1961 400 Hp Single Cab Street Rod Build
Page: Previous  1, 2, 3 ... 9, 10, 11, 12  Next
TheGreenVW
TheGreenVW is offline
PostPosted: Sat Apr 30, 2016 12:57 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
More progress on the engine cover. Both rear corners are welded in, just need smoothing
View from the underside
http://www.BenModified.com
TheGreenVW
PostPosted: Sun May 01, 2016 8:27 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Tack welds are ground smooth
TheGreenVW
PostPosted: Mon May 02, 2016 3:58 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Wheeled the other end cap
TheGreenVW
PostPosted: Thu May 05, 2016 3:30 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Hood is nearly done. Still need to run thru the english wheel to smooth and crown
Found these intricate bmw hood hinges at the self serve salvage yard for $4.99
TheGreenVW
PostPosted: Thu May 05, 2016 3:27 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Started setting up the bmw hinges. These should allow me to hinge the hood at the front and still up the hood all the way without hitting it against the back of the cab.
TheGreenVW
PostPosted: Fri May 06, 2016 6:19 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Completely mounted the new hood hinges. Also made a support framework to sandwich between the hinges and the hood.
TheGreenVW
PostPosted: Sat May 07, 2016 6:45 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Missing one strut
TheGreenVW
PostPosted: Sun May 08, 2016 7:41 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
TheGreenVW
PostPosted: Tue May 10, 2016 4:41 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
The hood and remote latch are mostly done.
heywebonya
heywebonya is offline
PostPosted: Wed May 11, 2016 6:05 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Wow, incredible work and great to see the fit and finish of each part. Well done.
If I knew what I was doing; I wouldn't be building a buggy!
TheGreenVW
PostPosted: Wed May 11, 2016 4:40 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Thanks!
I started building the passengers side air scoop today.
TheGreenVW
PostPosted: Fri May 13, 2016 5:20 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Right side Scoop Progress
TheGreenVW
PostPosted: Wed May 18, 2016 2:29 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Finished up the second side scoop and got started on filling the gap under the doors.
TheGreenVW
PostPosted: Wed May 18, 2016 9:09 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Time Lapse of the side scoop from sheet metal to completion
TheGreenVW
PostPosted: Sat May 21, 2016 4:15 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
I spent some time applying a little body filler to the rear fenders yesterday. Today, I sprayed them (spray can) with some Rustoleum prof. grade bed liner. I am happy with the way it turned out.
TheGreenVW
PostPosted: Sun May 22, 2016 10:09 am    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
TheGreenVW
PostPosted: Mon May 23, 2016 6:34 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
TheGreenVW
PostPosted: Tue May 24, 2016 4:28 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Filled the gap under both doors. Some light sanding still to come.
TheGreenVW
PostPosted: Wed Jun 15, 2016 4:18 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
Apparently Block Hugger headers and urethane engine mounts do not play well together!
Wrapped the headers where they immediately surround the motor mounts. If the mounts do not melt any further, then I will install new ones.
Also boxed in the area between the front of the radiator and the back of the side air scoop to keep hot engine compartment air away from the front of the radiator.
Booky
Booky is offline
PostPosted: Sat Jul 16, 2016 6:13 pm    Post subject: Re: 1961 400 Hp Single Cab Street Rod Build Reply with quote
No up dates for awhile.
Page 10 of 12
