Building a better Vanagon automatic transaxle
Page: Previous  1, 2, 3, 4 ... 31, 32, 33  Next
Rocky Mountain Westy
Rocky Mountain Westy is offline
PostPosted: Tue Jan 13, 2015 7:10 pm    Post subject: Reply with quote
I will also be watching closely on this thread. I didn't read it all but I would find someone with a Bostig and a 3.27 r and p before using it. I am not sure a Bostig has the right power curve for this tranny. Might be valuable research before taking the plunge. I would say my 2.5L subaru at 165hp is close to the line. I do a lot of high elevation mountain driving though.
Rocky Mountain Westy Inc.
www.rockymountainwesty.com
970-310-3441
[email protected]
The Splitzgauer build (when I have time to work on it and update the thread)
http://www.thesamba.com/vw/forum/viewtopic.php?t=497133
kourt
kourt is offline
PostPosted: Tue Jan 13, 2015 7:36 pm    Post subject: Reply with quote
I'm glad you mention this (regarding the suitability of a Bostig and 3.27 R&P), as it is a concern for me as well.
Regardless, I will probably buy from RMW, but feel free to PM me your thoughts on that... or post them here, no worries.
kourt
ThankYouJerry
ThankYouJerry is offline
PostPosted: Tue Jan 13, 2015 8:39 pm    Post subject: Reply with quote
My guess is the 3.73 is probably the proper auto R&P for a Subie 2.2.
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
Tristar Eric
Tristar Eric is offline
PostPosted: Tue Jan 13, 2015 11:04 pm    Post subject: Reply with quote
I'm in line to see how this all goes down as well. I've got the tall R&P waiting to go in, but I'd like to add the limited slip also. Running a 2.5 subie DOHC (it's in my dads 88 ). He likes to drive fast Wink
Vanagon/Transporter flares here: www.terrawagen.com
[email protected]
geo_tonz
geo_tonz is offline
PostPosted: Wed Jan 14, 2015 1:12 am    Post subject: Reply with quote
dart330 wrote:
dart330 wrote:
I also came across a suggestion that Redline ATF can be used in the trans and final drive eliminating the threat of cross contamination. I do not know if this fluid can actually be used in the differential, but I would like to know as this could buy me time before a full replacement.
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
Provides a GL-4 level of gear protection. Also used with manual transmissions and transaxles.
It looks like this has been asked a few times but nobody has posted an actual response from redline. I guess I will shoot them an email.
http://www.thesamba.com/vw/forum/viewtopic.php?t=418681
http://www.thesamba.com/vw/forum/viewtopic.php?t=355605
I also emailed Jeff Field at http://www.transaxleengineering.com as they have beefed up the 010 for racing purposes in cars with 600HP. This includes Kevlar bands, forged input shafts, upgraded clutches, valve bodies, 4340 alloy 4 planetary carrier, etc. This all sounds like overkill to me but I plan to give him a call and discuss which upgrades would be good for heavy loads and transmission longevity.
Does anyone have a full part list of what is included in the GTA turbo upgrade?
That is interesting...I'd also like the idea of no cross-contamination possible (except from my ageing cooler...). You'd still want to keep them separate as I doubt metal slivers from the R&P would be welcome in the Auto tranny, but that seal would not be a concern and you could carry one less jug of fluid.
Red Vanagon "Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper
Abscate
Abscate is offline
PostPosted: Wed Jan 14, 2015 4:46 am    Post subject: Reply with quote
djkeev wrote:
IdahoDoug wrote:
You probably know this, but that's a max allowed weight for that model of Vanagon, not the weight it is hauling around daily. Lop about 1500lbs off that figure for what is known as the curb weight - the empty weight. Though some of the weights people post on their daily driver vans are pretty close!! Heh.
So the Audi 5000 and Vanagon are much closer in weight.
Well.......... Except the Audi 5000's weight posted is also maximum loaded...... No?
In essence this Audi trans is designed to move a maximum 3500 lbs, an empty Camper easily STARTS at this 3500 lb weight and goes up from there.
Just thinking out loud, as I mentioned, I'm no expert at Transmissions.
Dave
You are pretty good with numbers, though.
Very Happy Very Happy Very Happy
Question on this Audi transmission though. Didn't the 5000 series have a horrible reputation for mixing ATF and diff oil through seal failure? Are you guys building a pig in a poke??
on edit - seal incident was a 1980s trans issue per post below.
