Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Tue Jan 13, 2015 3:13 pm Post subject: Steering Wheels from early VW/Porsche |
Has anyone ever adapted, cut/welded, etc the type 3 steering shaft to use an early VW/Porsche steering wheel? If so how? and were there other things that interfere like the turn signal cancelation, the column itself, etc?
I have a wild itch. I really like my interior, but I'd really like a different steering wheel. I don't want to go with an Empi GT on this car, I don't think the wood will look right
Ultimately, I want to go with one of these, all Split/Oval spline pattern...
And Ideally, dream steering wheel for my notch is this VDM Wheel
Maybe I'm crazy... But that one would look perfect with my interior
Maybe I'll just go with an incorrect early white wheel with the full circle ring...
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Tue Jan 13, 2015 5:03 pm Post subject: |
Grafting in a new spline end is no problem whatsoever. You will want to have the new wheel on hand so that you can tailor the length of the steering column so that it fits right once it's installed. That way you don't have a large gap between the column and the back of the wheel. This also ensures your blinker cancel feature works right since that can be a real drag if you have a gap and that doesn't work correctly. Below is my shortened dual stalk, '74 Super Beetle column.
I personally like the first wheel in that line-up, but I have a thang for Porsche stuff. I chose a 930 Turbo wheel for my car and I absolutely love it. Below is a really old pic.
_________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Erik G Samba Member
Posted: Wed Jan 14, 2015 1:16 pm Post subject: |
t3kg wrote: |
I think ISP West has adapters that will do the job. That might be preferable to cutting the column shaft. |
I've never seen one. I'd think there would be a market since late model (60-70's) could use it. I think it would have to be a full boss, kinda to Nate's point. all the early Vw/Porsche wheels are very flat. I would want the wheel in the same place, and there would be considerable gap without it... Starting to sound real expensive to do a one off, wish I had access to a machine shop and someone with skills _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Wed Jan 14, 2015 7:28 pm Post subject: |
I realize you are striving for either a genuine 356 wheel or a '50's period aftermarket wheel, but have you considered an ivory "banjo" wheel like this one? http://www.piersideparts.net/CBI-235.html
With the hub adapter going straight onto your existing column, you can switch wheels within 1/2 hour.
Many years ago I had played with the idea of mounting a 3-spoke aftermarket wheel to a VW steering wheel's hub. I noticed that the 3 holes in the aftermarket wheel's center section lined up with the 3 holes in the VW's hub for the horn screws. You could pick up a mangled original Vw steering wheel like the kind you have for next to nothing. If you'd cut the center spokes off both sides of the wheel, you'd end up with a round hub. Next, grind down the metal outer lip of the hub so that the aftermarket wheel sat flush. Fasten the aftermarket wheel to the VW hub using short metric screws into the 3 horn screw holes as well as the original factory large center nut+washer. Then you'd have a proper factory turn signal collar, and enough depth away from the steering column so that the aftermarket wheel should clear the blinker stalk. Finish the sides of the VW hub with epoxy, sand to shape, and paint it either black or ivory to match the aftermarket wheel.
I never got beyond the concept stage, and ended up just getting a Grant hub adapter kit. |
