1961 400 Hp Single Cab Street Rod Build
Page: Previous  1, 2, 3 ... 8, 9, 10, 11, 12  Next
TheGreenVW
TheGreenVW is offline
PostPosted: Fri Mar 04, 2016 12:13 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
andygere wrote:
Unreal creativity and execution. They should make a HotWheels version of this...
That would be cool!
TheGreenVW
PostPosted: Sun Mar 06, 2016 4:40 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Got the good camera out today
http://www.BenModified.com
TheGreenVW
PostPosted: Wed Mar 09, 2016 6:12 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Nearly finished with the drivers side cab corner and under cab mods
My Build Videos are here:
Machine Dr.
Machine Dr. is offline
PostPosted: Sat Mar 12, 2016 4:05 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
I have been watching this build as well as the YouTube Videos. I am impressed with the creativity and craftsmanship. Very Well Done!
The Truth can be brutal, but a lie is worse.
TheGreenVW
PostPosted: Sat Mar 12, 2016 4:11 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Thanks! I appreciate it
TheGreenVW
PostPosted: Wed Mar 16, 2016 4:53 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Started smoothing off the hundreds of tack welds on the headlight filler panels.
TheGreenVW
PostPosted: Wed Mar 30, 2016 3:17 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Finally got around to welding up the cut in the door and removing the alignment clamps
TheGreenVW
PostPosted: Sat Apr 02, 2016 11:41 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Progress on the drivers side bed side and engine vent install. Welded in the mounting strips.
The vents are in, but still lots of tack welds and grinding to go
TheGreenVW
PostPosted: Sun Apr 03, 2016 8:22 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Many imperfections left to hammer out, but these will be easier now that it is held in place
TheGreenVW
PostPosted: Mon Apr 11, 2016 5:17 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Started on the front turn signals
TheGreenVW
PostPosted: Wed Apr 13, 2016 4:42 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
deleted
TheGreenVW
PostPosted: Thu Apr 14, 2016 2:23 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Finished up the front turn signals
TheGreenVW
PostPosted: Thu Apr 21, 2016 2:28 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Part 12 of the Build on YouTube
daanbc
daanbc is offline
PostPosted: Fri Apr 22, 2016 7:54 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Love the scoop! Much better then the grill.
daanbc
daanbc is offline
PostPosted: Sun Apr 24, 2016 8:17 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Just had a thought last night. What about the scoopes that the old Pontiac fiero had? The one that went over the roof. That would look neat on it. If you could fabricate it.
TheGreenVW
PostPosted: Sun Apr 24, 2016 4:09 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
I like it!
Here is the latest progress on the side scoops
TheGreenVW
PostPosted: Wed Apr 27, 2016 5:03 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Got started on the new Hood today. Plan is to make it look as much like the roof as possible
Bashr52
Bashr52 is offline
PostPosted: Thu Apr 28, 2016 4:37 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Are you going to leave this thing primer and rough, or eventually paint? I vote flat black Very Happy
Is that hood going to leave enough room for the rear window to open?
Looking awesome!
TheGreenVW
PostPosted: Thu Apr 28, 2016 6:58 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Looking awesome!
Thanks! The current plan...so much of the sheet metal is badly pitted that instead of slathering it in body filler (or replacing every panel) I am leaning towards spraying the truck with a light crinkle finish bed liner material. Black, offset by the chrome and stainless.
And yes, there is still room to open the rear window, though it must be shut to open the hood.
Got up early and welded in the rear of the hood. Still need to weld in the corner pieces, the underside and smooth.
daanbc
daanbc is offline
PostPosted: Thu Apr 28, 2016 1:00 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
I favor the crinkle finish also, but in Red.
Page 9 of 12