.ssS!
djkeev
djkeev is offline
PostPosted: Wed Jan 14, 2015 5:25 am    Post subject: Reply with quote
Dave
Yeah.... Thanks......
Anyway the GVW..... Maximum weight of the units involved, seem to be of no importance anyway so.....
I'm just Sitting back and watching.......
Popcorn
Dave
Ghia
Vanagon
Beetle
madspaniard
madspaniard is offline
PostPosted: Wed Jan 14, 2015 8:01 am    Post subject: Reply with quote
Haven't heard that but we are only using the internals from the automatic section
AtlasShrugged
AtlasShrugged is offline
PostPosted: Wed Jan 14, 2015 9:22 am    Post subject: Reply with quote
Back in the early 80's there was an occasional failure of the back to back seals with Audi and VW..not a horrible reputation.
The back to back seals are in the differential..not the automatic. You remove the automatic to get to the seals.
VW/Audi came out with some improved seals which is the replacement parts available now.
Correctly installed the new seals you buy are not a problem.
Abscate
Abscate is offline
PostPosted: Wed Jan 14, 2015 9:52 am    Post subject: Reply with quote
It was a while back but its all a blur when you are old and crusty like me.
Edited my post to try to stop internet urban legend propagation phenomenon.
.ssS!
geo_tonz
geo_tonz is offline
PostPosted: Mon Jan 19, 2015 8:36 pm    Post subject: Reply with quote
Any confirmation on this yet?
dart330
dart330 is offline
PostPosted: Tue Jan 20, 2015 6:46 am    Post subject: Reply with quote
I got busy last week at work and didn't get in touch with them yet. Going to their website and using the application search, it only lists the D4 ATF for the entire automatic transaxle. I will shoot them an email to verify this application.
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
dart330
dart330 is offline
PostPosted: Tue Jan 20, 2015 11:31 am    Post subject: Reply with quote
Thank you for contacting Red Line Oil, in the separate final drive I show either a GL-4 or GL-5 gear oil is specified depending on the year of manufacturer, the MT-90 or 75W90 would be recommended. I will try to add the final drive recommendations to reduce confusion.
Regards, Dave
Red Line Oil
ThankYouJerry
PostPosted: Tue Jan 20, 2015 8:44 pm    Post subject: Reply with quote
FWIW... This is the reply I received from GTA regarding fluids and intervals:
"We recommend any FULL SYNTHETIC A.T.F.
We use BG Ultra Guard – Full synthetic oil in the Diff.
1st service at 15,000 miles and then every 30,000 there after."
kourt
kourt is offline
PostPosted: Sun Feb 08, 2015 4:31 pm    Post subject: Reply with quote
Automatic Transmission Fluid - Filtering, Cooling, Measuring Temperature
I completed this part of the project today. Photos:
These first three photos feature the Derale fan, mounted essentially under the floor near the sliding door. There's just enough room to mount it there with the lines making a 90 degree bend to the aft end of the van. There's a Propex mounted farther aft of this cooler. The last of these three photos shows the fan shroud's profile below the rocker panel--not a significant amount of exposure.
Here's the Derale filter with temperature sender. The is the first stop for the ATF as it is pumped out of the transmission. The filter is mounted immediately to the left of the transmission, on a small vertical depression in the sheet metal bulkhead just forward of the transmission. The filter is basically very near the 2nd gear brake band cover on the transmission, but with plenty of room to service the filter.
The temperature sender on the filter mount sends the ATF temperature to this VDO gauge. I'm very fond of the native design of the Vanagon dash, so I preferred to mount this less-significant gauge on the heater shroud, which I could replace with another if I decided I wanted to rethink the gauge location. I removed my rear bench under-seat heater last year so I was able to use the remaining wiring for that heater to support this gauge. I used the yellow wire to go from the sender to the harness in the dashboard, and that was simply cut and spliced to the gauge. The old heater switch also has dimmed dash lighting power, ground, and switched/fused DC 12V for the gauge, so all those wires were transferred to the gauge. Works great!
