
Does anyone have a picture of there's. I have an extra assist strap identical to the one on the closet. Not sure it is correct for that side with two holes.
Thanks. |
Malokin Martin Samba Member
Posted: Fri Jan 09, 2015 12:12 pm Post subject: |
Were those even on campers there?
I have a westy that has the holes but no strap also. Same deal.
I just assumed it was the "passenger bus" metal stamping they used that retained the holes, even if they weren't going to be used. |
Tcash Samba Member
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Fri Jan 09, 2015 12:22 pm Post subject: |
Good chance there was nothing there to begin with. That is a standard threaded mounting boss installed on all bus bodies for all versions of the type 2 bus. Funny thing is one of those grab straps is factory mounted to the closet cabinet on the sliding door side of my 71 Westie but not on the other side. There is nothing there like on yours. I don't think any of my past campers had one there either. All though the passenger versions had them as a convenience for passengers scooting around the middle seat while getting into the back seat.
I think they were put in more for people to use while getting in and out of the bus than to hang onto while the bus is in motion. No left side rear door ergo no grab strap for getting in and out with.
Mi Dos centavos. |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Fri Jan 09, 2015 12:31 pm Post subject: |
Early '73's had the assist straps:
_________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Posted: Fri Jan 09, 2015 12:38 pm Post subject: |
From the 1973 brochure also, so it did have them by then (albeit its the Canadian flavor brochure).
http://www.thesamba.com/vw/archives/lit/1973_bus_c...Canada.pdf
There wasn't a clear picture of it on the 68-72 brochures, but I don't have one on a relatively original 1972. |
Posted: Fri Jan 09, 2015 12:42 pm Post subject: |
Nice to see an actual brochure of a '73 with the leatherette upholstery.
Can't tell you how many times I'm told that '73's didn't come from factory with leatherette, but fabric, even though I have leatherette AND I have original window sticker stating it had leatherette. Thanks. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Xevin Samba Member
Posted: Fri Jan 16, 2015 10:27 am Post subject: |
Thanks for the input everyone. Does anyone have a close up of the strap used in a 72. If there are straps used in a 72 I want to get the right one. The one I have is identical to the one on the closet. The screw that fits it, is to small in diameter to fit the holes pictured in mine. Maybe there was nothing there but white plugs. |
