childofthewind Samba Member
Joined: October 19, 2010 Posts: 763 Location: Eastern Sierra
Posted: Fri Jan 23, 2015 10:07 am Post subject: Fuel Lines... |
Hey, everyone. Hope winter's treating you all well.
I'm getting ready to replace my fuel lines. They've all been replaced from tank to firewall, I just have the engine compartment left. (for the record, every mechanic who has inspected the lines in the recent past have said the original look fine; this is just a peace of mind thing.)
I was going to have a local shop do this but after reading Ben's great tutorial and some other threads, I'd prefer to save money and learn a bunch doing it on my own.
My one (which may turn into many once I get started..) question is should I have the fuel injectors cleaned somewhere? If so, where? I'm in Portland, OR so local would be great. Do you all have them cleaned when doing this? Anything else I should think about replacing (such as fuel regulator)?
My van is an '87 with the stock 2.1 L.
Thanks!
vermont girl / child of the wind _________________ 1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville |
rubbachicken Samba Member
Posted: Fri Jan 23, 2015 10:11 am Post subject: |
i send all of my customers injectors away to cruzinperformance.com
he's a good guy to deal with, quick turn around, i've had more than a dozen sets done this far no complaints, i'm very happy to recommend his services _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Jan 23, 2015 10:15 am Post subject: |
If you up for a road trip, im showing another vangon guy how to replace them, on my van, in everett on saturday, tomorrow. I could help yiu through it.
Unless you want to be down and out for a week, id stick with just good lines and fuel line clamps to replace, dont worry about injectors unless your having problems. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
KevinsKamper Samba Member
Joined: November 17, 2014 Posts: 72 Location: Massachusetts
Posted: Fri Jan 23, 2015 10:43 am Post subject: |
I just did this job myself....go for it....its not hard and its rewarding when your done....I ended up replacing the fuel pressure regulator and the injectors since I was doing the job. One tip I will share that worked out well.....I attached all the new fuel lines to the fuel rail as well as the injectors while out on the workbench, then installed the whole fuel rail assembly with lines and injectors attached at once, feeding the new lines up to the FPR and T fitting as I went.....saved trying to attach the fuel line and clamps down in the tight work space. Good luck and any questions you can pm me....Kevin _________________ 1990 Westfalia GL
1980 Toyota Sport Truck 4wd
1981 Toyota DLX 4wd
1983 Toyota SR5 4wd |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Fri Jan 23, 2015 1:03 pm Post subject: |
In the past I've bought used injectors here on the samba 5-10 bucks apiece and sent off to witch hunter. That way I'm not down waiting on the turn around and have a set of running spares in the end. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Fri Jan 23, 2015 6:06 pm Post subject: |
If you're up for it, you could check the spray pattern and volume of the injectors before removing the engine compartment lines to see whether they need cleaning. I would replace the injector seals while doing the fuel lines at least. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Posted: Fri Jan 23, 2015 7:04 pm Post subject: |
Stuartzickefoose wrote: |
Unless you want to be down and out for a week, id stick with just good lines and fuel line clamps to replace, dont worry about injectors unless your having problems. |
That's generous of you and I totally would of i didn't have to work.
Thanks for the feedback. _________________ 1987.5 wolfsburg hardtop; 2.1
bluebus86 Banned
Posted: Fri Jan 23, 2015 7:12 pm Post subject: |
Use 30R9 lined hose to resist the government mandated corn based alcohol fuel that cost more, raises food prices and delivers worst mileage, it also attacks the older non-lined hoses. (Thank you corn lobby and congress!!!)
30R9 is resistant to the new crap fuels, has a Teflon like inner liner to protect the hose from the fuel.
30R9 will be printed on the hose along its length, 30R7 is the old stuff, it is NOT lined and is not resistant to todays fuel.
besure to delete the fire wall fitting (bulkhead fitting) , it is made of plastic that does degrade, and can result in a fuel leak, simply delete this fitting, and run the hose under the fire wall. this fitting is located directly in front of motor, just above the flywheel, above motor. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Fri Jan 23, 2015 8:58 pm Post subject: |
bluebus86 wrote: |
...besure to delete the fire wall fitting (bulkhead fitting) , it is made of plastic that does degrade, and can result in a fuel leak, simply delete this fitting, and run the hose under the fire wall. this fitting is located directly in front of motor, just above the flywheel, above motor. |
+1. These fittings are also available made from metal instead of plastic from Van Cafe, Terry Kay here on TS, and others. If you delete it altogether make sure you have a rubber grommet/shield in its place so a hole doesn't eventually wear through you new fuel line . Cheap insurance. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Fri Jan 23, 2015 9:10 pm Post subject: fuel lines |
I replaced my fuel lines about a year ago, on my '88 2.1 Westfalia. I noticed that I had a fuel leak as the van was idling in my carport. Thankfully I caught it before a disaster. I ordered the fuel hose kit from Gowesty, with the "better" hose. The kit came with original style clamps, injector seals, firewall fitting delete, etc. I did have to buy the clamp pliers.
I took my time, replacing one at a time, as I went, using the old hose as a guide for length. Be sure to use a very sharp blade to cut the hose, for a clean cut.