Here's an example of some of the AN-6 hose I made for this project. You can also see the relationship between the filter and the transmission. The hose is a rubber hose with braided stainless jacket. I took pains to use the Koul Tools products to make the AN hoses, and I would recommend that step to anyone. I made my cuts with a miter saw using a 12" cutoff blade, and blew out the hoses with compressed after every cut and prior to installation. Aviation snips also made the task of cleaning up the frayed ends much easier. AN hoses require patience to manufacture, but these are bomb proof. They can be disassembled and rebuilt, and the whole system allows for substitution of hoses in the field for easy shunting of ATF if an emergency occurs. These hoses are secured every 18 inches or so with clamps. All hardware is stainless.
The fan is driven by a thermostatically controlled relay. The relay draws power from the positive post in the wiring box in the northwest corner of the engine bay. Note that I have a second relay for the engine oil fan, as I am running a similar Derale engine oil cooler for my Bostig, but with AN-10 fittings.
Here's the fan relay thermostat sender (in the blue fitting) and the fluid control thermostat from the GoWesty cooler. The fluid stat is a Derale product as well.
No leaks on the first startup!
I hope you all find this helpful. Next project: Audi turbo internals.
kourt
HoustonPhotog
HoustonPhotog is offline
PostPosted: Thu Mar 26, 2015 11:27 am    Post subject: Reply with quote
kourt wrote:
Summit Racing provides the rest... fittings to convert the thermostat to AN-6 and all the AN-6 fittings and hose:
http://www.summitracing.com/parts/SUM-220648N
http://www.summitracing.com/parts/SUM-230606
http://www.summitracing.com/parts/SUM-220687N
http://www.summitracing.com/parts/AER-FBM3484
Hey there Kourt... I'm planning to make this order soon so I can install the ATF cooler before I head out to California in later April...
Do you recall the quantities of the listed items above you purchased? I can figure it out by looking through your photos but figured you may recall right off hand.
Thanks
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
HoustonPhotog
PostPosted: Fri Mar 27, 2015 5:46 am    Post subject: Reply with quote
Thanks
I got the quantities figured out... Placing my order soon!
Abel Longoria
kourt
kourt is offline
PostPosted: Fri Mar 27, 2015 6:46 am    Post subject: Reply with quote
Let me know if you need help. Building hoses required a good chop saw with cutoff wheel for accurate cuts, the Koul Tools AN helper tools, some aviation snips to dress the ends, compressed air to blow out the debris of hose cutting, etc. I have modified my Koul Tools helpers to accept the slightly larger Summit fittings.
I just finished this same project (oil cooler) for my Bostig engine as well--but with AN-10 hose and fittings. It is quite stout.
kourt
HoustonPhotog
PostPosted: Fri Mar 27, 2015 6:51 am    Post subject: Reply with quote
kourt
yea that's the one thing I'm looking at now... is how to cut the hoses and install the fittings etc
side note: My engine left GoWesty yesterday so it should be back at the shop sometime on Monday. Very Happy
Abel Longoria
falkortheluckwagon
falkortheluckwagon is offline
PostPosted: Thu Aug 13, 2015 8:09 am    Post subject: Reply with quote
This is a great thread and has been super informative for me. I had my auto trans rebuilt by GTA and got the turbo upgrade. I havent been too happy with it but that's a different story.
Recently I installed a trans temp gauge and a diff temp gauge to monitor those components as the last trans I had got cooked pretty good because I was running way too hot (even with a cooler under the van), and I dont want to pay GTA for another tranny anytime soon.
I have a Small Car cooler that was positioned in about the place as was shown above by Kourt. I also attached a thermostatic fan to the cooler to help with the temp at Ken from GTAs suggestion. That hadn't worked for me at all. After installing the temp gauge I was seeing temperatures for the trans as high as 240 (and the diff is around the same often hotter). GTA told me that running above 210 is pushing it so 250 is definitely bad. Apparently Ive been driving with these temps since getting the rebuilt trans way back in January.
Anyhow, I moved the trans cooler up in front of the radiator and went on a 45min drive from north Seattle to Tacoma and back. The temp in the trans never got above 180 which is 40deg cooler than it has been previously on that same drive, but the diff was around 210.
I say all of that to ask what temperature is too hot for the diff? When should I pull over and let it cool off? As far as I know, there isn't a bolt up quick and easy way to add a cooler to a diff so any suggestions on max temperature would be super helpful. Should the diff temp even be of concern to me? Have any of you attached a temp gauge to the diff? If not, why not? Kourt, is that something you will be monitoring on this new trans of yours?
Page 3 of 33
