tgraham Samba Member
Joined: July 04, 2015 Posts: 127 Location: Santa Cruz, CA
Posted: Sat Dec 09, 2017 11:33 am Post subject: Re: GW Instrument foil replacement, NEW design |
Hello everyone,
I'm in the process of installing the GW printed circuit board in my 1990 multivan. I'm just starting and have pulled the instrument cluster, but it looks to me like I've got some creative wiring going on here.
The two sets of wires that are attached to the red and yellow bulbs, should those wires have been part of the main plug on the cluster? And if so, any thoughts on how this will affect the install ?
Thanks all
_________________ 1990 Multivan/Weekender Auto 3.27 R&P SAH 1.8T |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Sat Dec 09, 2017 12:23 pm Post subject: Re: GW Instrument foil replacement, NEW design |
I think the wires are stand alone. Looks like you have an aftermarket engine? I see a VSS |
Posted: Sat Dec 09, 2017 12:31 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Thanks for the reply, yes I have a 1.8T and the VSS, from GoWesty. _________________ 1990 Multivan/Weekender Auto 3.27 R&P SAH 1.8T |
Posted: Sat Dec 09, 2017 1:43 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Ok then you are good. Guessing VSS going into speedo, then check engine light should not be part of blue foil |
Posted: Sun Dec 10, 2017 9:37 am Post subject: Re: GW Instrument foil replacement, NEW design |
Thank for your help, got everything back together and working as expected. Nice to have gauges again! _________________ 1990 Multivan/Weekender Auto 3.27 R&P SAH 1.8T |
OSIDWST Samba Member
Joined: February 24, 2018 Posts: 1 Location: Oceanside
Posted: Sat Feb 24, 2018 3:32 pm Post subject: Re: GW Instrument foil replacement, NEW design |
I recently received a gift of the GVW-255-919-059 subject kit for my 1984 VW Westy.
Using the enclosed instructions and the GoWesty video library, I installed all the parts, but am now having difficulty in the last phase of the process in reconnecting to the vehicle electrical connection. Specifically, switching the wires in the factory white connector kit.
I have watched the video dozens of times and read and reread the instructions, yet remain uncertain as to how to proceed.
The instructions and video indicate I should match wire color in the new harness by switching the wires around in the factory white connector kit.
However, I am flummoxed as to how to do so when the factory white connector kit only has 12 wires, 2 of which are brown ground wires, while the GoWesty Cluster Harness Connector has 14 wires, one of which is white which is not one of the wire colors in the factory white connector kit.
If, as per the instructions, I am to splice together the two brown ground wires, there would then only be 11 connection points in the factory white connector kit into which to plug the 14 wire connection points of the GoWesty Cluster Harness Connector. |
eeebee Samba Member
Posted: Sun Feb 25, 2018 5:22 pm Post subject: Re: GW Instrument foil replacement, NEW design |
You should call Go Westy, they are usually very helpful. _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
Nikkoleto Samba Member
Posted: Thu Aug 23, 2018 6:54 am Post subject: Re: GW Instrument foil replacement, NEW design |
I also installed the GoWesty kit. It worked great but all of a sudden my oil light remains on, my tach and digital clock stopped working. Anyone else have similar problems ? I am not low on oil! _________________ 1987 Vanagon GL |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Aug 23, 2018 2:58 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Nikkoleto wrote: |
I also installed the GoWesty kit. It worked great but all of a sudden my oil light remains on, my tach and digital clock stopped working. Anyone else have similar problems ? I am not low on oil! |
I had intermittent problems when I first installed mine and found that the wiring plug to the original connector can move a little and needs to be pushed in harder. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Fri Aug 24, 2018 12:57 am Post subject: Re: GW Instrument foil replacement, NEW design |
Thanks Mellow Yellow.. I will check it out _________________ 1987 Vanagon GL |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Sun Sep 30, 2018 10:52 am Post subject: Re: GW Instrument foil replacement, NEW design |
Has anyone used this kit with a Subaru 2.5 swap? I’m wondering if I’ll need to do anything special with the tach circuit. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
The Gockleys Samba Member
Posted: Thu Oct 04, 2018 4:31 am Post subject: Re: GW Instrument foil replacement, NEW design |
Mellow Yellow 74 wrote: |
Nikkoleto wrote: |
I had intermittent problems when I first installed mine and found that the wiring plug to the original connector can move a little and needs to be pushed in harder. |
I have the same oil light on problem after running well for a year with the new cluster. Added a new oil sender and wire in the engine to no avail, so will try resettting the connector. Thanks! |
Posted: Sun Nov 04, 2018 7:51 am Post subject: Re: GW Instrument foil replacement, NEW design |
I ended up having a bad wire from the oil sender. New circuit board working perfectly. |
beach_creature Samba Member
Posted: Sat Mar 02, 2019 9:41 pm Post subject: Re: GW Instrument foil replacement, NEW design |
I have installed an oil pressure send relocation manifold so now have high and low oil pressure switches - just need to install wiring. |
I am trying to find the terminals that go inside the white instrument harness plug in the van that the Gowesty harness plugs into. The terminals crimp onto the wires have two little "fingers" that are the contacts inside the plug but I can't find anywhere that sells them (in Australia) because I don't know what they are called. Can anyone help? |
In case anyone is looking for these in the future. These connectors can be purchased from the dealer. They come pre crimped onto a wire. One on either side, so you have two total.