Surprising, my old hoses looked excellent. I had a pinhole in one line, that didn't make sense. I also did the fuel rails on a bench,( actually, on a piece of wood over the engine compartment) and did not do a thing to the injectors. If your van is running fine, leave them. If you want to have them checked or replaced just because, that's up to you. The job was kinda fun. Dealing with the injectors is a piece of cake. Next time I do this, I will probably add just a little length to a couple of hoses. Gowesty now has the fuel line insulators, if you want to replace 'em. Good luck! Be methodical! Know your van. Peace
Dana
Last edited by Dana Champion on Sat Jan 24, 2015 10:52 am; edited 1 time in total |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
CampWesty Samba Member
Joined: September 05, 2012 Posts: 70 Location: North Carolina
Posted: Fri Jan 23, 2015 10:42 pm Post subject: Re: Fuel Lines... |
childofthewind wrote: |
I started with Ben's guide but found he glazed over some areas that a complete newbie like myself didn't quite understand. I found this guide had some nice tips that he didn't cover in detail: http://www.vanagon.org/fuel-line-replacement/
Between the two of them I was able to get the job done no problem.
As for the injectors I didn't do anything special for mine. They seemed to work fine at the time so I just put them back in. They're still going strong. _________________ Eric
1985 Wolfsburg Westy Weekender, Bostig RG5
Bostig Facebook Group
Vanagon Nation Facebook Group
Instrument Cluster Foil Repair Kits - Fix your faulty blue foil for good! |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sat Jan 24, 2015 7:47 am Post subject: Re: Fuel Lines... |
Fuel injectors during the vanagon production era and since rarely go 'bad'. I personally have never had that happened over twenty years of too many vanagons nor do I know anyone who has although I'm sure someone somewhere out there has, as with all things VW there are exceptions.
In the early days of fuel injectors on the aircoolers they could be more problematic although this usually involved stirred-up crud from the gas tank getting stuck in the needle. The injectors these days are about half the size and far more refined.
If anyone has any real concern with their vanagon injectors, there are plenty of off the shelf cleaners like from STP, like from any place that sells car stuff. Just pour the bottle into the gas tank, fill the tank up with gas and call it good.
Removing the injectors will require new rubber seal replacements, two to an injector, when reinstalling. This is recommended for safety and convenience. They are cheap --- I think Vancafe sells the smaller one for 50 cents and the larger for $1 but they can be had from any place that sells Vw parts.
These rubber seals can potentially get brittle from engine heat and fuel residue and eventually allow fuel leakage (rare) onto the engine block. Visual inspection of each outer seal can be done if one is concerned. Equally important, when removing any injector, if these two rubber seals crumble/fall apart (usually it's the inner one), make sure the pieces don't fall back into the injector hole.
Bottom line ... don't mess with them unless you visually spot gas leakage or 'weeping' when the engine is idling, or if you notice during visual inspection the outer rubber seal edge looks cracked or severely weathered. However, I couldn't argue against anyone wanting to replace those seals after roughly 25+ years of service for super insurance |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32596 Location: Reading Pennsylvania
insyncro Banned
Posted: Sat Jan 24, 2015 8:17 am Post subject: |
Fluid Film sprayed on the metal engine parts before storms and when salt is being spread is a really good idea.
Wash off the crap with Simple Green and hot water, than reapply for the next storm. |
Posted: Sat Jan 24, 2015 9:04 am Post subject: |
djkeev wrote: |
Well,
I'm glad you Western Folks who drives without the Department of Transportation engulfing your vehicle in various forms of Sodium every winter have such great injectors.
Quite honestly..... Ours RUST away!
[rust pics]
Dave |
Yep.....that's what mine looked like but not quite that bad, which is why I replaced the injectors with Sorensons from autozone.....some of my hose clamps had rusted thru and I probably was just days away from a fire.....big relief with the all new fuel system now. _________________ 1990 Westfalia GL
1981 Toyota DLX 4wd
Posted: Sat Jan 24, 2015 9:08 am Post subject: |
Yeah Djkeev .... that's quite gnarly and not commonly seen out here. I did have a westy syncro once that came from Maine and had a similar appearance but hey .... the upper rubber seal there still looks good |
Posted: Sat Jan 24, 2015 9:45 am Post subject: |
Despite the fact, in those pics, the injector and hose clamps are turning to dust and the hoses are cracked and turning to stone not to mention the whole assembly looking like it's been sitting under the ocean since 1000 BC, the electrical connections look clean so I'd wager those injectors are still working. |
Posted: Sat Jan 24, 2015 5:37 pm Post subject: |
Thanks Bob and everyone else for your tips and experience, I very much so appreciate it.
All of this bizarre warm weather we're getting in the PNW will have me starting this in the next couple weeks.
Recently I poured some sea foam into my gas tank and have since then also only filled up with Chevron/Texaco and it's definitely running better. Should I put more injector cleaner in after the new lines or before? Does it matter? And is that good enough - to not have them cleaned elsewhere? I could test the spray although I'm not exactly sure what that entails..
I only need to do the engine bay so I'm wondering if I should get a kit from VC or GW or buy things separately?
Thanks! _________________ 1987.5 wolfsburg hardtop; 2.1
