kidosteele Mr. Butthurt
Joined: July 14, 2004 Posts: 116 Location: Saint Petersburg, FL
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jan 20, 2015 4:16 pm Post subject: adapter |
...check thesamba general parts section. On Wed. 1/14/2015 Vintage Fab Werks sells wheel adapters from 4 lug to wide five...not exactly what you asked, but a possible path to follow. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
c21darrel Samba Member
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Jan 20, 2015 9:47 pm Post subject: |
Not sure if that rotor would clear the stock '67-'74 front caliper. That's also why 4 x 130 mm to 5 x 205 mm adapters are iffy. Might be made for one of the aftermarket 5 x 205 mm front disc brake kits. _________________ 1966 Karmann-Ghia convertible |
Posted: Wed Jan 21, 2015 5:45 am Post subject: |
Sorry, I have a 73 Ghia coupe...
Aren't most entry level disk brake kits just Ghia brakes? |
Posted: Wed Jan 21, 2015 10:30 am Post subject: |
kidosteele wrote: |
I believe so, at least for the fronts. _________________ 1966 Karmann-Ghia convertible |
Posted: Thu Jan 22, 2015 8:41 am Post subject: |
So I called SoCal... After being transferred and put on hold, I started talking to one of there employees... He said in a nut shell they won't work... Then said they only work with factory spindles... I said I have factory brakes he then said in that case they won't work... Very confusing.. Then the call dropped... I'll try again today |
Posted: Thu Jan 22, 2015 2:30 pm Post subject: |
c21darrel wrote: |
If you do a search on the samba google above...something like..."4 lug to wide 5" I bet you come up with a boat load of info that may be more helpful than socalauto. |
Yea I always try and use the wealth of knowledge the internet has before relying on a phone call to an unknown source....
But I can say I tried again today and talked to a very knowledgeable person named John...
I explained my situation and he informed me that the brake rotor would work |
berliner Samba Member
Joined: December 27, 2006 Posts: 440 Location: west coast canada
Posted: Mon Sep 21, 2015 6:27 pm Post subject: brakes |
Did you buy the discs?Do they work OK? _________________ I'm part of the problem. |
