66 slider
crukab
Samba Chef
crukab is offline
PostPosted: Tue Feb 10, 2015 10:10 am    Post subject: Reply with quote
Sh*tBird wrote:
orangebug60guy wrote:
received this chassis part for Allan Scholfield INC in the UK to fix my chassis.
Excited to get out in the cold today to get it ready.
How'd you hear about Scholfield? Just searching the web for parts?
He has been around for years.
Looking good Jack !!
OOOOOHHH page 2 !!
Tom
Dude, you "Stone Cold looser" you lost, get over it.
My Pops:
In the yard right now:
'65 Bus/Panel/camper W/T Now FOR SALE !!
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
WM971252
WM971252 is offline
PostPosted: Tue Feb 10, 2015 10:11 am    Post subject: Reply with quote
A little bird told him....
We used to carry his stuff and knew the piece. Actually thought we had one or 2 for our own project but could not find them when I went to put them in.
They are easily findable on a search, we have them in our favorites. Last time I knew Wolfgang International and Bus Depot still carry there stuff now on this side of the pond
mandraks
mandraks is offline
PostPosted: Tue Feb 10, 2015 1:02 pm    Post subject: Reply with quote
http://www.alanhschofield.com/
some of us old guys have been looking at his parts for a long time, since the late 80s early 90s Especially in Europe.
regards
Uli
Ran When Parked
Ran When Parked is offline
PostPosted: Thu Feb 12, 2015 8:34 am    Post subject: How's it? Reply with quote
Any Updates? Keep those background images coming!
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Tue Feb 17, 2015 1:24 pm    Post subject: Reply with quote
I finally made it out today. finished my chores early on my second day of vacation. So I had previously cut out the majority of the rust. I welded in the patch today. This is nothing fancy but its solid now. I still need to do the back side and start with the removal of the old center cross support. Any tricks to getting up there with the grinder in this cold.
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
orangebug60guy
Twin #1
PostPosted: Tue Feb 17, 2015 3:17 pm    Post subject: Reply with quote
my front brake parts from cip1 just got here too. I'm slowly buying front end parts too. thinking about ripping out the beam and replacing it with a spare that I have.
orangebug60guy
Twin #1
PostPosted: Tue Feb 17, 2015 3:20 pm    Post subject: Reply with quote
I asked Scholfield if anyone carries their stuff here in the states. No one carries their products anymore. You have to buy directly from them. Easy customer service and fast shipping. I received my part on friday afternoon and I only ordered it on tuesday. Faster then getting parts from the west coast (WofsburgWest) or even Canada (Cip1)
orangebug60guy
Twin #1
PostPosted: Thu Feb 19, 2015 2:52 pm    Post subject: Reply with quote
i've been trying real hard to get a lot of the rusty bits out yesterday and today. I had to remove the center heat pipe, rip out the front cross bar support and grind down the spot welds. My arms are tired today.
I was happy when I started:
heater pipe removed. Someone has replaced this at some point.
passenger side cleaned up. I did the drivers yesterday.
then I just wanted to see what it would look like with fresh metal in there! nice. Dancing
I've noticed a nice hole in the front beam this winter: #2gunfire #2gunfire
Eskimotom
Eskimotom is offline
PostPosted: Thu Feb 26, 2015 12:21 pm    Post subject: Reply with quote
Greetings,
Can you share the steps you took to knock the old ones out? I have to knock out the cross members on my bus also.
Did you drill out welds, use an air chisel or cut and grind? I ask because although I don't plan to weld in new ones myself, I figure I could save a handful of dollars delivering the bus to the metal person with the pieces out.
Are you going to weld in the new ones yourself?
Love the slider by the way!
Eskimo Tom
orangebug60guy
Twin #1
PostPosted: Wed Mar 25, 2015 4:10 pm    Post subject: Reply with quote
Eskimotom wrote:
Greetings,
Eskimo Tom
Eskimo Tom, I cut the old metal with sheet metal sheers and then used a fancy vise grip and some muscle work. It took a while but I didn't damage any of the original metal. THe spots welds are hard to rip off by hand and takes some bending and prying of the metal you are ripping off. But it worked. I plan on welding in the cross member and out riggers myself. I will drill holes and spot weld in place.
Today I ripped apart my spare beam to prep for all the new parts I've been collecting this winter. Going to replace the center pin first. I want to have this beam all put together before I take out the old one.
here is the hole I found in the beam on my bus currently:
orangebug60guy
Twin #1
PostPosted: Sun Mar 29, 2015 1:42 pm    Post subject: Reply with quote
Got the beam all cleaned up and blasted with a couple coats of rust inhibitor. time to rip the old one out and get this bad boy in there.
crukab
Samba Chef
crukab is offline
PostPosted: Sun Mar 29, 2015 2:59 pm    Post subject: Reply with quote
Go Jack GO !!
Good day for that kind of work- sunny & over 45 degrees out !!!
Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon
orangebug60guy
Twin #1
PostPosted: Mon Apr 13, 2015 5:41 pm    Post subject: Reply with quote
I need help now. The one thing that stand between me and dropping this old beam is this shift linkage.
I was able to carefully cut the old set screw and collar off. But the two pieces are still together pretty well. I blasted it with PB blast before I came in for the night.
Any suggestions? Tricks?
Ran When Parked
PostPosted: Mon Apr 13, 2015 8:08 pm    Post subject: Known Issue Reply with quote
Lots a folks have this problem. I did. I got it uncoupled.
Once it was cut, it slid down the rod enough to get the two parts apart.
This thread gave me good advice:
http://www.thesamba.com/vw/forum/viewtopic.php?t=602951&postdays=0&postorder=asc&start=0
2Pack
2Pack is offline
PostPosted: Tue Apr 14, 2015 12:26 pm    Post subject: Reply with quote
I would heat it with a torch and melt some paraffin wax around the joint. Maybe tap it with a hammer to break up the rust bond a little.
Please buy my Treasure
crukab
Samba Chef
crukab is offline
PostPosted: Tue Apr 14, 2015 2:15 pm    Post subject: Reply with quote
I used the "Blue Wrench" on mine, heated it w/ the torch and pulled it apart.
Are you going to try & make Litchfeild ?? Will you ever Trailbash it again ?? Wink Twisted Evil
Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon
orangebug60guy
Twin #1
PostPosted: Wed Apr 15, 2015 4:57 am    Post subject: Reply with quote
I sprayed some PB blast on it and let it sit. I'll Try heating it up if it doesn't break free. Thanks for the suggestions.
Tom: I probably wont have it ready for litchfield. I'll probably be driving the 73 as a shake down run. I need to have my spindles rebuilt and right now Widefive isn't tooled up for rebuilds. I am working on the center pin this week and getting the sway bar on before I jack it back up. Trailbash would be fun. It's been a few years.
iamdonquixote
iamdonquixote is offline
PostPosted: Wed Apr 15, 2015 11:32 am    Post subject: Reply with quote
you are gonna need to heat it. Propane torch to the 'female' side until its cherry red. Then take vice-grips on each portion and turn until they come free.
60vwnewengland
Twin #2
60vwnewengland is offline
PostPosted: Fri May 15, 2015 12:52 pm    Post subject: Reply with quote
Updates?
77 Westy - Cape Cod Sage
14 Dieselgate Jetta Wagon
LLAP
orangebug60guy
Twin #1
PostPosted: Mon May 18, 2015 7:15 am    Post subject: Reply with quote
got the beam all put back together. New center pin and sway bar mounts.
Page 2 of 6
