1961 400 Hp Single Cab Street Rod Build
Page: Previous  1, 2, 3, ... 10, 11, 12  Next
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sun Mar 08, 2015 6:52 am    Post subject: Reply with quote
Any updates on this?
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
TheGreenVW
TheGreenVW is offline
PostPosted: Sun Mar 08, 2015 9:56 am    Post subject: Reply with quote
Nothing big…shaping hard brake lines, installing gas tank etc. I have been putting some effort into one of my other Death Traps. Just got my V8 powered Daihatsu HiJet to a drivable state.
Here is a link to the Test Drive video
https://www.youtube.com/watch?v=HRD9OVNCy0k&index=6&list=PL8xzCtTkH46Yacfx191MBwjfPCcbNPCrr
sixfootdan
Samba Smartass
PostPosted: Sun Mar 08, 2015 8:28 pm    Post subject: Reply with quote
Lol, That's awesome!
GO SEAHAWKS!!!
TheGreenVW
PostPosted: Wed Mar 11, 2015 4:53 pm    Post subject: Engine and Trans Mounts Reply with quote
The mounts are at least tacked in place. Still need plating and finish welding
www.BenModified.com
TheGreenVW
PostPosted: Thu Mar 12, 2015 11:11 am    Post subject: Reply with quote
Crossmembers are done
www.BenModified.com
TheGreenVW
PostPosted: Fri Mar 13, 2015 3:23 pm    Post subject: Drivetrain is in and connected to rear axle Reply with quote
Other ongoing Projects
www.BenModified.com
TheGreenVW
PostPosted: Tue Mar 17, 2015 5:20 pm    Post subject: Single Cab Hot Rod Progress Reply with quote
Fuel tank is in and plumbed.
Steering Box is being fitted along with the Cab
Gutted the swiss cheese floor to make way for the new raised floor.
Hope to reuse the stock parking brake handle
Cab still needs to drop another 8 - 10"
www.BenModified.com
heywebonya
heywebonya is offline
PostPosted: Wed Mar 18, 2015 11:07 am    Post subject: Reply with quote
I think it would be insanely cool to move the cab forward over the front axle and build a flat bed for the truck.
Regardless, this is an amazing build.
If I knew what I was doing; I wouldn't be building a buggy!
TheGreenVW
PostPosted: Wed Mar 18, 2015 3:37 pm    Post subject: Single Cab Hot Rod Progress Reply with quote
Relocating the headlight buckets
Cab has one inch of drop to go
Gutted a lot more floor to get the cab low
The doors and cab will lose everything below the blue tape.
My Build Site
www.BenModified.com
TheGreenVW
PostPosted: Fri Mar 20, 2015 4:53 pm    Post subject: Reply with quote
heywebonya wrote:
Looks awesome, can't wait to see it rolling! Post a picture from the front
Cab is in its final location, just need to trim off the bottom of the doors.
Part 4 of the Video Build Series
https://www.youtube.com/watch?v=VpO0Jza3EGg&index=4&list=PL8xzCtTkH46avFAEsFkL1x2-tW1IROfZw
My Build Blog (Multiple Projects)
www.BenModified.com
TheGreenVW
PostPosted: Sat Mar 21, 2015 6:50 pm    Post subject: Single Cab Street Rod Reply with quote
Steel and strength going back into the Cab
sixfootdan
Samba Smartass
PostPosted: Sun Mar 22, 2015 8:10 am    Post subject: Re: Single Cab Street Rod Reply with quote
I'm getting into the same scenario soon of welding new thick structure to thin old german metal, What is your welding setup?
GO SEAHAWKS!!!
TheGreenVW
PostPosted: Sun Mar 22, 2015 3:16 pm    Post subject: Re: Single Cab Street Rod Reply with quote
I am using a Lincoln Power Mig 256. I love it. I have had a couple of lesser migs from the big box stores in the past and had nothing but trouble with them. You get what you pay for and it was worth every penny. The 2" square steel in the photo is 14 gauge.
TheGreenVW
PostPosted: Mon Mar 23, 2015 4:07 pm    Post subject: More work on the Cab Reply with quote
Started on the integrated roll cage/body mount system for the Cab today. (Lower part of the picture, the part in the middle is temporary bracing)
www.BenModified.com
TheGreenVW
PostPosted: Sat Mar 28, 2015 1:03 pm    Post subject: Cab Mounted Reply with quote
4 of the Cab Mounts are done. Have a few more mounts and cage tubing to go.
www.BenModified.com
TheGreenVW
PostPosted: Mon Mar 30, 2015 6:47 pm    Post subject: More Tubing Reply with quote
TheGreenVW
PostPosted: Tue Mar 31, 2015 4:17 pm    Post subject: Under seat compartment Reply with quote
Started building a compartment to house an A/C unit under the seat utilizing a void in the frame.
Started with a sheet of 18 gauge
With any luck, this will be finished in a day or two
www.BenModified.com
TheGreenVW
PostPosted: Thu Apr 02, 2015 7:44 pm    Post subject: More metal work Reply with quote
TheGreenVW
PostPosted: Tue Apr 21, 2015 4:20 pm    Post subject: Reply with quote
The Steering Box and Brake Pedal Assembly are both finished and installed. Also drilled and tapped all of the cab mounting points into the frame
Link to my Build Blog (multiple projects)
http://www.BenModified.com
TheGreenVW
PostPosted: Wed Apr 22, 2015 5:50 pm    Post subject: Reply with quote
Page 2 of 12
