1961 400 Hp Single Cab Street Rod Build
Page: 1, 2, 3 ... 10, 11, 12  Next
TheGreenVW
TheGreenVW is offline
PostPosted: Sun Feb 01, 2015 7:39 am    Post subject: 1961 400 Hp Single Cab Street Rod Build Reply with quote
This truck had literally rusted in half! The frame rails were so rusted that there was almost nothing holding the front suspension to the truck. The top 3/4 of the cab and bed gates are very usable.
Link to my Build Blog is below:
www.BenModified.com
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Mon Feb 02, 2015 5:37 am    Post subject: Reply with quote
Cool man, Keep the pics coming. Cool
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
heywebonya
heywebonya is offline
PostPosted: Tue Feb 03, 2015 7:00 am    Post subject: Reply with quote
Are you going to put the front axle under the cab? This would really retain the pick up feel. Amazing.
If I knew what I was doing; I wouldn't be building a buggy!
TheGreenVW
PostPosted: Tue Feb 03, 2015 5:28 pm    Post subject: Reply with quote
Thanks. No, the axle is out front, street rod style. Its hard to tell from the photos, but its looks good. The cab will sit low in the frame.
I started on the frame today. Got one Z'ed rail done
[/url]
heywebonya
PostPosted: Wed Feb 04, 2015 4:16 am    Post subject: Reply with quote
Looks awesome, can't wait to see it rolling! Post a picture from the front
TheGreenVW
PostPosted: Wed Feb 04, 2015 3:36 pm    Post subject: Frame back half is done Reply with quote
TheGreenVW
PostPosted: Thu Feb 05, 2015 7:20 pm    Post subject: Frame progress Reply with quote
Decided to add gussets to the frame joints for extra strength.
Also, welded the front spring perch to the front crossmember while I can still flip it all around for a good hot weld as is supports the entire front of the vehicle.
Frame so far
TheGreenVW
PostPosted: Sat Feb 07, 2015 11:25 am    Post subject: Frame is Done! Reply with quote
Build videos are on the blog
www.BenModified.com
TheGreenVW
PostPosted: Sun Feb 08, 2015 6:24 am    Post subject: Suspension is going on Reply with quote
www.BenModified.com
https://www.youtube.com/user/TheGreenVW?feature=mhee
MMW
MMW is offline
PostPosted: Sun Feb 08, 2015 6:53 am    Post subject: Reply with quote
Looking forward to watching this build. It seems you know what you are doing & have done this before.
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
sixfootdan
Samba Smartass
PostPosted: Sun Feb 08, 2015 10:08 am    Post subject: Reply with quote
You should start a build thread over at www.killbillet.com those guys would dig it too.
GO SEAHAWKS!!!
TheGreenVW
PostPosted: Sun Feb 08, 2015 4:25 pm    Post subject: Front Suspension Reply with quote
TheGreenVW
PostPosted: Sun Feb 08, 2015 4:30 pm    Post subject: Reply with quote
Thanks, I will check it out
TheGreenVW
PostPosted: Mon Feb 09, 2015 4:53 pm    Post subject: Suspension is done Reply with quote
Everything is connected
TheGreenVW
PostPosted: Tue Feb 10, 2015 5:09 pm    Post subject: fenders and engine cradle Reply with quote
Started building the engine/trans/rearend cradle today. Also picked up 4 trailer fenders to make 2 big fat tire fenders!
www.BenModified.com
TheGreenVW
PostPosted: Mon Feb 16, 2015 5:26 pm    Post subject: Engine cradle is done Reply with quote
Crossmembers are next
www.BenModified.com
TheGreenVW
PostPosted: Tue Feb 17, 2015 5:10 pm    Post subject: Hitch Reply with quote
Built a hitch into the frame and modified the rear crossmember to accept tail lights.
My other Projects:
www.BenModified.com
sixfootdan
Samba Smartass
PostPosted: Wed Feb 18, 2015 3:30 am    Post subject: Reply with quote
What are the plans for a bed?
GO SEAHAWKS!!!
TheGreenVW
PostPosted: Wed Feb 18, 2015 7:03 am    Post subject: Reply with quote
I have the original bed sides (top 3/4 portion is decent) and tail gate with some cool old "keep on truckin" lettering. I am going to use these pieces as decoration around a 1 5/8" tubing structure and aluminum diamond plate floor. The bed sides will be trimmed down to match the new bed length.
www.BenModified.com
TheGreenVW
PostPosted: Sat Feb 21, 2015 2:33 pm    Post subject: 400 Hp Single Cab Street Rod Reply with quote
Motor and trans going in
My Build Blog:
www.BenModified.com
Page 1 of 12