Here is the part number
000-979-102-E
_________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
plummerdesign Samba Member
Posted: Tue Jan 14, 2020 8:10 pm Post subject: Re: GW Instrument foil replacement, NEW design |
This summer I installed a Cluster Master kit into the '84. As anticipated, it went in easy and works perfect. The TOUGHEST thing was to toss the old blue foil into the trash bin.
Buh bye : )
But it did not stop the yearning for a 100% modern cluster made from new, non-broken plastic. Maybe my dream will come true... _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
BCE56 Samba Member
Posted: Sat May 16, 2020 4:17 pm Post subject: Re: GW Instrument foil replacement, NEW design |
FWIW- another option for foil replacement kits:
https://www.thesamba.com/vw/classifieds/detail.php?id=2367183
I'm keeping this in mind just in case... _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
deepseeman Samba Member
Joined: January 13, 2004 Posts: 435 Location: san diego
Posted: Sun Oct 31, 2021 2:35 pm Post subject: Re: GW Instrument foil replacement, NEW design |
So I installed the GW kit about a year ago. Every now and again my tach would either stop working or become erratic. A simple thump on top of the dash corrected it 95% of the time. I had time one day and took the cluster out and insured everything was tight and installed correctly. Still have the same issue. Called GW and was told I must have installed it wrong. I tore it back down and put it back together. Still doing it. Called GW again and basically was told to pack sand. any suggestions? Its getting annoying _________________ in the barn:
61' Double Cab-restored driver
91 SYNCRO |
DuncanS Samba Member
Posted: Sun Oct 31, 2021 3:14 pm Post subject: Re: GW Instrument foil replacement, NEW design |
There are a few of us who have eliminated the foil by harvesting the key elements and wiring it together. Did this and it works like factory. My tach stopped so it was time, plus I had to fiddle with it just because.
Before odo windows re opened.
Takes a bit of work, but was satisfying to do.
Duncan |
gtinseth Samba Member
Joined: July 25, 2019 Posts: 76 Location: NW California
Posted: Sun Oct 31, 2021 9:02 pm Post subject: Re: GW Instrument foil replacement, NEW design |
I know this is an older post, but I just installed this kit yesterday. My 87 Syncro has a tachometer and the digital clock, so it looks a little different than in that old ad. Here is the website for the specific kit I installed: https://www.slowbridgeinnovation.com/product-page/instrument-cluster-repair-kit which cost $110 US shipped from Taiwan. He also sells an upgraded clock which you can add to the kit. It took about an hour total, including removing and reinstalling the cluster in the van. It works great, even with the plasma gauge face upgrade (from T3 Technique) I did. |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Sat Dec 11, 2021 9:34 am Post subject: Re: GW Instrument foil replacement, NEW design |
Time for this upgrade methinks. Enough gremlins popping up that it makes sense before jumping into more stuff.
Since these have been out for awhile, any consensus on whether one kit - GW v. Vanagon.org - is better than the other?
Price is same now, so any difference in performance or longevity? _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
