Driver Project - 1973 karmann Ghia
Page: Previous  1, 2, 3, 4, 5, 6
Bloku
Expert Noob
Bloku is offline
PostPosted: Sat Mar 21, 2015 6:59 pm    Post subject: Reply with quote
I looks like there are only 2 ways to hook it up. It acting as a power switch or as a ground switch Wink
1971 Karmann Ghia
-Zodiac-
-Zodiac- is offline
PostPosted: Sat Mar 21, 2015 7:08 pm    Post subject: Reply with quote
Good deal Wink
To some people wiring is like the work of wizards.
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
-Zodiac-
-Zodiac- is offline
PostPosted: Sun Mar 22, 2015 8:49 am    Post subject: Reply with quote
Here's what happens when you accidentally leave the window down in FL.
Luckily I didn't glue down the carpet on the floor, I was able to take them out and shake most of the water out, then wipe the rest up from the floor. Suprisingly not much water actually got in.
Bloku
Expert Noob
Bloku is offline
PostPosted: Sun Mar 22, 2015 9:21 am    Post subject: Reply with quote
Looks really good in the pic. One question though... where are your front turn signals? In the grilles? Laughing
1971 Karmann Ghia
-Zodiac-
-Zodiac- is offline
PostPosted: Sun Mar 22, 2015 10:54 am    Post subject: Reply with quote
Razz yepp they're inside the nostrils .
Eventually I plan on going back to the stock ones. Right now they are just those little rectangle ones you buy at Walmart/ autoparts store, so They aren't that bright. If I can't get the originals back, or there is some other problem I'll just install a better setup for inside the grills.
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Mar 25, 2015 10:16 am    Post subject: Reply with quote
Finally got to do my fuel lines, did the engine compartment lines, and under the tank. Got a good bit of gasoline in my eye.. Then decided to wear goggles.. all of the lines were replaced with rubber ones, the only braided part was pump to carb. The replaced lines were in bad shape, cracked and pretty thin.
Here are the old lines next to the new ones
New is more grey, I'm guessing they were black
c21darrel
c21darrel is offline
PostPosted: Wed Mar 25, 2015 12:43 pm    Post subject: Reply with quote
Applause Applause Applause
GhiaBuild
mountainkowboy
mountainkowboy is offline
PostPosted: Wed Mar 25, 2015 5:24 pm    Post subject: Reply with quote
Wow those were ugly! I'm using the new rubber lines that are Ethanol rated.
Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater"
1966kghia
1966kghia is offline
PostPosted: Wed Mar 25, 2015 5:32 pm    Post subject: Reply with quote
Just went through your thread...you've come along way. Great job. I can't wait to get my ride on the road...
Cheers!
-Zodiac-
-Zodiac- is offline
PostPosted: Thu Mar 26, 2015 8:11 am    Post subject: Reply with quote
Thanks!
I look forward to seeing some more progress on your 66', it's good to drive a ghia Wink
-Zodiac-
-Zodiac- is offline
PostPosted: Sun Apr 05, 2015 6:41 pm    Post subject: Reply with quote
Got a transmission for 10 bucks Cool appears to be in alright shape,
Anyway to tell what year it's from? Told its IRS . These are the only numbers I was able to find easily.
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Apr 22, 2015 5:15 pm    Post subject: Reply with quote
well progress is slow, I haven't really had any problems to fix - not complaining about that! I got my spare shift rod and cage that came with the trans, getting a new cage next week - I'm just going to use the original Vw parts, and only the Plastic from the new one. got to look at the trans - it is an AH code, gunk was covering the letters.
I did an oil change the other day because I was feeling bad about using the cheap stuff, so now it has nice oil with Zinc. should keep her good and happy.
Today I noticed something that was new to me, but it's probably been like this since I got it. the gap between the tire and fender on the passenger side are quite a bit closer , that the drivers side. Is this just from old suspension?
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Apr 28, 2015 3:32 pm    Post subject: Reply with quote
Finally got to change the bushing, and the Inserts for the cage! Things went smoothly for the most part, but did have troubles.
did't use any of the aftermarket parts except for the inserts.
old bushing, didn't look terrible..except the part that holds the clip lol
cleaned the old shift rod with kerosene and steel wool, looks brand new. did the same to the shift cage, and parts.
got everything put in, dropped one of the inserts inside of the tunnel twice,dropped a wrench too - coat hanger was MVP of that job. after everything was all installed and the gear stick was adjusted everything was very smooth! much more positive shifts!
-Zodiac-
-Zodiac- is offline
PostPosted: Thu Apr 30, 2015 4:22 pm    Post subject: Reply with quote
Well, decided to replace my broken door hinge finally..
Went to crank it, so I could work on the cement - and then It suddenly died, and had no power - turns out there was a connection on the wire that goes to the VR that wasn't crimped, and had fallen off. That took a while to find..
After fixing that I finally got to work on the door, taking it off was easy
Putting it back on was defiantly not a one man job - atleast not for me. Had to wait for my friend to help. Then adjustment was a nightmare, after adjusting the striker the alignment is 'pretty close' hopefully I can tweak it alittle more to make it better.
Should be the last update for a while, I'm beat. Still have to put the front bumper on..
Page 6 of 6
