sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Fri Jan 16, 2015 6:33 pm Post subject: Cutting tools |
So here is my collection of cutting tools:
They all have their uses but they all have shortcomings. The dremel is nice because it makes a narrow kerf but the wheels don't last long and the dremel itself has very little torque for cutting. The air saw is nice but not great for making straight lines. The electric grinder with a diablo cutting wheel on it goes thru metal like a hot knife thru warm butter but it's heavy and large and impossible to make precise cuts. The air grinder is a great tool as well, precise, lots of torque and light but I can't find 0.040" cutting wheels for it. This is what I really want: 3" - 3/8 arbor 0.040 cutting wheels. And no Diablo don't make 'em. If I can find wheels for it the air grinder will do so much for me.
Diablo wheel, beautiful to cut with but too large for what I want.
Don |
modok Samba Member
Posted: Sat Jan 17, 2015 2:33 pm Post subject: |
Going by eyeball accuracy can be the thickness of a blade or better.
I always draw a line with marker or template/spraypaint and then cut on the line.
The guard on the angle grinder is preventing you from seeing the the line then it's in the way, should be moved or modified or well, you know. Get really good safety glasses, the goggles or the ones with shields all around the edges.
Dewalt is making some good cutoff wheels, better than the diablo ones. I used to use Forney brand but local store quit carrying it which is a shame.
http://www.dewalt.com/tool-parts/abrasives-bonded-...heels.aspx
To make the dremels more powerful I run with a transformer or variac 140 or 160 volts. Really brings it to life!! |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Jan 17, 2015 4:31 pm Post subject: |
I agree about the Dewalt cut off wheels. I bought a 5 pack 4months ago and I'm still on the first blade, and only used up a 1/4" of blade. That includes lots of sheet metal cutting, and cutting 10 12mm wheel studs. They cut clean and smooth.
It takes practice to cut really well with an cut off wheel on a grinder. I always mark what I need to cut and cut a hair larger. Then I can fine tune it on the bench grinder or a hand file. Using tape works really well for guiding your cuts.
I also agree you need to ditch the shield on the grinder. They make it a pain in the ass to cut. Just make sure you cut in a way where your not throwing sparks up in your face. _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Jan 17, 2015 6:23 pm Post subject: |
It's too easy to get off of your mark when cutting sheet metal, so rarely do I even attempt to get it right the first time. Usually I aim to cut about a 1/16" away from my target line with whatever suits the job best, plasma, wafer wheel on a grinder, sawzall. Then I use my grinder with a 60 grit flap wheel and carefully buzz the sheet exactly to the line. For inside corners where the grinder won't fit, get some carbide burrs for the pneumatic die grinder. They throw big chips, so eye goggles are a must. |
Posted: Sun Jan 18, 2015 11:44 am Post subject: |
Thanks guys. I will try and find the Dewalt cut-off wheels.
Don
BTW I tried cutting with the angle grinder with the shield off and it scared the crap out of me! I've had enough accidents over the years to leave more than a few scars and bad memories. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Jan 18, 2015 2:45 pm Post subject: |
I took my guard off to better cut out solid body sections, but you do have to be careful with your fingers & thumbs! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
esde Samba Member
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Tue Jan 20, 2015 3:18 pm Post subject: |
I would be extremely hesitant to remove the guard from a grinder. I have heard of several deaths resulting from exploding grinder wheels where the user removed the guard. Reposition it, or yourself if necessary, but don't risk your life by removing. Despite it seeming like an annoyance, it is there for a reason and should be between you and the edge of the blade. Position yourself off to the side if necessary to improve your view of the cutting surface. I regularly experience shattering of cutting disks when they catch on something. _________________ 1958 Karmann Ghia owner |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Jan 20, 2015 9:01 pm Post subject: |
I have a broken HF nibbler. It worked better than a expensive one I have but a part broke that converted the rotory motion to the up and down motion. I can't get the head off to try to fix it. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Wed Jan 21, 2015 7:33 am Post subject: |
I have an electric nibbler! I forgot all about it. I will have to update my photo.
Don |
modok Samba Member
Posted: Fri Jan 23, 2015 7:35 pm Post subject: |
Northof49 wrote: |
I would be extremely hesitant to remove the guard from a grinder. I have heard of several deaths resulting from exploding grinder wheels where the user removed the guard. |
With grinding wheels I agree that the guard should be kept on. Cutoff wheels..... not necessarily.
The thin ones are light and rarely does a large enough piece break off to cause a BIG injury. Just small painful ones mostly. And like I said use the best safety glasses and also don't smile.
I used to think using a wire brush was the most dangerous because they GRAB and take off, but then I tried using a wood cutting blade on there.
Every few years I forget and try doing that and it always ends badly. I nearly cut my foot off last time. |
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Fri Feb 06, 2015 9:49 pm Post subject: |
double cut shears make nice clean cuts, but have a wide kerf. when i use them im usually not to concerned with the kerf as im replacing that metal |
