delta9007 Samba Member
Joined: March 17, 2008 Posts: 106 Location: Arcata,CA
Posted: Fri Jan 16, 2015 12:51 pm Post subject: Will 16" Factory steels fit 2wd Westy? |
An out of area friend has a set of 16" factory steel wheels from a Syncro I can have but neither of us know if they'll fit my '89 2wd Westy. Any help much appreciated and yes I searched! _________________ '89 2wd, 4spd, 2.1 Westfalia. |
WedgeAntillies Samba Member
Joined: April 07, 2008 Posts: 166 Location: Maple Ridge, BC
Posted: Fri Jan 16, 2015 1:01 pm Post subject: Re: Will 16" Factory steels fit 2wd Westy? |
delta9007 wrote: |
An out of area friend has a set of 16" factory steel wheels from a Syncro I can have but neither of us know if they'll fit my '89 2wd Westy. Any help much appreciated and yes I searched! |
Just and FYI, there is an existing thread for wheel fitment questions.
http://www.thesamba.com/vw/forum/viewtopic.php?t=203519 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Fri Jan 16, 2015 1:23 pm Post subject: |
I can't think of reason they would not fit, unless they have tires mounted that are too tall. Many syncro owners opt for taller tires along with their lift. _________________ ☮️ |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Fri Jan 16, 2015 3:11 pm Post subject: |
They are kind of on the narrow side 5.5" IIRC.
Big brake kits will be a issue since the rim center is flatter than most options.
What tires are you going to run to keep from getting overgeared too much?
They are cool from the originality side but I have doubts that I would run them on my cars with other lighter/stronger/better looking options available. |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Fri Jan 16, 2015 7:36 pm Post subject: |
They will bolt right on, but you need to use +2 size tires to keep your outer diameter close to the original.
Tire Rack: "Large diameter wheels and wide, low profile tires go together and show up everywhere from America's new car showrooms to its roads, tracks and trails. So whether the vehicle came from the assembly line or was upgraded after it was delivered, Plus Sizing (also called "Inch-Up" sizing in other parts of the world) probably played a role in its tire size choice. Plus Sizing allows tires and wheels to make a fashion statement while providing a functional improvement.
Plus Sizing dates back to the 1970s when Plus One and Plus Two fitments were the available choices. Drivers could upgrade their cars from relatively narrow 13-, 14- or 15-inch wheels and tires up to wider 14-, 15- or 16-inch combinations. While Plus One and Plus Two are still popular today, the starting point now typically begins with 15- or 16-inch wheel diameters and grows from there."
So if the OEM size was 205/70-14, you'll need something in the range of 215/60-16.
You also need tires load-rated for the heavier Westy, so your choices are a little limited _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
Posted: Fri Jan 16, 2015 11:40 pm Post subject: |
syncrodoka wrote: |
Thank you for the feedback. Main motivation was the price..Free! I'll have to research my tire options. _________________ '89 2wd, 4spd, 2.1 Westfalia. |
Posted: Fri Jan 16, 2015 11:44 pm Post subject: |
Syncroincity wrote: |
You also need tires load-rated for the heavier Westy, so your choices are a little limited |
Excellent info, thank you. I currently have the 14" steelies with Hankooks. _________________ '89 2wd, 4spd, 2.1 Westfalia. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Sat Jan 17, 2015 8:32 am Post subject: |
Like others say, they will physically bolt on, but you will be limited to narrow tyres, like 205/60R-16. Even 215 is on the wide side for a 5,5 inch rim.
These Wheels are desireable for an original 16 inch syncro owner, and as such may be worth something as a trade, however for Your van, you will probably be better off with some Mercedes steel wheels. They are available in 7x16 et30 and many other dimensions. Look in the "what Wheels fit thread" for details. _________________ 1991 VW Multivan syncro 1,9 TD |
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Mon Jan 19, 2015 2:59 am Post subject: |
Free is the perfect price - go for it! I would hang on to them though - they're about the toughest wheels you can get for a T25, and all the offsets are perfect.
As others have said you just need to watch your overall diameter so that you don't get tyre rubbing. 195/65R16 or 205/60R16 are the same size as the standard 185R14 tyres so you could probably go a bit bigger than that, but get opinions from people who have done it first. We're running these wheels on our Westy Syncro with 215/70R16 BFG ATs so you may even find that this size will fit your 2WD. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
