Insulation under luggage comparrment
crvc
crvc is offline
PostPosted: Sat Jan 24, 2015 12:45 pm    Post subject: Insulation under luggage comparrment Reply with quote
I have a 1967 bug with a stock 1600 engine. I added foil-backed insulation all atop the luggage compartment and under the rear seat. But it's still too noisy. I still have plenty of insulation I could glue under the luggage compartment. Will engine fumes or oils dissolve the glue?
Any suggestions?
TIA,
crvc
AZ66Bug
AZ66Bug is offline
PostPosted: Sat Jan 24, 2015 1:23 pm    Post subject: Reply with quote
Don't think it would do any good to add to the outside. Might try some padding on the inside. The carpet kit I just installed came with some 1/2 inch padding that I added on top the Dynamat in the luggage area. As for noise, I don't think anything will stop that completely - its a noisy engine!
66 Beetle Sedan, restored 2014
66 Mustang: Original Owner, restored 2008
66 Ford F250: 4th Owner, restored 2013
yammi450
yammi450 is offline
A lot of noise comes in from the opening in the C pillar if you don't have any filling in there. Use the search for "footballs" and it will give you some ideas. I know when I stuffed mine it made a noticeable difference.
microbus
microbus is offline
PostPosted: Sat Jan 24, 2015 1:27 pm    Post subject: Reply with quote
I don't think you want to install anything on the outside that might trap water/dirt and aid in the formation of rust! More padding inside... Try driving a Canadian Standard with no lower headliner/padding... ugh!
Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician
ThorpS18
ThorpS18 is offline
PostPosted: Sat Jan 24, 2015 5:54 pm    Post subject: Reply with quote
Undercoating might help slightly. The insulation a previous poster mentioned looks like this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1742547
Success is never final, failure is rarely fatal, and courage is always necessary.
Mark
Mark is offline
PostPosted: Sat Jan 24, 2015 8:09 pm    Post subject: Reply with quote
They came from the factory with the 'football' pads in the C pillar.
Mine shows no signs of rust, with the car living in the PNW for 50 years now.
andk5591
andk5591 is offline
PostPosted: Sun Jan 25, 2015 5:18 am    Post subject: Reply with quote
On my 65, I did a couple layers of Peel and Seal on the inside from below the window to, and including, the floor. Dont forget wheel wells. Then the usual padding and carpet. BUT on the engine side, I only used cheap aftermarket tarboard over a bare firewall. Already had made and installed replacement pads jammed in the C pillars. Was still a bit louder than I liked.
The next time I pulled the engine, I installed generic "under hood" insulation on the engine side of the firewall and a better tarboard. Made a very noticable difference.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
