colins84 Samba Member
Joined: January 20, 2012 Posts: 79 Location: Newport Beach, CA
Posted: Sat Jan 24, 2015 12:36 pm Post subject: HELP! Stuck in Renton WA, |
Just flew in from California. Van sat on a slight hill pointed down for two days. Has been running fine up till now. Tried to start. Heard fuel pump. Didn't seem to want to start. I bump started since I was pointed downhill. Got going. Was running pretty rough. Pulled into gas station to fill up. Then the van would not start again. Tried bump starting, and the van will not even bump now.
I could use some help with a direction to go... Trying to get back to Bellingham today. Thanks!!!
-Colin _________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
1986 Vanagon GL (2.2L) |
Randy in Maine Samba Member
Posted: Sat Jan 24, 2015 12:37 pm Post subject: |
Is the starter turning over?
How about with a jump? How are the connections at the battery and starter? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sat Jan 24, 2015 12:40 pm Post subject: |
Fuses all look good _________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
Posted: Sat Jan 24, 2015 12:43 pm Post subject: |
Can you wiggle the clamps? How about the connections at the starter? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Assuming it cranks with alacrity but doesn't fire...
I'd be checking to see if it is getting a good spark.
BTW - when starting, I always have the trans in neutral and foot off the clutch. Aside from slightly less wear it probably doesn't matter most of the time, but in marginal start situations it can help (I think of it as you were able to bump start when the starter wouldn't do it). |
Posted: Sat Jan 24, 2015 1:03 pm Post subject: |
I'm on the road!!! I got out and gave the fuel pump a couple of wacks. Tightened The air intake hose, and also reseated the two relays in the water type box on the left of a 1.9 engine.
Thanks for the recommendations guys! _________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
