zbug Samba Member
Posted: Thu Jan 22, 2015 5:14 pm Post subject: tight cam help please |
I'm starting a 2176 build with a brothers machined as41 case. While mocking up, everything in the roller assembly went like a breeze until I put the cam in the case by its self to do the thrust bearing. I closed the halves, tapped it back and forth. didn't do much. So I removed it to very lightly sand on the bearing until I achieved .002 clearance. It rolled fine in each case half, but when I close them and torqued the 6 case nuts down it would't hardly turn. had to use a little force with a big screw driver to turn it. undid the case and there was smoothed section on the plug side bearing and a little on the outside edges of the thrust bearing.
removed the end bearing, put it back together and it spun pretty good. put end bearing back in and crap. It seemed as if the bearing halves were sticking up out past the edge of the case halves and I wasn't getting a good crush. So, without asking anybody first, I started sanding the ends of the the bearing to attempt to fix it. Aaand I need a new set of bearings. There's no crush left and now it won't turn at all with 15 lbs of torque
Has anybody had this problem and what should I look for. The cam is an SLR, and it mics perfectly at 25.00mm on every journal
Thanks in advance, sorry for the long post |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Thu Jan 22, 2015 5:34 pm Post subject: |
yeah it happens and isn't a good sign. The case squeezes together over time and the cam bore gets too small, may have to ream it.
Some shops do that to every case that they line bore. |
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Thu Jan 22, 2015 5:54 pm Post subject: |
modok wrote: |
Car craft i know measures this with the align bore, i have had it done with them twice. _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
zbug Samba Member
Posted: Thu Jan 22, 2015 6:08 pm Post subject: |
Well thanks for the help. I'm not gonna build on this case if that's what it is. I'd rather send another case in to be done that I know is good, than blow all the money I've got in parts. thanks again |
zbug Samba Member
Posted: Thu Jan 22, 2015 6:34 pm Post subject: |
one last question or two. is this case good anything? Maybe a small motor, or should I not trust for anything? |
modok Samba Member
Posted: Thu Jan 22, 2015 6:51 pm Post subject: |
I'm sure there are lots of VWs going down the road with worse engine cases.
Might want to double check how warped it is at the case split, check size of front and rear seal areas, lifter bores. if it isn't terrible then it should still be useful for something. |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Thu Jan 22, 2015 6:56 pm Post subject: |
I think its common and I think allot of guys let it fly the way it is , I have a case right now that is tight in the center cam bearing , I might make my own cutter or reamer , havnt got around to it yet . _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Dale M. Samba Member
Posted: Thu Jan 22, 2015 7:41 pm Post subject: |
Try different brand of bearing.... I had similar situation and it was poor bearings causing all the grief....
Posted: Thu Jan 22, 2015 9:31 pm Post subject: |
zbug wrote: |
Ill take the case off your hands _________________
modok wrote: |
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Fri Jan 23, 2015 11:01 am Post subject: Tight Cam bearings |
I have found that about 1/2 the engine cases that come to me have a warped bearing boss mounting for the cam bearings and I run my reamer through them all at the same time I do the line bore on the case. That usually fixes the problem but lately I have found that now the new double thrust racing cam bearings need a lot of cleaning up to make them fit and let the cam spin freely. It appears the flanges on the thrust has been over bent during the mfg process and warps the bearing so the cam will not turn freely when cam is installed and everything torqued down properly. Another PITA for such a simple thing. I've had to cut the inside of the bearing flange where it fit's into the case because when you install the bearing half it spreads the bearing and makes the cam tight for the end play, not the crush. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
Posted: Fri Jan 23, 2015 1:41 pm Post subject: Re: Tight Cam bearings |
hooker wrote: |
I have found that about 1/2 the engine cases that come to me have a warped bearing boss mounting for the cam bearings and I run my reamer through them all at the same time I do the line bore on the case. That usually fixes the problem but lately I have found that now the new double thrust racing cam bearings need a lot of cleaning up to make them fit and let the cam spin freely. It appears the flanges on the thrust has been over bent during the mfg process and warps the bearing so the cam will not turn freely when cam is installed and everything torqued down properly. Another PITA for such a simple thing. I've had to cut the inside of the bearing flange where it fit's into the case because when you install the bearing half it spreads the bearing and makes the cam tight for the end play, not the crush. |
Can I see a picture of the reamer set up that you use ? _________________ " Hot vw feature , may 2014 issue "
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Fri Jan 23, 2015 2:02 pm Post subject: Re: Tight Cam bearings |
raul arrese wrote: |
hooker wrote: |
Can I see a picture of the reamer set up that you use ? |
http://www.rockyjennings.com/cam.html
These are available new, and there were some tru-line ones just like it made a long time ago. I made a very similar one. It centers on the front and rear journals, and only has one cutter for the center journal. I bolt it into the case at the same time as the linebore tool. Every case has needed at least a tiny bit of clean up. Some were pretty bad. After using the bar, I have never had another tight cam.
Brian |
mark tucker Samba Member
Posted: Fri Jan 23, 2015 5:25 pm Post subject: |
make sure there are no burrs, Ive seen some warped bearings, there pretty small so that bend can be wonkifying the bearing. I would think you could make a jig to put the bearings into and a shaft(biger then the cam) so there is no clearance and try to press the bearing straight.....or try another set of bearings.Ive seen the front cambearing that was not square when it was formed so it stuck up at one point&down at another, it was bad enought it was visable to the naked eye !! I had noticed some funkey wear patterns on some cambearings I figured it was the small bearing's not being exzactly right when the flange was formed. some are machined after they are plated some dont seem to be,I wonder just how good these things are done and whoo has the best ones.??. I hate these small cam bearings any way.the bearings on a cam should be bigger than the lobes base circle... a lot bigger. |
Posted: Fri Jan 23, 2015 7:42 pm Post subject: Re: Tight Cam bearings |
Brian_e wrote: |
hooker wrote: |
Brian |
Oh I didn't know rocky made that tool .. thanks . _________________ " Hot vw feature , may 2014 issue "
zbug Samba Member
Posted: Sat Jan 24, 2015 11:09 am Post subject: |
problem solved. I've tried some mahle bearing that just arrived. perfect fit. I tapped it back and forth and got perfect clearance, spun freely when it was torgued down. Thanks everybody for the input |
Posted: Sat Jan 24, 2015 12:21 pm Post subject: |
thats what i suspected.what brand did you have? |
modok Samba Member
Posted: Sat Jan 24, 2015 2:26 pm Post subject: |
Mahle run on the looser side, as much as .004" clearance
Silverline have about .0005' more thickness. |
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Sat Jan 24, 2015 8:18 pm Post subject: |
nothing but trouble here with those silverline cam brgs ,every set has required work mostly to get the thrust set but some are tight as well ,we now source a different brand (green writing on box) and had no problems since,funny enough the silverline mains and rods are ok just the cam brgs are a pain in the arse _________________ I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed |
